Question about Microwave Ovens
Ineed a set of motor brushes for model RM 872
Why r 872 blowing 8w ceramic fuse repeatedly
Most microwaves usually use 15 amp fuses and not 8's. If it keeps blowing fuses there is a short circuit somewhere and you would need to track that down to stop your problem. A frequent possibility might be one of the micro switches in the door circuit.
Aug 13, 2014 | Sharp Microwave Ovens
Ineed a manual for a MV1608WW
http://www.searspartsdirect.com/partsdirect/part-model/Goldstar-Parts/Microwave-Parts/user-manuals/manual-downloads/Model-MV1608WW/1366/0123370?modelNumber=MV1608WW&diagramPageId=&documentId=
Sep 04, 2013 | Goldstar MV1608WW 1.6 cu.ft. Over The...
I need my neff h7871 repairing. Who can help
BSH Home Appliance Ltd
0844 872 8999
or you can go to BSH Customer Service website and book engineer online
Mar 05, 2013 | Microwave Ovens
Kitchen Aid Mixer Model KSM5PSGR . I have had this mixer for about 15 years and recently while mixing dough, it started struggling to spin, and at some point stopped spinning. I just turned it on, and it...
it's possible the brushes on the motor are burned out. Are there 2 screw holes on the sides? You should have one on either side that look like a flathead screwdriver would fit in them? If so, inside those chambers are the brushes and springs for your motor. You can try replacing them. You should be able to order replacement brushes based on your model number(found on the bottom of your mixer). Let me know if that helps.
Jun 10, 2011 | Microwave Ovens
According to one of your solutions rergarding a noisy k45 kitchenaid I removed the brushes to examine and upon multiple attempts to reinsert properly - the noisy machine no longer operates to make noise. ...
Hello; Bummer trade off, huh? Ok , here we go.Getting it to run again, then address the noise. The attached drawing shows how the brushes should be installed. The brushes take a set and must be placed back into the same holder and leading edge into rotation, set square on the armature, w/full contactand spring pressure. After Slidingthe brush in place, lift it slightly and let it drop back onto thr srmature. Not much and let the spring set the brush and align .You want to make sure the brush moves smoothly up and down. The part the brushes ride on is called the the commutator. The copper bars. Each is separated by a thin piece of mica. If there is any copper bridging the mic, the motor will be noisy and not run smooth. In this case, use an ice pick to scratch the mica so it's below the copper ba abou, never mind, just run the pick down the mica groove to keep the bars seperated. Put it all together and turn it on. You may have to tap the motor to get it going. Once it gets going let the motor run for about 15 minutes at high speed and 5 minutes at low speed, Good luck and take caution not to get shocked. I'm here so feel free to keep in touch. 909-630-3192. Ned
Apr 16, 2011 | Microwave Ovens
Bosch w/mc will not spin, just fitted new brushes to motor but it still wont turn.control unit seems to be working as will fill and drain but will not spin.
Depending on the model, the control panel has a triac on it. That fails giving the idea that the brushes have failed. BT139 I think from memory. Large transistor style component with three legs.
Jan 04, 2011 | Microwave Ovens
I need operator/ instruction manual for a Welbilt Toaster oven/Broiler with rotisserie and griddle. Model # TB6080
WELBILT APPLIANCE CORP.OF AMERICA P.O. BOX 220709 GREAT NECK, NEW YORK 11021 Write to this address and they should send you a manual for your toaster oven, here is a phone # also1-800-872-1656 Hope this gets to you Heather_s514 From smoothygirl63@yahoo.com
Oct 01, 2010 | Welbilt Microwave Ovens
Microwave sylvania
my microwave plate is broken.the model no is sm81011 ineed that help me
Jan 21, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
