Question about Refrigerators
Whirlpool wbm 569/1
Compressor not working
    New Friend:
  • 156 Answers
Did you give the Refrigerator 24 hours? Did you lay it on its side shortly before plugging it in? Does your wall outlet have power or maybe the circuit breaker is popped? Otherwise you probably need a replacement
Posted on Oct 22, 2013
Hi, I have a quite old Whirlpool refrigerator model no: WBM 377. I want to find the replacement for top door hinge (P/N: 481241719454). Can anyone direct me where to go to search for the spare part?
Try lookingwhirlpool on the whirlpool web site or searching the web for whirlpool spare parts, Got loads come up straight away but not sure what country you are in so uk ones may not be suitable for you
Jan 03, 2016 | Whirlpool Refrigerators
Whirlpool wbm 48
That is a short on gas problem but make sure that the fan is running and check the settings on the inside of the unit so that you can have a circulation around the whole unit. If all this is good then Check your warranty or get someone to check for a gas leak. Get fixed and charge it with the write amount of gas and your problem will be solved.
Good luck
Will
Jul 28, 2014 | Whirlpool Refrigerators
Refrigerator whirlpool wbm 501
Problem is defrost thermostat, defrost heating element or defrost timer and or low gas in the system. Remove the back panel in the freezer and look to see if the evaporator coils are frozen solid with ice. If so the problem is no defrost cycle. If no ice then the unit is low on gas and it has a leak. If the refrigerator is old... recycle it and go buy a new refrigerator from Whirlpool.
Feb 07, 2014 | Refrigerators
What is the three digit code for DISH on a Sylvania LC195SLX
Hi, my name is Cheri Torres and I work with DISH Network Customer service. We have a few different codes for each of our different models of remotes. I will list here for you the best codes for each of our more popular models of remotes and the instructions for addressing the remote to the TV. I hope this information helps and if you have any other questions please let me know!
Remotes models Remote codes
3.0, 3.1, 3.2, 3.4 IR remotes - codes 632, 569, 566, 671, 733, 515, 568, 764.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 632, 569, 566, 536, 733, 672, 660.
4.0 and 4.4 IR/UHF remotes - codes 733, 569, 566, 632, 764, 664.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 733, 569, 566, 654, 672, 632, 764.
20.0 IR and 21.0 IR/UHF remotes - codes 733, 672, 777, 566, 764, 527.
Instructions for addressing the remote to the TV
1. Press and hold down the TV mode button until all the mode buttons light up red.
2. Enter the 3 digit code using the keypad.
3. Press the pound(#) button once.
4. Test the functionality of the TV.
Oct 17, 2011 | Sylvania LC195SLX LCD TV
I have a Whirlpool refrigerator Model WBM 35 ix that is about 5yr old . The problem i am having is with the freezer. (the frige area stays cold) Some times the freezer will work and freeze food but i...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 23, 2011 | Kitchen Ranges
Whirlpool wbm 39 fridge freezer. Has not been opened for a day or two and now trips the power supply every time you plug it in, it does this after about 1 min
TRY TO USE A DIFFERENT POWER SUPPLY. IF IT WORKS YOU GET AN OVERLOAD ON THE OTHER CIRCUIT.
IF IT DID THE SAMETHING THE UNIT HAS A SHORT
YOU NEED TO DO AN EYE AND MANUAL CHECK.
UNPLUG IT GO TO TH MOTOR COMPARMENT TURN EVRYTHING MANUALY TO SEE IF THEY TURN NORMALY . IF ANYTHING JAMB THAT SHOULD BE THE PROBLEM
Oct 24, 2010 | Refrigerators
TRY TO USE A DIFFERENT POWER SUPPY. IF ITY WORKS. THERE IS AN OVERLOAD IN THAT CIRCUIT NEED TO LOOK FOR.
IF IT DID THE SAME. THER IS A SHORT ON THE SYSTEM.
UNPUG IT GO TO THE COMPRESSOR COMPARTEMENT
DO AN EYES AND MANUAL CHECK. TURN EVERY SINGLE THING THAT SHOUD BE TURN FREELLY BY HAND.
IF YOU SEE ANYONE OF THEM JAMB THAT SHOULD BE THE PROBLEM
I have a Whirlpool Refridgerator model WBM39MS. It stopped cooling and I had it repaired. The Repairman replaced the electronic control box. Repairer claims that the compressor is working. It now seems...
Hi Lollipop, partially working fridge? A fridge either works or not, cold air is made in freezer then distributed to fridge via a vent. In your case WBM Series fridge, top mount freezer blows air down a vent (back centre of chiller compartment). A common fault with the WBM Series is both the PCB and Interface Panel (PCB beside compressor back of fridge, Interface is display panel front of fridge).
So if freezer is cold and fridge not, try a fan motor. If compressor doesn't work either comp is faulty or PCB has blown(has a burning smell).. Hope this helps you and maybe many other ppl.
Jan 21, 2010 | Refrigerators
Refrigerators Logo
177 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
