Question about Pulaski 628100 Ashton Park Dresser
I need replacement bolts for bolt-on bed rails
Where can I purchase replacement slats, side rails, and bolts for rail slot brackets?
I would think almost any good home improvement store has all that stuff .Home Depot ,Lowes,Menards etc
Sep 08, 2015 | Coaster Briana Black Leather Like By-cast...
Lost machine bolts for louis philippe sleighbed
You can pick replacement up at a hardware store. If you need to figure out how long just line up the holes the bolt goes through, put a straw or somthing like it through, mark the depth and that is the size you need. I am guessing it is about a 3 1/2 inch long bolt at 3/8inch in diameter....may be a 1/2 inch in diameter.
Jan 23, 2013 | Coaster Louis Philippe 200431 Sleigh Bed
Where are the 6 bolts to remove the bed of a
crawl under the truck , 2 is at the frt of the bed ,then look inside of the chasis rails at the back 2 near the bumper and 2 between those bolts and the rear end located inside the rails also . there is a small wire on the right frt to remove as well as the 3 screws in the fuel door area you must remove to lift the bed
Nov 26, 2012 | 2004 Dodge Ram 1500
Need replacement bolts for acme eclipse futon bunk bed
Take a look on amazon for replacement parts. Here: Amazon com acme bed bolts I hope this was useful. Cheers
Sep 04, 2012 | Acme Eclipse Black Metal C Shape 2" Tube...
I lost my manual, I need to know how to transform the crib into a toddler bed
Converting a Simplicity Crib into a Toddler Bed:
Please note, Simplicity has gone out of business and the Simplicity Cribs should NOT be used as cribs. They were sold at Walmart, Target and BabiesRUs. The word on the street is that Walmart is the easiest to deal with when it comes to returning them. Those who wish to return Simplicity cribs don't need a receipt, they can just take them to Walmart for store credit. BabiesRUs was apparently giving about $65 while Walmart was closer to $190. Again, this is just what I have heard from others.
You can find the specific information on the Simplicity recall here.
If you do want to use your Simplicity crib as a Toddler Bed, I have not read any warnings against this. Again, I might just take it to Walmart anyway and get a store credit and perhaps buy a new convertible crib. You can get some great ones on Amazon for around $150 with delivery included.
I would pack it up, take it in for store credit, and get a new crib!
You can get some great deals these days on cribs, there's a great one on Amazon for $150 with free shipping so it's kind of a no-brainer.
As I have heard, Walmart will take it back, no questions asked and no receipt necessary and you can get a brand new one with brand new parts, brand new instructions and no recalls or risks!
Good Luck.
Here's one of my favorites:
mkd123_2.jpgGraco Sarah Classic 4-in-1 convertible bed
If you still want to convert it, here is what you need to do:
1. Remove the front panel of the Simplicity crib. Use an Allen wrench and 45mm bolts (there should be extras underneath the crib, along with an Allen wrench, but if there aren't then you can pick some up at your local hardware store.)
2. Check the mattress support. It needs to be in the lowest position available, which will allow the toddler to get in and out of bed easily. It is also the only position that will make the rails line up properly with the pre-drilled bolt holes. To lower the mattress, unscrew the four bolts from the four corners of the mattress support and slide the support down. The holes for the lowest setting are just about the bottom wood panels. Use your Allen wrench to reattach the mattress support with the same bolts you pulled out when the mattress was in the higher position.
3. Attach the toddler bed rails to the crib frame. Use two 38mm Allen bolts on each rail. There are pre-drilled holes in both the rail and the crib frame. Line up the holes and then loosely screw the bolts into place. The bottom of each rail has a metal L-shaped hook. This will slide under the mattress support. Use a 19mm Allen bolt to attach this piece to the mattress support. When everything is lined up and screwed in loosely, go back and tighten each bolt. Repeat on the other side.
4. Check the entire crib frame for loose bolts. Use the Allen wrench to tighten all the screws. Toddlers can be rough on their beds, so it is important to make sure the bed is safe. You should recheck for loose bolts often. Jumping and climbing on the bed can easily loosen the bolts and screws.
5. Don't forget to hang onto the front panel and store it carefully, you will need it later to convert the bed into a full sized bed.
Jan 23, 2011 | Simplicity for Children 4-in-1 Convertible...
I have a delta jasmine crib.I can't remember if it comes with the bed rails to convert to a full bed
I have this samw crib and I was wanting to convert it to a full size bed as well. From what I understood on the instructions, you need to buy the bed rails on your own. You'll also need a set of bolts to help with the conversion. However, those bolts, labelled as (P) in the instructions, don't come with the crib. I am trying to find out where I can buy these bolts though since you can't buy them from the Delta website.
Oct 11, 2009 | Delta Luv Jasmine 4852 Crib
How do u remove the bed from a 2001 chevy?
get under the bed you have 4 to 6 bolts that run on each corner of the bed to frame rails , look thru holes in frame for big bolt heads to remove the bed, easy , hope this helps you ,thanks robert b.
Jun 07, 2009 | 2001 Chevrolet Silverado 1500
Trying to turn our crib into a toddler bed
Part needed: Allen Wrench
Safety rail
Safety rail bolt
Make sure the mattress support in in lowest position. Remove the front top rail and front panel. Attach both safety rails ( small side pieces) to the crib end leg using the safety rail bolts.
Mar 25, 2009 | Delta Enterprise Baby Gear
Convert to toddler bed
They do have answers on their website, you may want to check your printed or online crib instructions to remind yourself how you put the crib together, too.
I found the answers here:
http://www.pali-design.com/index.php?path=customer_services&template=faq&section=customer_services&subsection=faq&page=faq
i've pasted them below. You can make it a toddler bed without a side rail just by removing the movable side of your crib, and you can install the side rail instead of the movable side if you want it to look a little more finished and help keep your child from rolling out of the bed.
FAQ
How to convert a crib into a toddler bed
To convert a crib into a toddler bed you must loosen the two front gold bolts left and right side of the crib and remove the dropside (the front gate that goes up and down). After removing the dropside be very careful that you tighten back your two gold bolts.
How to install the streight rail (toddler rail)
To install a streight (toddler) rail loosen the two front gold bolts left and right side of the crib and remove the dropside, once you have removed the dropside replace with the streight rail. Always be very careful and make sure you tighten back your two gold bolts in the front.
Oct 14, 2007 | Pali Sabrina Crib
Changing from a crib to a toddler bed
1-Lower drop side to lower position. Then on the opposite side of the crib, remove stationary side. To remove stationary side, press the small tab on the end hardware(brown plastic piece that connects the rail to the frame) and then pull rail up.
2-Before reinstalling the conversion safety rail(csr), remove the mattress support bolt that is on the side the the csr opening will be(the foot of the bed). A new bolt will be used to reattach the mattress support in the next step.
3-Slide csr hardware onto the hardware on the crib ends. Insert two 1/4-20x2" bolts into each end. One bolt will replace the mattress support removed in step 2. Be sure to put the bolt back through the mattress support bracket before screwing into the end.
I have the instruction page with pictures if you would like a copy emailed.
jmsmith2003@msn.com
Sep 15, 2007 | Childesigns Carrollton Crib
Pulaski 628100 Ashton Park Dresser Logo
44 people viewed this question
Top Pulaski Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Pulaski Furniture Expert? Answer questions, earn points and help others
