Question about Acer Computers & Internet
Acer m1202 will not power up. On light does not come on
Acer aspire m1202 will not boot but fans run
Remove all media, DVDs, CDs, USBs, unplug from AC, remove battery, leave battery out, plug into AC, reboot. If that fails, Do a system restore/recovery. Do you have a repair disk? You didn't supply your OS? If that fails, remove HDD, test, replace is necessary.
Dec 03, 2012 | Computers & Internet
Can't connect my aspire m1202 to internet
I need more information to assist you.
Do you connect to the Internet using a LAN cacle to a modem and or router?
Do you have a wireless router, what is the make and model.?
Do you have an Internet service provider.
What error messages do you get.
Mar 30, 2012 | Acer Computers & Internet
Acer aspire m1202. turns on but no bio view just runs the fans and there isnt any sort of beep code either. just runs and runs nothing happens. oh and you cant turn it off via power button you gotta unplug...
t f doesn't open
* remove the fan/blower n the processor and check if there's still a heat sink paste on it. (most part of center metal attach),then clean the sorroundings of the process...this s due to an overheat that's why the blower or fan might sometimes stuck up at the pc stop working.
* detach each memory and try to clean the slots and put it back properly.
* check the power supply,might getting open voltage and needs replacement.
hope t helps...
Jun 06, 2011 | Computers & Internet
I have an Acer M1202 that I performed a Windows flash upgrade. For whatever reason it did not complete i guess. The window closed and I tried to reflash it but it would work. When i rebooted the system...
yes there is , **** its not what you sould do.....u should try to flash again using a floppy drive in dos.
if u dont know how to do that, google for it, its not wise to flash in windows ;)
Apr 30, 2010 | Acer Aspire M1201 Athlon X2 320 Gb PC...
I shut down my desktop properly that night.i woke
First use the following steps:
Turn off the system and disconnect power cables.
Press and hold the power button for 30 seconds
Reconnect power cables and try to turn it on.
If it remains same, the next step will be to turn off the system,
Disconnect power cables
Open the case and re-seat memory modules.
If you have more than one modules installed, test the system with a single module at a time.
Thanks
Feb 19, 2010 | Acer Computers & Internet
Replace the Vista Home Premium with XP on ASPIRE M1202
Your best option is to upgrade to Windows 7. It is free for (I believe all) Vista users, and you can run programs in XP compatibility mode.
Dec 04, 2009 | Acer Computers & Internet
We are getting a No Signal on our monitor,
it should be motherboard problem.
try to check it nearby service centers
are you able to hear any beep sounds
pp
Nov 21, 2009 | Acer Aspire L100 PC Desktop
I was told that could get 7 setup free, because i
Here's a link for you to order your free upgrade to Windows 7 at Acer...
http://www.acer.com/windows7upgrade/
Oct 31, 2009 | Computers & Internet
Computers & Internet Logo
15 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
