Question about Euro-Pro Shark 60 - 384
Where can I buy a replacement container + lid (the one at the front of the machine), my lid is broken and wouldn't stay on ):
  • Euro-Pro Master
  • 1,564 Answers
LOL Good luck. Enjoy your boat anchor. I've not ever been able to find anything on any Euro-Pro product.
Posted on Nov 01, 2013
Replacing a damaged top lid from a viking designer se
Yes it is loose in there on the plastic. The pressure from the other side holds it in place. You could install a small screw if you want to make sure it stays in place.
Dec 23, 2013 | Husqvarna Sewing Machines
Bobbin case wont stay in place
the bobbin case may need to be replaced. it wouldn't hurt to have the machine serviced to make sure the hook & hook race are ok
Apr 19, 2012 | Janome Sewing Machines
I have a bernina E65 and it does not move any part ,you hear the motor but the neddle does not work, help? the manual is no help either!!
I assume you have cleaned and oiled the machine as per the owner's manual.I believe this model is belt driven. If so, the belt may have loosened or broken. Replacement is not mentioned in the manual so I feel a tech is needed. My mom's machine used to have a lever that engaged the machine and it wouldn't move with this lever in the up position.
Mar 19, 2012 | Bernina Sewing Machines
I lost the Buttonhole fine-adjustment screw for brother ls2125
I just wanted to share my situation with you. I had the same problem. When I tried to use my Buttonhole fine-adjustment screw, it broke up and fell inside the machine. My husband opened the machine to get the broken parts out (two of them: first one - white-colored plastic broken part of the adjustment screw and a metal, half-moon shaped washer).
I called 1-877-276-8437 (BROTHER), and the person who checked the list of replacement parts said to me that this particular screw was not in the list. So that person gave me the number of the closest service center where I called.
The service person told me that it was no cost to see what was the problem, but to determine how much the solution would cost he needed to see the machine. I asked about the minimal cost of a service; it was $89+ the cost of the parts. It means the minimal cost of the repair (without the price of the replacement part) goes 14 dollars beyond the price of a new machine, which in Amazon.com today 10/2011 is $75 for the same model LS-2125(i).
My solution was to get out the broken part for which my husband unscrewed for me the front plastic shell and took out the two little broken parts. During this procedure, he realized I could use a narrow scissors to make the remaining part of the Buttonhole fine-adjustment screw turn around. This way I can still use my machine with no need of buying a new one.
Sep 07, 2010 | Brother LS-2125 Mechanical Sewing Machine
Hi I have broken the lid on my necchi 270
You will have to contact a Necchi dealer to see if this is available.
To locate your nearest Necchi Dealer us at 1-800-525-9987 ext. 4
Mar 01, 2010 | Necchi Sewing Machines
I don't know how to thread the machine and how to put in the bobbin. I have a White 1410 machine.
I don't have a solution, but I wanted to thank GUEST for the drop of oil solution - I was about to buy a new machine and throw out the one I have ( 3 years old!) because it wouldn't wind up thread on the bobbin. You've saved me money and futher frustration :-)
Jan 06, 2010 | Sewing Machines
A plastic bevel gear has broken and the material
You can get the gears quite easily on ebay, they are standard on all singer machines
Nov 21, 2009 | Singer 5070 Mechanical Sewing Machine
Loose end cap cover.
This actually applies to most of the newer Pfaff machine models:
  1. If the cover will come completely off, look at the inside of it to make sure the bracket that holds it in place is not broken. If it's not broken...
  2. Grab a flashlight
  3. Remove the stitch lid - there are little silver clips at the base of the lid on either side - push the lid either to the left or right against these clips and you'll be able to pop it right off. You will reverse procedure to put it back on. Removing the lid isn't absolutely necessary but does make it easier to see/access screw.
  4. Raise the handle of the machine
  5. Aim your flashlight into the machine behind the left side of the handle... you should be able to see down inside the machine to the set-screw that holds the side cover in place
  6. Check to see what kind of screwdriver you need - either a Phillips head or a Torx Driver. Most of the newer Pfaff models require a Torx Driver (this is a star-shaped screw-driver available at most hardware stores - Size T25 should fit this particular screw)
  7. Slide cover back into place - may need to wiggle it a bit to get the bracket under the screw
  8. Tighten screw & you should be back in business
If the bracket on the inside of the cover is broken, this part will need to be replaced. Pfaff parts are only available through an authorized Pfaff dealer so your local dealer will need to order it for you.
Hope this helps - please don't hesitate to respond if you need further help or clarification.
Happy sewing,
Kim & Linnette
Dec 20, 2007 | PfaFF Tiptronic 2030
Euro-Pro Shark 60 - 384 Logo
27 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
