Question about Philips CDR760 CD Player
Philips audio cd recordable rewritable cdr870 I
Philips audio cd recordable rewritable cdr870 I have put a new cd into this player,and can't seem to record anything. The player is connected properly to the amp,the player is set in analog mode,the amp is switched to the recording mode,I start to play music for the player to record,press the record button on the player and nothing happends.even if I plug phono's direct into just the input's on the player nothing happends.surly when you put a new disc in and the player loads it up.i should be able to press record and the unit should set its self to be ready to go.the player play's cd's fine but to record phew. What am I doing wrong?
3 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Philips CD recorder CDR870 not recording
Consumer CD recorders require CD-Audio or CD-Music blank CD's to record.
Posted on May 16, 2009
  • 3 Answers
SOURCE: Have just purchased a secondhand
Are you sure the TDK blank had either AUDIO/MUSIC somewhere written on the disc...if not, then that is the problem. On the other hand it it should not have recorded or played back as you said it did.
If it did have Audio/Music written on the disc, then first of all give the laser a clean by using either a disc cleaner or better still, take the cover off and gain access to the laser, using a cotton bud, diped in INDUSTRIAL METHALATED SPIRIT (usually coloured purple) do not use medical metholated spirit as oily additives could be added and smear the laser lens. Dry off the lens with the dry end of the cotton bud. Do not soak the cotton bud in the spirit, just a very small amount will do !!!
If it does not work now, try using other good named branded Audio/Music CD-R discs as there appears to be such a variation in the quality of CD discs which is well documented !
Did you FINALISE the TDK disc before you removed it from you recorder??
I have a feeling its the TDK disk.....I avoid TDK if I can...Try Sony or Philips Audio/Music discs, very few failures for me with those brands.
Hope this has ben of some help...good luck
Posted on Sep 29, 2011
Where can I buy a remote control for a Philips cdr 870 recorder?
Please contact the outlet where you have bought your product.
Sep 11, 2012 | Philips CDR870 CD Recorder
Operating manual for cdr870
You may download a copy of the manual here.
Jul 06, 2012 | Philips CDR870 CD Recorder
Have not been able to find digital cd's. Are cd audios the same for use on philips 870
Philips CDR 870 is designed to RECORD with ONLY Audio or Music CD-R or CD-RW discs !!
The word(s) Audio Or Music MUST be written somewhere on the Cd disc or Cd Covers.
Computer CD-R and CD-RW discs will NOT Record on this recorder !!
My experience of GOOD Audio/Music discs : Philips,Sony,Traxdata,Verbatum
My experience of BAD Audio/Music discs : ALL unbranded discs, Maxell,TDK
Dec 16, 2010 | Philips CDR870 CD Recorder
Replace the remote control
the only way are try it
ask the store if not works posible for refund
Mar 12, 2010 | Philips CDR870 CD Recorder
Hello i have a Philips cdr 870. With every blank CD inserted, the display shows NO AUDIO. Pre recorded CDs play OK. Unable to record. I have recently aquired this machine and this is the first time I have...
You are probably inserting blank computer discs, eg 650 or 700mb rather than blank music CD-R or CD RW`s which this machine is designed to work with. The correct discs are labelled "music audio" or 80 minutes. You can only use these types of discs. Why? When these recorders first came out, it was a way of battling piracey in copying discs. I believe there is a "hack" to enable this player to use blank computer discs.
SMA
Jan 13, 2010 | Philips CDR870 CD Recorder
I want to use the optical input s a dac without going through the recorder
Put in a blank or unfinalized disc, press Record until Record Manual shows. This is similar to an old-school cassette deck being in Pause/Record mode. That should do it. The input signal will be present on the audio outputs (both digital and analog).
The manual isn't specific about how long you can remain in Record Manual mode without starting to record on the CD. My Pioneer has a Monitor function so I don't need to place a blank disc for this.
Jan 03, 2010 | Philips CDR870 CD Recorder
May 16, 2009 | Philips CDR870 CD Recorder
Open Questions:
Philips CDR760 CD Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
