Question about Fellowes Powershred PS-60 Shredder
Need new gears - Fellowes Powershred PS-60 Shredder
  • Fellowes Expert
  • 71 Answers
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Posted on Dec 13, 2014
How to rebuild dana 60 front?
Fully rebuild, or partial rebuild? Pinion, ring, spider gears, pumpkin, bearings? Rebuilding it FULLY and PROPERLY is a big story, one too big to relate here, and it takes quite a lot of special tooling (differential spreader, dial indicators, etc). Please don't attempt this unless you have a well equipped shop.
If you just need to replace the spider gears, that's easy. Drain the oil, remove the cover, rotate the pumpkin until you can unbolt the crosspin. Push/pull the crosspin out, rotate the spider gears until they come out. Remove the side gears. Remove all four thrust washers.
Replace all four thrust washers, then the new side gears, then mesh the new spider gears with the side gears & rotate them into place. If the crosspin hole won't line up, rotate one axle shaft until it does. Install the new crosspin and bolt it in. Replace the cover gasket and cover, refill.
Going further requires a LOT more work, but you'll need to remove the spider & side gears first anyway. If you're replacing bearings or the pumpkin or the ring & pinion, you'll need a bunch of new shims to work with until you can get the ring-pinion clearance exactly right. You'll also need a differential spreader to get enough space to remove/install the pumpkin with its bearings in place. If you're replacing the pinion gear, you'll need to take some painfully exact measurements or you'll NEVER get the ring/pinion clearances correct.
Jul 29, 2014 | Cars & Trucks
Play in steering 1985 dodge w150
You need to remove & rebuild the steering box
I would have done that first
Then work my way to other
parts away from it
You adjust it after you rebuild it
Mar 13, 2013 | 1987 Dodge W150
Do I have to buy new bikes to get higher range of gears?
Actually no! you can visit your bike shop and ask them for higher range. What they do is change the front wheel ring in order to give you higher range.
Jan 17, 2013 | Cycling
My CDX-636 has a mechanisim to lift and lower the
My Sony CDX-636 has a mechanisim to lift and lower the CD reading carriage. It consists of a small motor and two nylon gears. the smaller of the gears has stripped a number of teeth which makes the carriage move up and then slip back. I need a new gear wheel. where can I buy a new gear? I am living in Palmdale, california
Feb 06, 2010 | Sony CDX-636 CD Changer
Chevy distributer gear worn out gear 1997 C3500 7.4
Gears wearing out can be due to lack of lubrication.
Since you have already replaced the gear, not a bad idea to recheck if its ok and tht there is enough of lubricant (oil) going to the gear and around it.
Hope this helps!
Nov 14, 2009 | 2007 Chevrolet Silverado 3500HD New Cars
VW Golf 3 jumping out of gears
Sounds like a stripped reverse gear. And for the second gear probally need a new gear (1st 2nd) and the syncros with a new hub. If too much metal from the gears has already made it's way around in the bearings through the transmission oil you might be looking at a new transmission. The Golf 3 generation had many problems with reverse gears. Sorry to be the one to tell you.
Nov 19, 2008 | 1999 Volkswagen Golf
Stuck in 5th gear
try bleeding your clutch
Aug 19, 2008 | 1991 Ford Ranger Supercab
Kenmore 80 series washer not spinning
you need the gear box not the timer.
Dec 20, 2007 | Washing Machines
Fellowes Powershred PS-60 Shredder Logo
138 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
