Question about Cobra DC5600 Digital Camera
I have a traveller DC-XZ6 camera..when I turn it on lens protection appears on the screen and then it switches itself off.
I have a canon t3i. The menu doesn't turn on when you turn on the camera.
The menu doesn't display when you switch on. You should get the settings screen appear. Once powered up just hit the MENU button
Mar 02, 2015 | Canon EOS Rebel T3i 600D SLR Digital...
The lens will not extend
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
May 29, 2009 | Kodak EasyShare Z612 Digital Camera
Lens will not retract and camera will not work
When the lens will not retract and camera is not functional (no picture on display, and does not shoot) , and you already tried replacing batteries with a new fresh set (ensure please) , and then restarting camera with no memory card inside, then camera is faulty.
Try an easy fix by pushing gently the lens (do not force them, just help them) while you turn off camera at same time. Try also switching the mode selector.
If still no luck , then the camera must be disassembled to fix the problem.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Dec 08, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Casio Exilim EX-S880 won't turn on, lens clicks
Do you have a mem card installed? If so what size? Make sure it is the right size for your camera. Also make sure the battery is fully charged. The lens clicking twice makes me believe that there was some kind of damage done to the lens like maybe accident powering on when it wasn't supposed to like in a pocket or something. You may have to send it in. Expecially if it says "lens error".
Jun 28, 2008 | Casio Exilim EX-Z55 Digital Camera
Fawabi
0013 indicates that your camera has a hardware (related to Lens) defect.When dirt gets into the lens mechanism the lens wont retract properly.. You wont believe what i have suggested for a similar problem and it worked! Its a similar lens stuck error..
http://www.fixya.com/support/t240817-camera_error_e45
Mar 21, 2008 | Nikon Coolpix 3200 Digital Camera
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Sep 03, 2007 | Kyocera Finecam S4 Digital Camera
Camera freezes in any picture taking mode
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. you need professional service to fix it.
Dec 28, 2006 | Gateway DC-T50 Digital Camera
Cobra DC5600 Digital Camera Logo
18 people viewed this question
Top Cobra Cameras Experts
ray gallant
Tom Chichester
Are you a Cobra Camera Expert? Answer questions, earn points and help others
