Question about Kohler K-1715 Fast Response 22 Kw Steam Generator
I have a problem with the control board of my Kohler k-1715 steam generator. Where I can repair it or get a new one?
2 Suggested Answers
SOURCE: I have a Kohler K-7 steam generator/shower and
There is a float valve interior of the steam generator that supplies water to the generator unit. There are no parts available for that unit, and Kohler was useless re: repair. I have the same unit and mine is doing the same thing. I took it apart and there is a washer worth about a nickel that is inside the unit. I flipped the washer over in mine and it worked for about a week....then back to the same problem.
Posted on Jan 06, 2010
Why does my generator start constantly?
if a lightning strike was anyplace close (30 yds) it's a safe bet your gonna have to replace the control board in generator also Id have a qualifyed tech ck out your auto transfer switch ,I bet he''ll find that you fried your coils on your switch too , do that before changing control board cus if ya hook up a new one to a bad coil ya just bought two of them
May 24, 2014 | Kohler Electrical Supplies
First start up
Try disconencting the remote start wires between the transfer switch and the generator, if ot still does it you have a bad control board. If it stops, then check the transfer switch for correct wiring of utility and generator power wires, also check with an ohm meter if the run contacts in the transfer switch are closed, that would indicate loss of sensing, or bad board
Jul 19, 2013 | Kohler Electrical Supplies
12 RES - Control Panel Dead With New Battery
If it won't start in manual, you have a short and/or a bad control board. Make sure battery polarity is correct, did you disconnect battery charger before removing old battery? If not charger can push DC volts over 20V and can damage control board.
May 26, 2013 | Kohler Electrical Supplies
I have a Kohler Confidant 5, model 5ckm21 generator in my RV, serial # 326827, spec# 101228. It worked fine one evening and the next day it wouldnt stay started unless the start button stays depresse
no 14vac coming from generator to control board.--cause can be regulator board on end of generator---dirty brushes or worn out brushes==b1 and b2 winding open that outputs the 14vac--my problem was blown regulator board
Dec 05, 2012 | Kohler Electrical Supplies
Will not issue a start signal all of a sudden. How to test to see if it is the switch or the gen. panel
I have a Kohler 12RESM1 whole-house generator with a 200AMP RDT, MPAC 500 Automatic transfer switch (ATS) in my home. The system was installed in 2006 and has been working great since. Several weeks ago I began noticing that the weekly tests weren't occurring on schedule and that the generator would initiate a starting crank for a couple seconds several time a day. The false starts began occurring more frequently as time progressed. (BE very careful!! You will be killed if you are not careful!! ) In order to isolate the trouble between the ATS and the generator, I disconnected the 2 start circuit wires from the ATS controller (2 wires on green connector). The problem stopped, which led me to believe the problem was the ATS controller board. The controller board in my ATS is a GM35950. After removing the board (BE very careful!! You will be killed if you are not careful!! ) and doing a little troubleshooting, I determined the trouble was the set of .47F 5V super-capacitors. These are the 2 black oval-shaped cans behind the relays that appear hot-glued together. I ordered 2 new caps from Digi-key (approx. $4.00 ea). The P/N is PB-5R0V474-R. Replacing the supercaps cured the problem. Don't be fooled, these capacitors are .47 farads, not .47 microfarads, thus the reason they're called Supercaps. They function similar to a battery in this application. Oh by the way, I ordered a couple extra Caps. They have a 1000 hour life expectancy, so I suspect I'll need to replace them again in 6-7 years. Good Luck, I wouldn't advise attempting this job unless you have the proper soldering equipment and are experienced with electronic repair. There's a company that will repair the board for $170. Try googling "Kohler GM35950 repair".
Jan 30, 2011 | Kohler 200-Amp Automatic Transfer Switch...
Error 5
-error 5 is caused by the back pressure of the steam head if water supply to the generator is sufficient and the steam output pipe to the steam head is plumbed according to the manual.
-Kohler recommends to modify the steam head to remove the wax motor, spring and snap ring in the housing. Call Kohler for instructions.
Jan 15, 2011 | Vibrant KOHLER Steam generator control kit...
I have a Kohler K-7 steam generator/shower and after using it just fine, water now just pours out of the steam outlet - even if the unit is turned off at the control head. I have had to close the inlet...
Dec 05, 2009 | Kohler K-1698-G Brushed Chrome Tandem...
The kohler steam unit keeps shutting down prematurely
Since I don't have your model number for this, I am going to attempt an answer for you. Yes, there could be a filter but not always. Sometimes, the sensor on these units can become stuck closed and is sending a false error. Does the unit seem to be working? If it is, then it probably is a false signal. If not, the there could be debris that has gotten into the water lines. Either way, if the unit is new, then it will be under some sort of warranty. I would contact either Kohler or an authorized service rep.
Apr 05, 2009 | Home
Kohler K-1715 Fast Response 22 Kw Steam Generator Logo
21 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
