Question about Measuring Tools & Sensors
Corghi em89 how do i recalibrate the corghi
How can I recalibrate my 2001 deville
recalibrate what , PCM/ECM ? engine computer . Disconnect battery cables and touch them together for 10 min.
Jan 23, 2017 | 2001 Cadillac DeVille
What's your question?wheel balancer CORGHI EM 73 breaking fuse1 after replacement.solution.
if this a power in fuse to electric motor in the balancer then It may be a start/ run capacitor for the electric motor that has failed
have it checked and tested by an accredited electrician
Aug 28, 2015 | Cars & Trucks
What's your question?CO RGHI EM73 psu breaking fuse1(3.5A)after replcement.
Hi Kevin!
You must have the power supply inside burned... probably the power transistor.. new power supply or repair!
If you donĀ“t have someone to do it, please check... http://www.ebay.com/itm/Corghi-8040-Wheel-Bal-Rebuilt-Power-Board-454218-/111759511065?hash=item1a0562ce19&item=111759511065&vxp=mtr
BR.
Aug 28, 2015 | Vehicle Parts & Accessories
How do I recalibrate alarm after replacing battery in fob?
NO..........What is it you wish to recalibrate?. If the bike is 2007 plus there is no recal needed.If you remove the battery without removing the MAXI fuse the alarm will have problems
Apr 04, 2010 | 2005 Harley Davidson FLSTF - FLSTFI Fat...
Oven temp low. recalibrated up 35 degrees, 375
no you need to still recalibrate the unit if your using the baking style thermo they are famous for being off 75 degrees
Aug 09, 2009 | Kitchen Ranges
Does not respond to stylus
Try recalibrating the touch screen. Devices with touch screens need to be recalibrated in order to respond properly. The greater the use, the more often recalibration is necessary. I recalibrate my phone once a week. I hope this helps.
May 22, 2009 | Palm Treo 755p Smartphone
Touch screen not working
Try recalibrating the touch feature. Touch screen devices need to be recalibrated ever so often. The more it is used, the more often recalibration should be done. I recalibrate my LG VU once a week. Hope this helps.
May 22, 2009 | LG KU990 Viewty
Measuring Tools & Sensors Logo
37 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
