Question about Asko T721 Electric Dryer
I have an Asko dryer model T721 that has stopped drying. Initially, it stopped producing hot air, but produced warm air on the low setting. Now it runs...just produces no heat. Pressing the reset on the back of the unit is ineffective.
SOURCE: my Asko T721 Electric Dryer is having drying troubles
Here's the answer:
The dryer has a thermo protection "fuse" that pops-out when the lint filter is not cleaned and air will not flow properly. When the airflow is restricted the dryer gets too hot and the "fuse" pops. Then it will not run unless you stand there and hold the start button in. As soon as you stop pressing the button the dyer stops running.
Clean the filter ESPECIALLY the "internal" filter. This one is behind the lower skirt of the machines face. There are two Torex head screws (T20) to be removed and the skirt comes right off.
Inside you see two red handles that you turn to open the filter door. Open the door and pull out the filter. It is a long metal finned box. Take it to your bathtub and run a ton of water through both ends to remove the lint inside. You'll be surprised at how much.
O K now let's "fix" the "fuse". Here it is likely you will need to pull the machine away from the wall. The fuse is a black plastic button about the size of a penny. It sits in the center of the machine's backside. It faces up a bit and if you have clearance you can reach your arm over the machines top and press it "in" with a finger. It clicks when you do so. This part is a no brainer. The dyer will now start properly.
The hard part to all of this is pulling the machine away from the wall since like me you probably have it sitting on top of an Asko washer. Take your time. You can do it.
Posted on Jan 21, 2008
  • 351 Answers
SOURCE: ASKO T721 dryer - Squeaking
the dryer needs a service you need to replace the front rollers,jockey pulley and grease the jockey pin,check or replace the belt.remove the lint build up from the front frame and element assy.also check that the felt and rubber seal arond the front frame hasnt come out.you can replace it but its hard to get in and you may have to replace the front frame.i find its any easy repair but i see a lot of asko dryers (not because there bad they just need a service about every 5-7 years).hope this helps.
Posted on Mar 20, 2008
SOURCE: overheat trips Asko T721 dryer
If you have a condensate tank that fills up too much the float inside the pump housing will shut the dryer off also.
Posted on Aug 05, 2009
  • 37 Answers
SOURCE: My Asko dryer does not dry clothes. It shuts off
It is quite common for lint to cover the blower on these units, making it impossible for the dryer to move any air.
1)remove the lower panel. you will need a T20 driver for this and may need to tip the dryer slightly to the rear
2)remove the left part of the blower plenum. this is held by 3 plastic tabs and a T15 screw
You will now see the blower wheel, it is a squirrel cage type. Check for lint buildup, broken vanes, or string/thread wrapped around the shaft.
if there is no problem with the blower then there is another reason you are not moving air. let me know if this helps
Posted on Sep 02, 2009
Macmarkus
  • 2605 Answers
SOURCE: asko dryer blows fuse
Hi, there are a number of possibilties to why it blows a fuse, and since you've recently transported the unit that increases the number of things it usually may be, unfortunately making it harder to diagnos. I would start by checking the fuse holders themselves. The only way to really check them however is to replace the holder. The reason being this, even under normal use the fuse "hub" and "holder" wear due to metal fatigue. The holder has a small spring in it which doesn't apply enough force to allow the fuse to "seat" or contact properly in the "hub" and in turn creates added resistance ( heat ), greater resistance equals greater amperage and "poof" hence the fuse blows as soon as you try and start the unit. Of course other things may have been damaged during the move such as the heater. Try starting it on a "air dry" ( no heat ) cycle. If it doesn't blow a fuse you know it is related to the heater, contactor, ( what Asko refer's to as a relay switch ) or wiring to and from the heater. Hope this was helpful to move you forward. Let me know what you find and if I can assist you further I certainly will try. God knows I've seen alot of these Asko appliances ha ha ! **Sorry if this appears crampy writing and bunched together, I'm on my iphone and it's my only source to the internet at the moment.** Good luck, macmarkus :)
Posted on Apr 13, 2010
Frigidaire FEX831CS0 does not seem to be producing warm water with the warm/cold cycle. It does produce hot water. The dryer takes way too long to dry.
Thank you for your inquiry, friend!
I understand that you are having temperature issues within your Frigidaire laundry center. I see that you feel changing the thermal limiter may fix your issue. That could help or it could be a possible issue with your element, water valve, or in home water supply. You may want to check and make sure the dryer vent is not clogged or restricted that could cause long dry times. With the water supply you may be able to run the sink closest to your washer in order to help boost the amount of hot water that becomes accessible inside of your washer. I hope all this information is useful for you. -Matt
Feb 14, 2015 | Frigidaire Washing Machines
Why is an Asko 7304 dryer running hot, so much so it melted fuse holder?
GOD IS still GOOD !!!!
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Sep 16, 2014 | Asko Dryers
After replacing the thermal fuse one my electric kenmore dryer, there is heat but clothes are not drying and is blowing out cold air
Might be the timer. Might just need cleaning. Take a look at my home video:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 27, 2012 | Kenmore Dryers
Clothes warms up but will not dry
I suggest you check the exhaust system to make sure it is clear. Secondly, is yours a drier that has a sensor that determines when to shut off? If so, clean your sensors according to the manufacturers direction.
Thank you for your question @ FixYa.com
Mar 02, 2011 | Asko T721 Electric Dryer
My asko T721 dryer won't start. If I hold the start button down it will work, but the second I let go of it the dryer stops. It was running fine yesterday and then it stopped and now I can't get it...
the start button is bad. you will have to get it replaced take the model and serial# and go to your local appliance part store and they should have one.
Dec 17, 2010 | Asko T721 Electric Dryer
Overheat trips Asko T721 dryer
Jul 24, 2009 | Asko T721 Electric Dryer
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
Asko T721 Electric Dryer Logo
79 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Are you an Asko Dryer Expert? Answer questions, earn points and help others
