Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
Sony LCD Projection TV Model No. KF-60xbr800 manufactured march 2003. power on, picture will stay on for 30sec then goes out for 30 sec red standby light blinks 34 times then picture comes back on for 30sec then out again red standby light blinks 34 times again and keeps repeating over and over.
  • chris
    chris Jun 05, 2016
    was there ever a diagnosis to this problem i have the same issue with the same model.
  • Sony Master
  • 10,291 Answers
  • 173 Answers
SOURCE: sony LCD turns off 34 flash turn on 30sec repeats ...
The self-diagnostic function of the projection television will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue, some of which you may be able to resolve without the need for service.
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the television may be overheating. To resolve this issue, ensure that the back of the television is well ventilated.
NOTE: If the television will not turn on immediately after being turned off, wait for the fan to finish its cycle, then attempt to turn it on again. This is part of the cooling process of some projection televisions and is normal operation.
If the flash sequence is not listed above, or the light continues to flash after troubleshooting the indicated issue, follow the steps below to perform a power reset on the television:
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
lno2()
Posted on Dec 14, 2007
Slinteriors
  • 8617 Answers
SOURCE: My sony kf-50XBR800 tv turns itself on and off continuously.
Check PS1601 and PS1601 on the reverse side of the G board these are ceramic IC links (fuses rated at 2.5 Amp @50V)
Posted on Jan 23, 2008
SOURCE: my sony tv model # kdf50we655
Blue shadow at bottom of tv
Posted on Aug 04, 2008
  • 1527 Answers
SOURCE: Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Posted on Oct 25, 2009
  • 8457 Answers
SOURCE: kf-50xbr800 turns off for about
The tv LED light "LAMP" indication it is flashing too or lite up?The tv projection lamp has it been in the tv like 1 1/2 or 2 years already and tv in uses it like 4 or 5 hrs everydays?Yes?The tv projection lamp life has ended.Tv require a new projetion lamp.Dose this whole blinking lights 34 times cycles have like clicking noises to it too.Yes,than the board that call the Ballast board it is also dead.Tv must it Ballast board replace too.This Ballast board only job are to ignite the tv projecion lamp only.
Posted on Aug 22, 2011
Sony Grand WEGA KF-60XBR800 Service Manual
Lamp/Bulb A1601-753A (XL-2000U) .
http://www.shopjimmy.com/dlplamps?tv_brands_select=Sony&tv_models=Sony+KF-60XBR800
Apr 29, 2014 | Sony Grand WEGA KF60XBR800 60" Rear...
My Sony KF-60XBR800 has sound but no picture and i have a faint glow on my screen
I would re check your steps. If you have a harness that is not hooked up, that is bad. It goes some where.
May 10, 2012 | Sony KF-60XBR800
My sony kf-60xbr800 keeps tirning off and on
If lamp has not been replaced in last 2-3 years then replace it, this tv turns off and on because of dying lamp.
Let me know if you see standby/power light flashing on tv front, this is an error code that shows some other problem instead of lamp.
Aug 01, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony LCD KF-50WE610 no picture-red light blinking
3 times standby red light blinking shows that lamp cover has not been placed back properly after lamp replacement.
Make sure lamp cover, (the first thing that you removed to replace lamp in tv) is fixed securely then turn tv On.
Jul 30, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
180 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
