Came back from a vacation and found the downstair thermostat's display blank. I tried all - reset breaker, reseat the unit. The upstair system is OK. The downstair system is not operational.
Took the upstair thermostat downstair, and it also went blank. Replaced it back to the upstair wall mount and it is OK.
There is a heater/fan in the attic that I have not checked.
TIA for some pointers...
Comments:
Jan 04, 2008
- Mr. Therinnaiguy,
It has got a bit cold lately in San Diego, so I decided to follow your advice and give it a try before calling the expert..,
As you pointed out, a blown 3A-32V spade fuse was found!!!
Got new one from Autozone to replace the blown one, all the voltages come back. Heater is now working again.
You are an angel!!!! Thanks very much.
Jun 20, 2008
- Sorry, I have not checked back for a while.
The fuse is in the hvac unit. Mine is in the attic. The problem is not with the control on the wall. The panel will need to be removed in order to see the ckt board and the blown fuse.
-   i have a honeywell T8000C thermostat with a blank display. circuit breaker is fine and the fan is still running. what should i do?
-   avery_b
Oct 05, 2008
-   I have a Honeywell T8000c Thermostat that controls a Comfortmaker NTG3 model furnace. The Honeywell display does not work since there is no 24 volt power to the wall plate or at the circuit board of the hvac unit. The fuse is OK and the blower motor operates continuously if the furnace unit switch is in the on position. According to the manual wiring diagram, the blower operates directly off the house 115 volt power while the electronic gas ignition and the thermostat use 24 volt power from the unit transformer. Is there anything else that I can check before calling a service technician since I can't operate the furnace. -   Perplexed411
Jun 07, 2008
-   I have a similar problem. My power was out for a few days and when it came on, our screen on the thermostat was blank. Is the fuse you are talking about directly on the thermostat or is it in the hvac unit? I am unsure. -   monique765
May 01, 2008
-   yesterday we lost power and upon power restore, the lcd was blank on the downstairs Thermostat but the upstairs one was ok, brought the upstairs one down and it worked downstairs.
What could be wrong with the unit in this case? Should i try to replace the fuse on the bad Thermostat? or is purchase a new one?
-   I have the Honeywell square thermostat and I cam home yesterday from work and noticed that the display screen was blank. The a/c unit was already off so not I cannot turn the unit back on. I have tried resetting the breakers and all, but still nothing. Please help-   tosha001
If you have a volt meter, remove the thermostat off from the mounting plate and check for 24 volts AC across red (R) and White (W). Then check across Red and Yellow (Y). If you do not find any voltage, follow wire as much as you can all the way back to the air handler that is connected to it. Look inside and see if there is a small Auto (car) type of fuse in the wiring harness. Test and replace if necessary. Jump out the Red and Green terminals on the air handler and replace the door. See if the blower turns on. If so, you have narrowed it to the wiring to the thermostat. If not, you have a power problem and will need a technician.
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at...
(More)
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at the lowest price. We stand by and guarantee the quality of our laptop battery.
<a href=http://www.bestlaptopbattery.co.uk/hp/dv1000.htm>Hp dv1000 battery</a>
Our Price: At Bestlaptopbattery.co.uk, you always pay the lowest price. We make this sure by offering our Best Price Guarantee on all our Hp dv1000 laptop battery.
Our Service: We have a dedicated team of customer service executives who are eager to help you save time and money by sharing their knowledge and expertise on batteries and related products.
Your Satisfaction: Your absolute satisfaction is our top objective. We stand by the quality of our battery and offer a 30-day money-back guarantee on all our products, no questions asked. Our products also carry a 12-month full repair or replacement warranty for any form of manufacturing defects.
How can you care Hp dv1000 laptop battery to get the maximum life out of it?
It is a question we frequently asked. It's a valid question since laptop batteries are usually expensive to replace.
First of all, how long should your battery last? 2-4 years is generally acceptable depending on how frequently you use and charge the battery. If you travel a lot and use and charge your battery frequently then you might only get a couple of years at the most out of your laptop battery.
The Hp dv1000 laptop battery are usually made with Li-Ion laptop batteries and the very nature of Li-Ion batteries is that they have about 500-600 charges and last at most about 4-5 years (shelf life). They also have a self-discharge rate of about 1% per day so you need to be sure to charge them at least every 6 months.
we were going to purchase 2 fujitsu split systems, but have just had a offer of buying LG instead ....
(More)
we were going to purchase 2 fujitsu split systems, but have just had a offer of buying LG instead . where can we get info, not from a salesperson regarding whats the better unit, can u help
my split system just blink a green light when turned on--outside powerboard was recently...
(More)
my split system just blink a green light when turned on--outside powerboard was recently replaced--worked ok for a while
