Question about Panasonic Microwave Ovens
NN-6859 microwave loud drone noise - Panasonic Microwave Ovens
3 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: panasonic microwave nn-s963bf making grinding noise
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can
order parts for this brand from Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Posted on Mar 06, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I have a Natioanl NN-6207
F and Fa could be the problem but.... You must check the power diode and the high voltage capacitor. One of these is most likely the reason the fuse failed in the first place. Ground the HV capacitor by holding an insulated screwdriver well back on the handle. The locate the Power Diode that will have at least ONE terminal that connects to the capacitor. Power doides are either 3'8 inch wide and 2 inches long or round an liik like a bit resistor with no color markings. ' Check the HV capacitor by rading each terminal to the case of the capacitor (no shorts allowed)
Then read across the capacitor terminals with the meter set on R x 10K. Watch for an initital jump in resistance and then it drifts up to infinity. Reverse test lead positions and you must get the same result. Resistance and then drift to infinity. Any other reading.... infinity in both directions, short to the case or short across the 2 terminals = bad Cap.
If after you perform the above tests and you still have the problem ... knowing you might pop another fuse there are 3 door switches. 2 of them will read resistance / continuity across the terminals when the door is close and one of them will read continuity across the terminals when the door is open. One of the 3 switches has 3 wires on it... the 3rd wire shorts the magnetron power when the door is open and the power relay / HV circuit is powered. This is a built in blow the fuse to prevent magnetron operation with the door open.
I think your are going to find that either the power diode or the HV Capacitor has failed.
Thanks for choosing FixYa,
Kelly
Posted on Apr 16, 2011
Hi my oven suddenly started making loud weird noises and now does not heat any food. I smell smoke. What might be wrong?
Seems to me that your magnetron is a goner, check also the antenna shield, cover inside the oven cavity and replace both, you may need to clean and repaint burn surfaces inside oven cavity.
Jan 08, 2016 | Panasonic NN-S676BA Microwave Oven
I have a panasonic convection/microwave. Last night, after I cleaned it, using oven cleaner on a sponge, it made a loud humming noise after running on microwave for about 10 sec. It does not make the noise...
Since the unit makes the noise on Microwave but not convection it is a problem it he Microwave Circuit. Probably in either the rectifier of bad mag, one of them shorted. Just looked at the date you posted this, Im sure you have fixed or replaced this by now
May 31, 2017 | Panasonic NN-C980 Convection/Microwave...
My NN-P295 wouldn't allow me to turn off the light about a week ago, so it remained on all the time. Then last night it was making a strange clicking noise. I got up to find the source of the noise and the...
It sounds to me you have short in the keypad controller system, from your description this is a very dangerous fire hazard situation, and the microwave in my view should replaced.
Feb 21, 2011 | Panasonic Microwave Ovens
Microwave making loud noise behind control pad and won't heat
Sounds like the magnatron (the bit that creates microwaves) could be goosed. Remove outer cover ( Isolate from the electric supply then remove screws at bottom on the sides).
Find big lump that says on magnatron with model nos etc on, any good electrical supply shop ( Maplins etc) should stock new one.
It is easy to change. It took me about half an hour having never done one before.
Buyer beware the price of the parts could be in excess of a new microwave.
Shop around
Sep 15, 2009 | Panasonic NN-T993SF Microwave Oven
Panasonic microwave nn-s963bf making grinding noise
You can
Mar 04, 2009 | Panasonic NN-S963BF Microwave Oven
Panasonic Microwave NN-C980-B buzzing noise but it still works.
All:
I have a 2003 Sears Ultra Wave microwave 721.63682300 with a similar problem. A few months ago it started giving off short buzzes when turned on. That stopped but then I noticed that everything took twice as long to heat up. After quite a bit of teardown&inspection I found a circuit break in the inverter board leading to ZD704 diode (pictured). I will now try to find a replacement diode to see if replacing will fix it. Thanks for your postings.
Feb 15, 2009 | Panasonic NN-C980 Convection/Microwave...
Microwave Ovens Logo
43 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
