Question about Dacor CM24P-1 Coffee Maker
Dacor coffee maker drip tray fills up quickly with water
4 Suggested Answers
SOURCE: Dacor coffee maker
Welcome to the club of unhappy Dacor coffee machine owners. The problem you are having is the problem everyone has had. The only thing I can suggest that has worked most often for me is not leaving the machine on for very long. I think the temperature gets messed up if it is left on too long. I just use mine now for a few cups in the am and then I turn it off. I've been so frustrated with it that I have gone back to my french press. One of the posters on this site actually got Dacor to buy her machine back. I will probably try that route as well.She replaced it with a Meile and is very happy with it. Good luck!
Posted on Aug 09, 2008
SOURCE: Dacor coffee maker not sucking any water or milk
I will call a local repair company, thank you.
Posted on Jan 03, 2010
  • 132 Answers
SOURCE: The coffee maker says it
if there is a water line attatched to your unit then you dont have to add water . there should be a spicket to shut off the water at the source. if you turn it on and it makes coffee then there it is,clowny daggers
Posted on Nov 09, 2010
How do i open water resovor on krups oblo coffee maker
See page 8
8
8
FIRST USE
Rinse water tank before first use.
Fill water tank with fresh, drinking water. insert
water tank to machine.
Switch machine on. Power button starts
blinking red while machine is heating up for
approx. 40 seconds. Afterwards power button
lights steady green and machine is ready.
40 sec
ON
Push selection lever to the "HOT" position.
Machine starts rinsing.
Open locking handle and insert empty capsule
holder. Close locking handle.
Place jug under outlet.
Push selection lever to the "COLD" position.
After approx. 60 seconds push selection lever
to the "STOP" position. Empty jug and refill
Make sure that the selection lever is in "STOP"
position. Then plug the power plug into a
mains power socket.
to the "STOP" position. Machine stops rinsing
and power button blinks red for about 5
seconds.
8
Place drip grid on drip tray. Then insert drip
tray at desired position of drip tray.
Then insert drip tray at desired position of machine.
Jul 02, 2017 | Krups Coffee Makers & Espresso Machines
The water in my Nespresso does not come through the from where the pod is, but fill the drip tray! what is wrong?
I had a coffee machine that was letting out the water instead of making the coffee it turned out the hose that leads the water was disconnected from the source if you can get to the hose you may find the problem good luck
Jan 03, 2015 | Nespresso Coffee Makers & Espresso...
Bunn pour omatic commercial coffee maker will not brew and it leaks
VPR is a pour over "Volume Displacement" brewer. Required to completely fill the inner tank and heat prior to using brewer. BEFORE plugging in unit, water must be poured into upper tray and with brew funnel and empty pot in place. Keep pouring water into top fill tray until water drips out of brew funnel. Plug in VPR and allow it 15-20 mins to heat up. leave the pot as there may be additional water dripping. Remove power if there is any water spilling out from other places like the top pan cover or bottom of machine. With the initial heating done, take a full pot of water and slowly pour into the top filling tray. HOT steaming water should come out of the brew funnel to fill the (empty) pot. Prep is done and the machine can be used to brew a pot after 10-15mins of reheat time.
*** the machine you have needs to be checked for leaks in areas mentioned above. Water should only come out of brew funnel (if not present then the brew head or if that is missing then the brew pipe. All will need to be replaced prior to brewing.) Leaking under machine is an indication of leak(s) in pour tray,tank,tank cover, gasket, probe gasket. This machine like any used equipment should be checked out by qualified tech prior to use. Be aware that coffee vendors sometimes rent or loan brewers to customers.
Nov 08, 2017 | Bunn NHB Coffee Maker
Barista supremo thinks it doesn't have coffee beans
http://www.espressotec.com/media/downloads/57/SA1260_Odea_Giro_plus_manual.pdf The red light comes on, doesn't it? The light indicates that the water tank could be empty or the drip tray is full. Tell the coffee machine that it has enough beans, but to please the machine you will fill the water tank and empty the drip tray. Good luck, kolbrun
Sep 10, 2013 | Saeco Odea Giro Plus Coffee Maker
Cva 4070 drip tray issue
Miele CVA 4066 -Empty drip tray warning would not go off even after draining the drip tray, cleaning contacts, and resetting power. Water was coming out from under the empty tray.
I pulled unit out and removed sheet metal in rear around water inlet. when I attached water line and power cord & turned on power, I could see water dripping out of one of the 2 solonoids on the water inlet valve. $168.00 from Miele and no expensive service call.
May 27, 2012 | Miele CVA4070 Coffee Maker
My Miele CVA 2660 built in is about 3 years old, the waste water fills up the drip tray in just one day, after one coffee fill. The water from the resivour "seems " to go straight to the drip...
Hi Robin,
I had this problem a year ago. Two things to check: 1. Does the water tank go all the way down so that the small notch at the back of the tank fits into the floor of the machine? 2. Any dirt at the water tank outlet?
Besides these two issues, I would say that it is very likely that the problem is that the valve of the water tank needs to be replaced. This will especially happen if the machine has been lefter without water in the tank for some time.
Good luck.
Jan 07, 2011 | Miele CVA2660 Stainless Steel Coffee Maker
Drip tray is filling up with water sooner than in
Hi
Either your grind is very coarse or your injector seal is bad. The injector is behind the brew unit and has 2 orange O-rings on it. See if you can wiggle the injector?
Dec 31, 2009 | Solis Master 5000 Espresso Machine
Dacor CM24P-1 Coffee Maker Logo
35 people viewed this question
Top Dacor Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Michael Vincent Cruz
Tom Chichester
Are you a Dacor Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
