Microsoft Xbox 360 Console
Problem for Microsoft Xbox 360 Console
My xbox 360 won't even start up/turn on
By lil mike on Sep 28, 2007
This is bs i just bought halo 3 and i get home and my xbox 360 don't even turn on that fucked up piece of shit xbox
Same Problem
May 25, 2009
-   ok i was playing my xbox about an hour ago then turned it off to watch T.V. got bored of watching t.v and went to go back on the xbox so i turned it on but it didnt load up and there arent any red lights help me plz. -   smurfula
May 25, 2009
-   everytime i move it to a different T.V. it take up to 48 hours until it will turn on. why? -   joel18ganser
May 24, 2009
-   ok ill push the power button and it wont start up...but theyre are 3 red rings-   christianmc1
May 19, 2009
-   my xbox just died poor thing:'( how can i ressuect it :'( ?!?!?!?!? -   Guest
May 17, 2009
-   i left my xbox 360 on last night, and when i woke up it was working, so i unplugged it and moved it to another room to play, and it wouldnt turn on, idk whats going on? can someone help?-   Guest
Best Solution
posted on Jan 13, 2009
Very Helpful)
ddowell
Rank: Apprentice
Rating: 99%, 74 votes
Make sure you check that your USB ports don't have a bent pin shorting to ground.
That was the problem for me
Was this helpful?
Yes
No
64 people thought this was helpful
Solution #2
posted on Jun 06, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
If the unit wont power on, and the power brick has power and is lit up green, the issue is likely a failing voltage regulator transistor. The P/N of the transistor is MMBT3906LT1 and it can be replaced at home with a small soldiering iron and some care. Look up the transistor part number. There of plenty of location guides and sources to buy it on line. They are all of a few dollars.
Good Luck!
Solution #3
posted on Jun 20, 2008
Helpful)
alex t 1992
Rank: Wiz
Rating: 83%, 40 votes
it might not be the power supply it might be the consele it self
Was this helpful?
Yes
No
8 people thought this was helpful
Solution #4
posted on Jul 03, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
well mine did the same thing wouldnt cut on then i unpluged the cord from the big box and pluged it bak on and it wurked
Solution #5
posted on Mar 27, 2008
Helpful)
angelinamax
Rank: Apprentice
Rating: 85%, 33 votes
Mine would not turn on either, all I did was unplug the power brick from the powerstrip I had it in and put it directly in the wall outlet.
Was this helpful?
Yes
No
12 people thought this was helpful
Solution #6
posted on Sep 29, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
If you're talking about your hard drive (attaches to the top of the machine), then take it out and use a memory card. If it's a memory card... then you may need to replace it.
Solution #7
posted on Jul 24, 2009
Very Helpful)
mojeemoo
Rank: Apprentice
Rating: 100%, 26 votes
Its more than likely that one or both your USB ports are damaged in that the pins have bent (useally kids forcing USB's in to hard with no care in the world). With a small screw driver seperate the pins its unlikely that you will be able to use these port/ports again, unless replaced. My problem was solved.
Was this helpful?
Yes
No
26 people thought this was helpful
Solution #8
posted on May 08, 2009
Very Helpful)
DCalvacca
Rank: Apprentice
Rating: 98%, 33 votes
My Xbox didn't turn on and the power brick was displaying an orange light. After I plugged the power cord in it turned red.
My two USB ports were housing 2 of the Plug in Charge cables for my wireless controllers. After unplugging those and plugging the power cord back in it booted up.
Hope this helps someone out there. :)
Was this helpful?
Yes
No
31 people thought this was helpful
Solution #9
posted on Sep 08, 2009
Very Helpful)
Dannytheevil
Rank: Apprentice
Rating: 95%, 5 votes
Yeah i had that same problem. I was unplugging it and plugging it in and there seemed to be no clear problem. BUT! i got it working by blowing into the bit that goes into the xbox on power supply and the xbox bit itself. after a good blow it worked fine. Musta been a bit dusty :)
Was this helpful?
Yes
No
Solution #10
posted on Mar 29, 2009
Helpful)
Hell Cresent
Rank: Apprentice
Rating: 94%, 21 votes
This is a repeat of a previously made solution.Try to unplug anything that's in you usb slots.For me it worked when i unplugged my charger for my controller and it terned on for me!!! TY im book marking this sight.
Was this helpful?
Yes
No
16 people thought this was helpful
Solution #11
posted on Sep 11, 2009
Helpful)
ScoobysDoo
Rank: Apprentice
Rating: 94%, 4 votes
Just had the same problem and per another user it was a USB port. One port had the plastic "fin" broken off and one of the pins was touching the side. Bent it back and put a piece of tape over it so they won't try to use it again. Any USB hub will work with the xbox.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #12
posted on Dec 23, 2008
Helpful)
JamesB71426
Rank: Apprentice
Rating: 92%, 9 votes
This has occured many times in the past for me and I have found that it works kind of in reverse to when it overheats while playing and freezes up.. if your system is too cold when you try to turn it on then it sometimes will not boot up.. my advice? Place your Xbox 360 in a warmer environment (not to hot or you'll damage it) and after a few minutes try to turn it on again... this becomes a problem for Xbox Arcade systems especially around this time of the year (or that has been my experience anyway)..
Again, try warming your 360 up a little bit. DO NOT put it in the microwave or oven, i'm sorry I shouldn't even have to say this but there are people out there who would do that.. just place it in a slightly warm room with a heater or place it under a blanket (make sure the power is off.. it doesn't have to be on to warm up)
Was this helpful?
Yes
No
Solution #13
posted on Mar 13, 2009
Helpful)
MediaStoner
Rank: Apprentice
Rating: 89%, 19 votes
If its brandnew i dont know what the problem is but to fix one that has stopped turrning on after you have moved it or somthing then first check the indicator light on the powersupply
now if its orange then its on standby meaning it operational and waiting on xbox response.
and you press the button and it does not turn on. this means the problem is most likely bbetween the xbox and powersupply. so what i did is keep pressing the power button while moving the cord around near the ends and such. YAAA it turned on
try it!!!!! no1 else offers this soloution and it worked on mine and my friends xbox
Was this helpful?
Yes
No
11 people thought this was helpful
Solution #14
posted on Jun 13, 2009
Helpful)
patz1
Rank: Apprentice
Rating: 88%, 4 votes
power biick turning red
hi, iv had the RROD twice in 2 years & fixed it myself (HAPPY GAME DAYS)till now.
its happend again, on repairing it this time i forgot to connect the fan to the motherboard & switched it on, the fan started pulsating then the brick turnd RED.
plz help thanks.
Was this helpful?
Yes
No
Solution #15
posted on Oct 13, 2009
Helpful)
brewcrew55
Rank: Guide
Rating: 81%, 13 votes
Well the first thing you do is take it to best buy or another electronical store and they should fix it for free, best info ever!!!
Was this helpful?
Yes
No
Solution #16
posted on May 23, 2009
Helpful)
keeyanahwds3
Rank: Apprentice
Rating: 83%, 9 votes
My xbox 360 won't turn on. The power cord is lit up.
Was this helpful?
Yes
No
Solution #17
posted on Apr 15, 2009
Somewhat Helpful)
Armand77
Rank: Master
Rating: 83%, 16 votes
What i would do is try a friends power cord or one from a different console and see if that solves the problem... if not you best bet would be to send it in, or even better try to experiment and come up with different solutions and then post it here =P cuz this seems to be a common problem with some people.
Was this helpful?
Yes
No
Solution #18
posted on Apr 27, 2008
Somewhat Helpful)
BoogerBill41
Rank: Wiz
Rating: 81%, 43 votes
Power unit is broken. Google "xbox technical error" and read the details about the industries most underreported engineering malfunction since the failure rate of heating lamps!
Billy D
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #19
posted on Jul 20, 2009
Somewhat Helpful)
jwstultz3
Rank: Apprentice
Rating: 80%, 5 votes
my xbox' indicator light on the brick is flashing orange. and it wont turn on. wut should i do?
Was this helpful?
Yes
No
Solution #20
posted on May 19, 2009
Somewhat Helpful)
alexnumber5
Rank: Apprentice
Rating: 79%, 7 votes
put your legs over the xbox so you share your heat with it then move the power cable around and keep pressing the power button trust me i just did it then
Was this helpful?
Yes
No
Solution #21
posted on Sep 03, 2009
Somewhat Helpful)
arale
Rank: Master
Rating: 78%, 25 votes
Try this link . . . www.microsoft.com/Xbox360Console
To find your best solution.
9
Was this helpful?
Yes
No
Solution #22
posted on Aug 04, 2009
Somewhat Helpful)
TheMan2009
Rank: Apprentice
Rating: 75%, 2 votes
My Xbox 360 power supply light is orange/yellow and it wont power up any ides whats wrong with it
Was this helpful?
Yes
No
Solution #23
Somewhat Helpful)
WWWTHERESANT
Rank: Apprentice
MY XBOX 360 WAS WORKING LAST NIGHT , I WENT TO TURN IT ON THE CONSOLE WONT COME ON OR NO LIGHTS ON. IT SAYS ITS ON STANDBY
Was this helpful?
Yes
No
Solution #24
posted on Nov 16, 2009
Not Rated)
blah1234
Rank: Apprentice
Rating: 0%, 0 votes
that same thing happened to me yesterday. I took alll the cords out. blew in them and the back of the xbox. go figure. it started working.
Was this helpful?
Yes
No
Solution #25
posted on Nov 07, 2009
Not Rated)
v-stily
Rank: Apprentice
Rating: 0%, 0 votes
my xbox stopped working it didnt turn on, i took it a part put thermal grease on all of the processors in the back of the other mother bored and in front under the hit sinks. after that it started to work but first i had to take care of the three red light problem.
Was this helpful?
Yes
No
Solution #26
posted on Oct 22, 2009
Not Rated)
karl851
Rank: Apprentice
Rating: 0%, 0 votes
i was playing on my xbox and everything was fine and then the next day i was going to go on it and when i pressed power nothing happened. the light on the power box is orange and ive tryed a differant cable but still nothing has any one any ideas on what i should do
Was this helpful?
Yes
No
Popular Solutions for Microsoft Xbox 360 Console
Questions and Unsolved Problems for Microsoft Xbox 360 Console
Do you recommend Microsoft Xbox 360 Console?
Answer
Answer
my xbox 360 has one red light. how can i fix this
Answer
when unplugged and then replugged in the console will not turn on but the fan runs constantly... (More)
Answer
My xbox won't read disks, nothing is wrong with the disk. But recently, i had to overheat my xbox to... (More)
Answer
i unplugged the xbox, turned it on and it wont start up. the power plug has an orange lite on
Answer
No video or audio, bought a new AV cable still doesn't work
113 Other Users Have The Same Problem - Continued
Comment by Guest, posted on May 16, 2009
i have the same problem the 369 wont turn on after i had turned it off threw the power supply
Comment by Guest, posted on May 08, 2009
I hav tha same muthafukin probelm tha xbox iz not turning on and i jus got a brand new *** game for fuckin nonthing **** microsoft all they wanna do iz steal ur fuckin money for a ******** *** system
Comment by Guest, posted on May 04, 2009
my xbox was working earlier today then i went out for about 2 hours and when i got bak and tried it again it wouldnt turn on
power died last night while the xbox 360 was on and now i tried to turn it on today and it wont turn on
Comment by Guest, posted on Apr 26, 2009
Actually I found if you put the power supply box in the freezer for about 8 hours for some reasons it fixes the problem. I dont know why but I guess it's like rubbing 2 batteries together or moistening the tips.
Comment by Red Bulit 20, posted on Apr 23, 2009
my big box is red
Comment by Guest, posted on Apr 23, 2009
my x box 360 wont get audio or video how do i solv this?????
Comment by jorgeherrera, posted on Apr 21, 2009
my xbox does not turn on but the power supply does
Comment by blade49fan, posted on Apr 21, 2009
i plug it in i turn it on it dosent work the power box turns yellow when i turn it on it turns red and it won't turn on.
Comment by Guest, posted on Apr 21, 2009
my power box turn yellow then when i turn it on it turn it self off and the power box turns red and won't turn on
Comment by jay c 201, posted on Apr 20, 2009
my power brick is yellow but the second i insert the wire into the xbox it turns red plz help
Comment by Guest, posted on Apr 20, 2009
3 xbox 360 1 works one sent for repair came back and now i have 1 xbox and 2 pieces of **** should have spent the money on another ps3
Comment by speedyporter, posted on Apr 18, 2009
It was fine last night I went to play it today and it just won't turn on. Spent an hour and a half unplugging everything replugging it making sure everything was in properly and nothing zilch diddly squat.
Comment by Guest, posted on Apr 18, 2009
i turned it on it went on and then it shut off.
i was just about to play halo 3
mine didnt start ether this sucks and its double exp weekend for call of duty world at war
Comment by Guest, posted on Apr 17, 2009
I have done everything that the xbox tells me to do but it just wont turn on
Comment by Guest, posted on Apr 15, 2009
it wont turn and everything is plugged up.But the bricks light is orange.
my xbox wont turn on.it was workin fine then we stopped play and a little while later it didnt turn on.
Comment by Guest, posted on Apr 11, 2009
Mine does the same thing it has everything hooked up and all the stuff hoked plugged in and it won't show anything on the screen and it keeps blinking red HELP!! (Worst spring break ever)!!!
Comment by Guest, posted on Apr 10, 2009
MY will on turn on either!  THIS IS MY WORST SPRING BREAK EVER!
Comment by jake4111, posted on Apr 08, 2009
my xbox 360 wont turn on i haved tryed for 2 days
Comment by Guest, posted on Apr 06, 2009
My xbox 360 is pluged in and wont start or even turn on..? ive tryied moving it and even letting it cool down by a fan...what do do?
Comment by Guest, posted on Apr 03, 2009
my 360 will not turn on anymore
minds will not turn on at all
My xbox won't turn on. if i try to turn it on by the xbox it does nothing. if i use the controler to turn it on the controler blinks and it isn't the cords.
Comment by blongaze187, posted on Mar 29, 2009
My xbox 360 won't turn on. The power cord is lit up. Everything is plugged in tightly. What do I do?
Comment by Guest, posted on Mar 29, 2009
my x-box 360 will not turn on
Comment by hayden2122, posted on Mar 26, 2009
i tried to turn it on but it does f***** nothin
Comment by Guest, posted on Mar 19, 2009
saME
Comment by Guest, posted on Mar 18, 2009
Mine does the same thing. I was playing it last night and when i woke up it wouldn't turn on. I just want to throw it out the window right now. ( I live in an apartment on the 6th floor )
Comment by Guest, posted on Mar 14, 2009
My xbox won't turn on as well...What the F*** is wrong with it. Had it for almost 2 yrs.
Comment by Guest, posted on Mar 11, 2009
My Xbox 360 won't even respond, I press the button and it doesn't even turn on, no matter what I do, and don't say it's the ******* cords or whatever, it's not.
Comment by robbie gula, posted on Mar 08, 2009
my x box will not power up---yellow light showing up on power supply
Comment by Guest, posted on Mar 07, 2009
"My xbox 360 won't even start up/turn on" problem, and notify you when a new solution is offered.
Comment by Guest, posted on Mar 06, 2009
my Xbox 360 wont turn on if I press on it doesnt do any thing
Comment by Guest, posted on Mar 05, 2009
it worked fine all the time then the light turned orange & stopped coming on
My xbox 360 is plugged in, the light at the box midway up the power cord is yellow, and the unit will not power on.
Comment by Guest, posted on Mar 03, 2009
My brother said i was addicted so he took the power cord and so i put it in and it worked for a minute then i heared a pop and it shut off. :-(
Comment by Guest, posted on Mar 02, 2009
i was playing the original fable game on my 360 on my tv upstairs , so i turned my xbox 360 off and took it to the downstairs tv, i plugged everything in right, but it won't turn on
i was fine until i started downloading file share maps on halo 3. then it just kept shutting off. i thought ok let it rest. next day i come home and it wont turn on!!!
Comment by Guest, posted on Feb 27, 2009
My sis and I was just playn halo 3 wit these guys who said girls aren't good. So we beat them and then got off. Like and hour later we decide to get back on now it wont even cut on. total bs
Comment by sikes492, posted on Feb 23, 2009
My son played Xbox all Friday night with no problems. Now, a day later it won't boot up. It'll turn on but it won't even show the Xbox logo. I've had the overheating problems in the past, but got that fixed. This is so frustrating!! I just want to play the stupid thing.
Comment by Guest, posted on Feb 22, 2009
my xbox 360 wont even turn on and the disc place wont open
Comment by Guest, posted on Feb 19, 2009
uhmm.. my 360 is plugged in and everything, but it won't turn on. My little bro leaned on it, could that be the problem? What do I do?
Comment by Guest, posted on Feb 14, 2009
i have the same problem exept my power box is lit up red ???????
Comment by Guest, posted on Feb 13, 2009
i fell you bro i got the rrod and i tryed 2 fix it and when i finished fixing it the system didnt even turn on harse man isnt it
(lll) (lll)
lllll lllll
lllll lllllll llllllll lllll
lllllll(llllll)(llllll)lllllll llllllll ROCK ON MAN
llllllllllllllllllllllllllllllllllll) (WE SILANCE FOR NO ONE DONT
llllllllllllllllllllllllllll LET THE MAN PUT YOU DOWN)
Comment by Guest, posted on Jan 25, 2009
mine i was playing fine then was walking down stairs with lil sis holiding the power box and she dropped it and then it didnt work..:(
and im getting really told off
Comment by meggerz20, posted on Jan 19, 2009
i bought my xbox 360 arcade version TWO days ago, and it wont turn on! ive only played it for about 3 hours in these two days... could i of gotten a defective machine?
Comment by noelwefour, posted on Jan 16, 2009
I was playing guitar hero world tour and then i turn it off and then i tried to turn it back on and it didnt work. i was like wtf!!!
Comment by Guest, posted on Jan 15, 2009
my xbox wont turn on its plugged in well but it jsut wotn turn on
Comment by Jordanhh, posted on Jan 15, 2009
its not the red lights i have. its when i turn my xbox360 on, And it don't really turn on it just stays blank. and it wont even power up the plugs are plugged in and i tried turning on by controller and it didn't work, and it still didn't work, the big power thing for it is the lite is on orange and it wont even power? wtf can u help me?
Comment by Guest, posted on Jan 10, 2009
my x box 360 just wont load try's then frezes
Comment by kola rank, posted on Jan 03, 2009
the x box 360 game console goes on standby any time it is turned on
what do i have to do
Comment by Guest, posted on Jan 03, 2009
Yo when my 360 came bak from repair the said they gave me a replacement. But wen I hooked it up that piece of **** won't even turn on.
Comment by Guest, posted on Jan 01, 2009
Same thing happened to me. I was playing halo3 then I turned it off and it didn't turn on again.
Comment by Guest, posted on Dec 27, 2008
whan i cut my xbox on the green light turns red and it wont turn on
Comment by ryker95, posted on Dec 27, 2008
my 360 had the red ring so i researched to get it fixed and i found the towl trick so i tried it and it worked for bout a day and it crashed agin so i tried it one more time and it worked i had to go to my uncles house so i tuned it off and when i got back i turned it on and it started to freeeze and then it just stoped working im so upset and i dont wont to pay a 100 more dollers agin to get it fixed.
all I get is yellow light on power supply and when I push the power button nothing happens
Comment by angelro, posted on Dec 27, 2008
does your xbox turn on or you just dont see anything on the screen?
Comment by Guest, posted on Dec 26, 2008
my xbox 360 was working fine yesterday but i tried to use it today but it will not turn on
Comment by morrisonryan, posted on Dec 25, 2008
My power cord is on but the 360 won't power up? Is there a fuse or can something else be wrong?
Comment by td31g, posted on Dec 25, 2008
i was playing madden 08. i plugged a controller into the usb, and the xbox turned off. now the xbox won't even turn on.
Comment by guitar guy36, posted on Dec 24, 2008
Alright so I was playing my xbox 360 this one time (guitar Hero 3 oh yeah!) and then the red ring came up and I tried turning it on a few times and it worked for a few days and now it won't turn on. It hasn't since April
Comment by bry742005, posted on Dec 24, 2008
Its 10:25 Christmas eve and my xbox wont start up as well. I turned on the xbox but im stuck at home becuase I was in a motorcycle accident 2 months wow how crappy is this.
Comment by Guest, posted on Dec 24, 2008
i have already commented telling everyone about microsofts horrific behaviour my xbox wont turn on on christmas eve . it got to the door and ther my xbox was just being fixed from the red light i try to play it it wont turn on WTF is happening microsoft this has to be the worst console ever i am fuming bill gates u P U F F sorrt this SH*T OUT . ther is one thing i have notice after reading numerous comments ,, people have said they have unplugged everything on the xbox and moved it somewer else i think this may oh happend to mine when it got shipped off this is my key coincidence . SOLOUTION BUY A PS3 . XBOX IS A PILE OF W_A_N_K..!!!!!!!!!!
Comment by Guest, posted on Dec 21, 2008
I unplugged my 360 to put it in my car and it was out in the cold for like a day and 1/2 and when i plugged it back in it wont work. Why the **** not!!!! it wont even turn on.
Comment by izaacstp, posted on Dec 20, 2008
woke turned on my xbox has three red light's i'd like to take a hammer to it. I havent even owend for six months. my super nintendo still works!!!
Comment by Guest, posted on Dec 18, 2008
after fixing my x bo
Comment by prince jamal, posted on Dec 13, 2008
my 360 was working perfectly yesterday now it wont turn on
Comment by Guest, posted on Dec 05, 2008
my 360 will not turn on, but it sounds like it is on (the fan is going)
Comment by Guest, posted on Dec 02, 2008
my xbox 360 wont start up and shows a red ring instead of a green ring
Comment by Guest, posted on Dec 01, 2008
Comment by macs jik, posted on Nov 28, 2008
my 360 worked fine this morning and now it wont even turn on
Comment by samfordcjs, posted on Nov 26, 2008
My xbox worked yesterday and now it want even turn on.
Comment by sxroc07, posted on Nov 17, 2008
gears 2 came out i played it for 2 weeks my xbox dies one month after the warranty....nuff said right?
Comment by Guest, posted on Nov 16, 2008
i was at my friends house & when I got home my xbox wouldnt turn on & it still wont
Comment by Guest, posted on Nov 14, 2008
this sux
Comment by 213jam, posted on Oct 28, 2008
i have the same problem i was just playing on my xbox 360 upstairs and i bring it downstairs and it wont even turn on :( some one help please
Comment by nearnotesan, posted on Oct 26, 2008
my xbox 360 console isnt turning on at all the adapter is blinking orange on and off and i have no idea how to fix it PLZ HELP ME!! ='(
Comment by mitchell L, posted on Oct 06, 2008
When i plug it in at switch the mains on there is not even a light
Comment by integra3585, posted on Sep 14, 2008
Xbox was running fine one day. Turned it on today and it sounds like its runing but nothing is showing. All the cords are fine.
Comment by Guest, posted on Sep 06, 2008
wont turn on :'{
Comment by Guest, posted on Aug 30, 2008
powered off won't turn on??? wtf
Comment by Guest, posted on Aug 29, 2008
my xbox wont turn on theres not even a light on on the transformer
Comment by Guest, posted on Aug 11, 2008
i went to turn my xbox 360 on the other day from it being over my friends and it will not turn on!
Comment by grouchygus, posted on Jul 29, 2008
My Xbox 360 was unplugged while playing, and now it won't power up. The light on the brick is yellow.
Comment by Guest, posted on Jul 07, 2008
I was playin HAlo 3 when my xbox turn off i walked over there 2 turn it on And it didnt ive tried it on different outlet and cords UMHH
Comment by skaterxchick, posted on Jul 06, 2008
i was playing the halo 3 like a month or 2 after i get my 360 and i turn it off when i plug everything back up and click the middle button it does nothing i try everyting i can find on the computer like checking the outlet, reconnecting the cords ect. the thing wont turn on at all but the power strip stays yellow
Comment by tyisamazing, posted on Jul 03, 2008
my xbox wont turn on and evry thing is pluged in but the light is orange
Comment by jizz6000, posted on Jun 24, 2008
i tyied to turn my xbox on wen i got home but the brick is yellow. i dont know what to do
Comment by baybidawl03, posted on Jun 22, 2008
my xbox 360 will not turn on and when I try to turn it on it blinks red and the power supply cord stays yellow
Comment by pimpvicous, posted on Jun 09, 2008
i have everything plugged in barely bought two new games i get home and my xbox just won't turn on and the light on the brick stays yellow so i know its getting power what do i do!
Comment by gameRoyale, posted on Jun 05, 2008
my xbox wont start. is there a way to fix it.
Comment by Gabez_R, posted on May 31, 2008
My powerbricks light stays ion yellow and the box JUST WONT START!
Comment by Fearless Jim, posted on May 27, 2008
yeah ma fukin xbox 360 won't even fukin turn on
Comment by Guest, posted on May 19, 2008
min has the yellow light on the brick but wont turn on
Comment by fizzler, posted on May 17, 2008
my 360 hard drive dont work it wont let me get to the dashboard
Comment by nuniie, posted on May 05, 2008
it wont power on
Comment by Guest, posted on Apr 28, 2008
xbox 360 won/t powerup power brick check out
Comment by Guest, posted on Apr 08, 2008
MY PROBLEMS THE SAME WHAT DO WE DO
Comment by Guest, posted on Mar 03, 2008
the same thing happens it just made a massive loud fan noise then cut out!
Comment by Guest, posted on Jan 02, 2008
ya my xbox 360 wont turn on ether. ive check all the wires, all the outlits but it still wont run. the light on the power brick thing is lit up but it still doesnt turn on.
Comment by Midnight Q, posted on Dec 28, 2007
my wont turn on anymore either and it blows. i played for like 3 hours walked away and now it wont turn on. i bought the freakin thing 2day so this sucks. the stupid power brick thingy has an orange light, which means its on standby. SO HOW THE HECK DO I GET IT OFF STANDBY AND WHY IS IT ON IT!!!!!!!!!!!!!!!!!!!!!
stupid microsoft
Comment by Guest, posted on Dec 11, 2007
everything seems fine all the plugs are in and it just wont start i think one of the wires might be messed up though (im not sure)
Comment by Guest, posted on Dec 02, 2007
Same problem, the xbox 360 won't turn on. My power cord registers that it's getting power, but the thing won't turn on.
Comment by GOFUCKURSELF, posted on Nov 17, 2007
Goddamnit i have the exact same problem... but the thing is that my power cord thing whateverthefuck u call it is messed up!! AND I WANNA PLAY GODDAMNIT!
so u better come to my fuckin house and fix my fuckin goddamn xbox or ill shove it up yo ass!
you dig?
Comment by Guest, posted on Nov 10, 2007
Xbox 360 won't turn on
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Microsoft Xbox 360 Console:
Top Video Game Console Experts
Rank: Guru Guru
Solutions: 384
Experience: From previous experience, research, schooling, and studying the work.
Ask Me
Find more Video Game Console Experts
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
