Question about Kenmore Intuition Canister Vacuum Cleaner, Blue
Kenmore intuition cross over
Model 116.58015700 Worked great until it quite. I belive the "reset" button is busted, not because I have overused it. Any suggestions?
Beater bar wont spin on kenmore intuition upright bagged vacuum
Start with a new belt if your model has one.
Dec 27, 2016 | Kenmore Vacuums
Kenmore intuition non-turning beater bars, beltless model
When you press the reset button does the vac motor start but the bars do not turn? If so the drive belt may be broken that drives the bars. If so you will have to replace the belt. If the motor does not start it is possible the belt could be jammed or the motor seized or burnt out. If it's not very old check to see if it's still under guarantee.
Dec 07, 2014 | Kenmore Vacuums
Quit running I checked all electric and it has electric running to it reset button won't reset it it just doesn't run
a newer model unit (withing 5-7 years) has a deadman switch inside. This means that if the filter is out of the machine or not in properly it will not start the motor until the filter is back in its proper place.
If it is an older model, what you can test is the low voltage lines coming into the unit. Where they go into the unit (usually red or black circular with the two "phone wires"), take a screwdriver and touch the two wires with the screwdriver. What you are looking for at this moment is either a "click" or the motor will start.
If the motor starts, great, now you have to trace the wiring and see where it went bad.
If the unit clicks, its possible it is your motor.
Either way, good luck.
Mark
Nov 11, 2010 | Electrolux Central Vacuum
Is there an operating manual on the web for a Kenmore Intuition vacuum cleaner
Hi, here is a link to a site that holds the manuals, but you will need the model number of your cleaner. Hope it helps! Please rate me. :) http://www.managemylife.com/mmh/owner_manuals/search/product_type.Vacuum,%20Upright?query=Kenmore
Jul 17, 2010 | Kenmore Vacuums
The brush is not rotating
Try pushing the reset button with a pen or paper clip. If that doesn't work, the motor may need to replaced. If the reset button is stuck, I don't know how to fix it - mine has the same problem.
Feb 21, 2010 | Kenmore 31913 Progressive Direct Drive...
Kenmore whispertone model 11620412003
I am getting suction to the power mate, but the mate doesn't
work. The belt seem fine, but the light and beater doesen.t
go on. Tried the reset - no result. Thanks
Dec 29, 2007 | Vacuums
Kenmore Intuition Canister Vacuum Cleaner, Blue Logo
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
