Question about LG LA185HV Split System Air Conditioner
My windy inverter air conditioner runs for 15mins shut down an error code ff. what does that mean
5 Suggested Answers
dgjtex
  • 405 Answers
SOURCE: C4 error code on LG artcool airconditioner
www.yx2.fi/LG/wall_and_art_cool_error_codes_2007.pdf
Please read this article, I think it will help you solve your problem
Posted on Jan 14, 2009
  • 400 Answers
SOURCE: Water level float switch error
You do not mention the model, I presume that it is a cassette, in which case the float switch is located in the indoor unit. You have to remove the cover which is 4 screws. First make sure all power supply is turned off. Then remove the drain pan which surrounds the fan blade. You will see in one corner of the unit a slightly deeper part of the drainpan, this is the corner where both the condensate pump as well as float switch is located. Before you do any of this, give a serious blow into the drain pipe from outside and this may dislodge any sludge which may be causing the floatswitch to stick. You can also pull out a rubber plug which is under the pump on the drainpan.
Posted on Mar 05, 2009
  • 9 Answers
SOURCE: Air conditioner shuts down constantly, need to
Sorry but you are just going to have to keep emptying it. These types or air conditioners are also use as de-humidifiers and unless you can place it somewhere where you can connect a drain hose it is going to require many trips to dump the holding tank of the condensation.
Posted on Jul 12, 2010
  • 414 Answers
SOURCE: my air conditioner has just
Not enough air being drawn over the outside condenser unit. This could be for a number of reasons. The unit may be covered, restricted, or blocked. The condensor fan may be inoperable on the unit. Without a model number I would first check the outdoor fan for proper operation, and contactor and run capacitor. It sounds as though the compressor is coming on and going into thermal overload.
Posted on Feb 13, 2011
E1 error code means?for Idec inverter split type airconditiong
Sharp air conditioners are among those designed to display the E1 error code after 720 hours of use. It's a reminder to clean the air filter, but cleaning the filter doesn't reset the memory. Unplug the air conditioner again and plug it back in. It should now work normally.
Apr 04, 2018 | Inverter Heating & Cooling
Error code for FF for KingAir air conditioner?
Error code FF means the outdoor DC motor fault.
first check the resistance value of the DC motor port, change the DC motor if short circuit.
Nov 08, 2016 | Refrigerators
Accent model ADC 27E1. Why is it displaying E C fault?
FAQs and Troubleshooting - Actron Air
www.actronair.com.au/service-and-warranty/faqs-and-troubleshooting
The air conditioner is not running at all and no control lights are on. (If there are no ...Air conditioner regularly cuts out on a circuit breaker trip or error code ...
Air conditioning (Accent Air control panel) is - Fixya
www.fixya.com/support/t3343544-air_conditioning_accent_air_control
Nov 3, 2009 - Air conditioning (Accent Air control panel) is displaying EC - what ... Panasonic mini split air conditioner css9nkua error code h99 what does it mean ...ERROR CODE ON AIRCONDITIONER LG ART COOL INVERTER MODEL .
Dec 05, 2015 | Heating & Cooling
What is the error code E5 on bluestar air conditioners mean
Problem
Overheat of inverter compressor motor
Cause
Shortage of refrigerant amount Leakage of four way valve
Defect of connector contact
Aug 14, 2014 | Heating & Cooling
Ciac air conditioner ff error code
FF code means blown or missing damper fuse. Replace damper fuse (inside equipment cover plate) and try again. If damper fuse blows again, find and fix the problem causing the fuse to blow.
Mar 27, 2014 | Carrier Heating & Cooling
We have 2.0 HP inverter wall mounted LG aircon, when we turn on the ac, the indoor unit only is running and shut down after 3 mins. What is the solution?
Hi Marie, does the green indicator light on the front panel flash after it shuts down? If it does...count how many times it flashes this will refer to a fault code diagnostic.
Keith.
Jan 02, 2014 | LG LS-K2430HL Heat Cool Mini Split Air...
Hi, I want to know the meaning of the error code of an air conditioner panasonic s91 inverter.Grazie
Grazie, your question is rather confusing, because you listed to different model numbers for to different types of appliances. The "panasonic s91 inverter" is a cooking appliance. Whereas, the CW-X-C243HU is an air conditioner. So, which appliance are you inquiring about? And you didn't even say what the Error Code is.
Perhaps you can be bit more specific.
Jul 13, 2011 | Panasonic CW-XC243HU Air Conditioner
Ac unit shuts down
See this document for P8 code on Mitsubishi Mr Slim MXZ30TN... It is likely you can get the fix just from following the diagnosis steps 1-7. http://www.digelair.net/pdfs/TECHLIT/MITSUBISHI/MrSlim_P-SERIES_Troubleshooting_TIPS.pdf
Jul 02, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Furnace runs but won't ignite.
Error code 12 is blower on after power up. Meaning: after you turn on power to the furnace for aprox. 60-90 seconds the blower will run. The blower should then shut down and the furnace should go through the start up process, providing that the thermostat is set for and calling for heat. If the furnace fails to start after blower shut down there should be a new fault/error code. However if the blower continues to run longer then 90 seconds and continues with the same fault code more then likely the circuit board is bad. Please let me know if this was helpful and give me a rating. Good luck.
Feb 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Error code on air conditioner e1
Search for this problem on web or contact Sharp Technical Support for the following procedure:
1. Unplug unit.
2. Hold down power button while plugging in unit. It will do a short self-test and then beep. leaving unit off.
3. Release power button and unplug.
4. Plug in again and turn on normally. This should last for about 720 hours, at which point the E1 error will come back and you need to follow the procedure again. (You might as well clean the air filter at this point just in case it really needed it...)
Jun 09, 2008 | Heating & Cooling
LG LA185HV Split System Air Conditioner Logo
187 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
