Question about Kenmore Magic Blue 24195 Bagged Canister Vacuum
Do I need a filter behind the bag??? - Kenmore Magic Blue 24195 Bagged Canister Vacuum
What is the right bag for sebo x4
  1. First, pull out the hose, turn the unit on, check for an obstruction in the hose. (unclog and obstruction)
  2. Separate the body from power nozzle. Check for obstruction in the air hole passage.
  3. Pull and clean both filters in the unit. The inside white long carriage and the exhaust filter located above indicator panel. (nozzle body)
  4. If this is not working. think about where and how dirt is carried or passes from the front floor nozzle or through the hose.Somewhere in the unit the it is clogged. The red light censers a full bag (we know that's not the issue) or an obstruction to the normal air flow.
  5. Last Resort contact http://www.sebo.us/contact_us.aspx
  6. In closing: I've been selling and repairing vacuums for over 30 years. Of all the 5 major brands that I sell. Sebo is by far the, best product on the market.
Aug 23, 2014 | Sebo X4 Bagged Upright Vacuum
Why is my hoover windtunnel vacuum cleaner shutting off?
Hi there! Sounds like the thermal protector is being activated. This is usually caused by a clog or a filter that needs to be cleaned or replaced. Follow the steps below to prevent the unit from shutting off.
1. Remove the hose completely.
2. Use a broom stick to gently loosen and clear hose of clogs.
3. Remove the bottom plate and brush-roll.
4. Use a wooden spoon or something similar to break up and remove any clogs from lower hose.
5. Check the primary filter behind the side grille. If it is dirty you may rinse it under running water and allow 24 hours to air dry outside the vacuum.
6. Remove the bag door. Clean the primary filter located on the vacuum under the bag. Rinse with water and allow 24 hours to air dry outside the vacuum. The primary and secondary filters should be replaced at least once a year.
7. Check that the bag is not full. If it is, replace the bag.
The vacuum will turn back on when it cools off. This can take up to an hour. Hope this was helpful!
Jul 08, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
How to fix squeaking and bag full sign lit on the sebo x4 extra upright vacuum?
Check the main "kitchen roll" filter isn't clogged which is on the left hand side of the bag when the bin door is opened. There could be a clog, either behind the pick out metal grid below the filter roll, or the roll filter requires to be replaced. Can you add more info about the squeaking though? Is it a high pitched squeal all of the time or just intermittent and where it seems to be coming from - it could be excess air escaping from a pierced hose or a drive belt issue.
Oct 30, 2013 | Sebo X4 Bagged Upright Vacuum
My Miele Solution HEPA 5000 vacuum cleanr gives off a burning smell but will continue to run with a varying motor tone. I have not run it for more than a minute like this. I have reviewed responses to...
Check both the bag and the HEPA filter behind the bag, torwards the motor. The HEPA filter could be clogged. Love these units but it takes clear attention to multiple filters.
Mar 06, 2018 | Miele S318 Bagged Canister Vacuum
How do you cheng the filter
The Sebo X1 has 2 filters. Both should be changed once for every 20 bag changes. The long cylindrical filter in the bag compartment just slides out to the front - grab the little handle at the bottom and pull forwards - it can be a bit stuck, so you may need to lever it out with a screwdriver or similar. When you put the new one in, make sure you push the little metal lever back up behind it (this is just a simple device to prevent you from shutting the bag compartment when there's no filter present).
To find the second filter, release the foot pedal and lie the handle flat on the floor. This exposes a square panel with lots of small holes in it. Release that panel by squeezing the clip, lift it off and pull the foam filter out. Just drop the new one in and replace the cover, pushing it until it clicks into place. Job done!
Mar 27, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
How do I install new filters on a Miele Blue Moon?
There are two filters on the blue moon. The hepa filter and the motor filter. You get to both filters the same way. You open the lid, like you do when you change a bag. The motor filter is right behind the bag inside a plastic cover. There should be two tabs you can pull down to open and access the filter. The hepa filter is located toward the back of the bag chamber but on top. There is one tab in the middle that lift up on.
Sep 23, 2009 | Miele Blue Moon Bagged Canister Vacuum
How to change filters on a Kenmore canister vacuum
Depending on age there may be one or two filters. A Hepa filter is an exhaust filter generally at the back end of the vac, sometimes at the back top.
For this style filter there will be a small grill with a release tab on it, simply pull the finger tab and the grill should pop off revealing the filter.
There is normally a bag chamber filter behind the dust bag as well. Open the bag chamber below the tool storage and remove the bag.There will be a soft filter sitting behind the bag on most models. If it is a sponge type it can be washed and reinstalled when dry, but if fabric it is disposable.Make sure you have replacement filters in hand before changing as some filters simply pop into a reusable frame, often a red frame. If the material slides out the frame is generally reusable, if glued in , it is likely disposable.
USE only the specified filter and chose the best quality multi ply filter bags for maximum vac performance and efficiency
Sep 07, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Bag full signal shows when a bag is still on its
This is often caused by fine dust such as drywall dust or an internal filter behind the bag being clogged. Look for blockage in the bag comaprtment
Sep 06, 2009 | Vacuums
Electrolux #1521 Canister Vacuum won't stay closed
hi from uk your problem with the canister cover/door coming off whilst vaccing ? you have renewed bag ? ok but there is a filter/gauze also inside the canister where bag is fitted if you check inside you should see the filter at opposite end from where bag is secured it is usually fitted behind a slotted pull out plastic gate ? this filter/gauze is to allow air out of canister when vaccing and the filter traps any dust that may accumulate inside the canister case so the dust does not get blown out to atmosphere/rooms SO if this filter is clogged it will not allow vacced air to escape out of canister so result is build up of pressure within cylinder and eventually cover flips open ! so for now you can remove filter/gauze and wash then dry refit this will allow air to escape from canister but still retain dust particles from escaping as it is designed for however may i suggest you replace filter when convenient ? all above is on assuming that the latch on cover is working ok and not now damaged ? hope this helps best wishes
Mar 01, 2009 | Electrolux UltraLux 2000 Bagged Canister...
It just shuts off!
Some of these have the Hepa filter on the back, if so there will be a door to access it. If there is one, some had a reset button that you push, mainly for when you change the fifter, if it has one, push that reset, if it needs to be re-set, it will shut off after a seconds. Remove the Hepa filter and look see if there is a reset button. https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM, this will give you a link for a user manual. If you disconnect the hose, will it shut off or stay on. If it stays on then there is a clog either in the hose, wands, or the inlet down by the brush roll. If it goes off, and there is no reset by the Hepa filter, then there could be a problem with the motor or motor protector.
Jan 30, 2008 | Bosch BSA2200UC Compact Plus Health Guard...
Kenmore Magic Blue 24195 Bagged Canister Vacuum Logo
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
