Question about Frigidaire FGF316 Gas Kitchen Range
Frigidaire gas range oven does not go up to correct temperature
For the past couple of years, our frigidaire oven has not been reaching the temperature we set it to. For example, if we set it to 450F, it will reach about 350F, and if I set it to 550F, it will reach about 490F. I measure the internal temperature with a separate thermometer. We've had service people over to fix it, but they say they couldn't find anything wrong with it. Any suggestions on how this could be fixed?
    Problem Solver:
  • 7 Answers
It sounds like the thermostat is off. This would be the first place I would check.
Posted on Sep 28, 2007
SOURCE:
Bake element wont cycle the temperature
PDF]ELECTRONIC OVEN CONTROL Control Pad ... - Frigidaire
manuals.frigidaire.com/prodinfo_pdf/Lassomption/318204143.pdf
Note: The oven function will not work if the time of day clock is not set. ... The ovencan be programmed for any temperature from 170°F to 550°F (77°C to ... Can be used with BAKE TIME to program a delayed bake cycle. Timer Pad- Used to.
[PDF]ELECTRONIC OVEN CONTROL Control Pad ... - Frigidaire
manuals.frigidaire.com/prodinfo_pdf/Lassomption/318204125.pdf
cycle. Bake Time- Use to enter the length of the baking time. Timer ON/. OFF- Use.... It does not disable the clock, Kitchen Timer or the interior oven lights. TIMED. DOOR .... The Preheat feature will bring the oven up to temperature and.
Gas Oven Repair Manual - Chapter 6 ' Gas Ovens Manuals
www.appliancerepair.net/oven-repair-6.html
If it does not ignite, you certainly do not want the gas valve to stay open. ... these sensor bulbs do not cycle the burner on and off to maintain oven temperature.
How To Fix An Oven Door That Won't Open After A Self ...
Jan 28, 2016 | Frigidaire Kitchen Ranges
How do turn on oven
Good Afternoon Friend,
I understand you want to know how to turn on your Frigidaire range, model# FGF378AC. First, you will need to make sure you have set the clock, by pressing the clock button and then pressing and holding down either the up or down arrows until the correct time displays.
Secondly, you will turn your oven on by pressing the "Bake" button and then pressing and holding down either the up or down arrows until the correct temperature displays. Once you release the up or down arrow, your oven should begin heating to the desired temperature. The control will beep three times, once the temperature has been reached.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 29, 2014 | Frigidaire FGF378AC Gas Kitchen Range
On a Frigidaire Gallery oven, it takes forever for the oven to heat to the set temperature. 20-30 minutes. This seems like a very long time. Once it reaches the temperature the oven temperature is fine,...
Replace the door seals, they are the thin rubber strips around the front of the oven when the door is open. They are simple to change as they just clip on.
Jun 26, 2014 | Hotpoint RGB745 Gas Kitchen Range
My Frigidaire electric oven only heats up to 100 degrees. Please help?
Contact a technician. The ignition and gas valves should allow the unit to preheat and then reach needed temperature within about 30 minutes, at the most.
Aug 22, 2012 | Frigidaire Gallery 30" Self-Cleaning...
My gas oven isn't heating up properly, is there
We were able to trouble-shoot our gas oven before calling the repair man. Our oven reached temperature but did not reheat when it cooled down. Our troubleshooting included taking out the storage drawer and looking at the underside of the oven near the valve.
First check if you can see the flame when the oven is on.
Use an oven thermometer in the oven to test if the oven gets to the desired temperature first. Does it get close to the desired temperature and stay near there for your entire bake time? If it does, you may need to adjust the thermostat setting. (This should be in your manual. Many Frigidaire manuals are available from their support site: http://www.frigidaire.com/Customer-Support/Videos--Manuals/ . )
Since our oven was reaching the set temperature and then not reheating, we had one person crawl under the oven and tap on the regulator when the oven needed to reheat. (We could see the ignitor spark.)
If the oven isn't heating at all, then the thermostat, the gas valve, controller or ignitor are suspects. Can you see the spark of the ignitor? Then it's probably not the issue. Similarly if you see the flame coming on several times during the bake cycle, it's not likely to be the valve. If you have a multimeter, you may be able to check the thermostat and controller for any breaks in the wire.
In our case, since the valve was failing, we ended up replacing the 10-year old range. (We looked at the price of a new range versus part and labor cost for the replacement. The part and labor was more than 50% of a new range.)
I hope this helps.
Apr 04, 2012 | Frigidaire Ovens
Although the termal coupling will glow, our oven burner won't ignite.
On this range it is called a glowbar style igniter.
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Nov 18, 2010 | Frigidaire FGF326AS Gas Kitchen Range
My Frigidaire FGFL67DBF gas oven does not reach the temperature set. I tried to calibrating the control, but it did not work. Any suggestions?
I believe that you have a convection oven.... by design, convection ovens built by GE come up to temperature....at 25 degrees below the set level .... when the Convection function is enabled.
Oct 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire gas range FGF337
The Frigidaire units have a shutoff valve on the regulator that has to be flipped up so the oven will get gas.
May 19, 2008 | Frigidaire FGF337 Dual Fuel (Electric and...
Frigidaire Gas Range Oven not getting hot - FGF376CEFP
DEAR CORDLESS TRY CHANGEING THE GLOW IGNITER THE GLOW IGNITER GOES BAD AFTER A FEW YEARS AND YOU HAVE TO CHANGE THEM YOUR BURNER SHOULD LIGHT IN 30 TO 60 SECONDS IF YOUR GLOW IGNITER IS NOT DRAWING ENOUGH AMPS YOU WILL SMELL GAS BUT NOT IGNIGHT THANKS GEORGE
Oct 29, 2007 | Frigidaire FGF376 Gas Kitchen Range
Frigidaire FGF316 Gas Kitchen Range Logo
318 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
