Question about Sanyo Microwave Ovens
I have a Sanyo EM-S1298V microwave which will not start. I program the power level then turn the timer knob but it will not start when I press the button. However the timer continues to count down.
No I have not, it's not the door micros witch.
A couple of symbles come on the control panel with I cannot find out what they are
i am sure it's a simple problem, but the manual, which came with the unit, does not have a decode for the symbles on the control panel
Posted on Nov 06, 2014
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp R-1450 microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
On these, it's usually a broken tab on the upper switch holder.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
That sounds like what's happening when you hold the Start pad - maybe you're moving the frame and chassis enough to help it work.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 19, 2008
SOURCE: EM-G4753
I did a google search for the service manual and found one from Sanyo support. From that I was able to figure out how to open the unit safely, and find the fuses and safety switches to check. I found a loose wire plugged onto the main interlock switch (don't know how it worked all this time for how loose it was...). Re-attached it, and now it works fine.
WARNING! There can be very hi voltages on the inside of the uwave so you really need to be careful and know what you are doing! Also, you need a special bit to remove a couple of the cover screws.
Posted on Apr 15, 2009
SOURCE: Microwave not heating food
I have exactly the same problem - strange and annoying! Did you manage to fix it?
Cheers,
Ben
Posted on Jan 31, 2010
SOURCE: Microwave Oven EM-804T
When I opened up the microwave cover, noticed that the door latch mechanism was worn and not holding up the interlock switch. A thick piece of tape on the worn piece of plastic and microwave was back to working (I had symptom of the timer counting down without the microwave turning on)
Posted on Nov 01, 2010
  • 1833 Answers
SOURCE: our microwave has power but
I will reply soon.
Posted on Apr 15, 2011
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
How do I use power feature?
Sanyo EM-S5002W Instruction Manual & Cooking Manual
www.manualslib.com > ... > Instruction manual & cooking manual
Sanyo EM-S5002W Manual Online: Control Panel And Features. OPERATION (1) ...Sanyo instruction manual microwave oven em-s5002w. Hide thumbs ... cooking. (4)POWER LEVEL. Use to set power levels other than. 100%. (5) KITCHEN ...
Oct 09, 2015 | Sanyo Microwave Ovens
How can I to set clock on Sanyo Microwave EM-C678
1. Open door
2. Press clock/Kitchen Timer button the display will show "0:00" with the hour"0" flashing.
3. Enter the correct hour by turning the potary dial. Enter 1-12
4. Press clock/Kitchen Timer button the display will show "0:00" with the minutes "00" flashing.
5. Enter the correct minutes by turning the potary dial. Enter 00-59
6. Press clock/Kitchen Timer. The colon will remain flashing.
7. Close the door.
Sep 03, 2014 | Microwave Ovens
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
EM-G5596V Sanyo Microwave - Start button does not work
MY KIDS WERE USING THE SHARP MICROWAVE R-9H94B FOR A TIMER WITH NO FOOD IN IT. IT NOW DOES NOT WORK AT ALL. IS THERE A FUSE OR A QUICK FIX TO THIS?
Jan 01, 2010 | Sanyo Microwave Ovens
EM-G4753
Apr 14, 2009 | Sanyo EM-P410W Microwave Oven
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Sanyo microwave EM-X515G
I'm thinking that the circuit board has a problem. I doubt it will work but disconnect all the connectors on the board...with the power off and reconnect. It may clean off some goo. If not, use your method as long as it will work and then consider a new board.
Dec 15, 2007 | Sanyo EM-S5002W Microwave Oven
Sanyo EM-P740w
It looks like you would enter the cooking time then press POWER 1 to 10 times. Once = 100%, twice = 90%, thrice = 80%, and so on, and "PL#" will appear in the display where "#" is the selected power level. On some models, twice = 80% and thrice = 60%, etc. and "80%", or "60%", etc., will appear in the display. Then press START. Did that do it?
Dec 07, 2006 | Sanyo EM-P740W Microwave Oven
Microwave Ovens Logo
143 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
tony denham
Level 1 Expert
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
