Question about Ovens
Zanussi oven zou 370 Timer PRoblem - Ovens
Zanussi ZOU 91 K gives error E80
An error has occurred with reading the programme selector. This can be resolved simply by turning it to "0" and selecting a programme again.
Nov 30, 2013 | Ovens
Oven won't turn on, had a power outage on the street 3 times today. Tried flipping the fuse, but nothing has happened. Any suggestions? Not sure which model Zanussi it is, except it is not brand new!!
The electronic clock/timer must be in manual mode for the oven to operate. When the power to the oven is cut the electronic clock/timer reverts to automatic mode when the power comes back on.
Mar 07, 2011 | Zanussi ZBS963X Electric Single Oven
Zanussi oven timer buzzes at 20.00 then resets to 12.00
Gave up and bought a new timer module for £66 from espares. Timer board has microscopic components so even if you knew what was wrong it wouldn't be fixable.
Sep 22, 2009 | Zanussi ZBF360 Electric Single Oven
We have a Zanussi built under oven (ZUF270). Last
You could but if you disable the timer and anything goes wrong with it could invalid your house insurance if anything went very wrong.
Jan 09, 2018 | Zanussi ZHQ575 Electric Double Oven
I can't get my Zanussi oven to work
Make sure timer is set to manual. and not on auto
Nov 19, 2008 | Zanussi ZBF260 Electric Single Oven
Zanussi Built-In Oven Clock keeps resetting?
The 1000uF/10V condensator in the timer unit has to be replaced.
Sep 29, 2008 | Zanussi ZBF360 Electric Single Oven
Setting Clock and Timer
Worked it out for myself - no solution needed now thank you.
Jun 21, 2008 | Zanussi ZBS963X Electric Single Oven
Clock
Hi this is propably too late now but we moved in to our new house six months ago and have a Zanussi ZBF 360 oven, and had no idea how to set the timer / clock. After fiddling around with the oven clock for the last 6 months i managed to set the clock. It shouldn't be much different to the one you have. Hope this helps you and others in the future.
Click the middle button until the little red things on the screen moved round to the clock symbol, then press + or - to get to the correct time, once you have done this it will flash for a few seconds then it will stop flashing and the clock is set. The same goes for the timer to set it when you want to cook something for a period of time eg: ten mins.
As for getting the oven timer to turn it's self on and off I am still messing with it and when i have mastered it I will let people know.
May 07, 2007 | Zanussi ZBF660 Electric Single Oven
Ovens Logo
12 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
