Question about Water Heaters
Amtrol boilermate wh7p E2 code - Water Heaters
SOURCE: No hot water from the Amtrol Boiler Mate model
The smart control was only reading 140 it never went up or down from that number and now it has an ER3 code seem the circulator just runs and runs
Posted on Feb 14, 2010
  • 10865 Answers
SOURCE: no hot water have amtrol boilermate
There is a device on the boilermate called an aquastat which controls the flow of hot water into it. Replace that and you should be up and running again. Joe.
Posted on May 23, 2010
aquaman987
  • 927 Answers
SOURCE: wondering how much this 2007 boilermate wh7p
Therm X Trol Amtrol ST-12 Water Heater Expansion Tank - eBay (item 390194010683 end time Jan-05-11 07:59:01 PST)
This is on E-Bay for $58, new from a supply house.
Let me know if this helps.
Gary
Posted on Dec 18, 2010
SOURCE: ER3 no hot water
Er3 means that the water is being heated for more than 1 hour without reaching the set temperature.
Need new aquastat.
Posted on Dec 28, 2010
packrat1948
  • 528 Answers
SOURCE: if the amtrol boilermate water
If the area it is in is heated it will not freeze any more then the water piping would.
Posted on Feb 02, 2011
AMTROL WH7P-41 GAL TANK. 12 YRS OLD. BOILER PRESSURE IS INCREASING ABOVE 30PSI, AND DUMPING SMALL AMOUTS OF WATER FROM RELIEF VALVE ON BOILER. Do I replace coil?, or buy a new tank? Thank you
do you have a pressure tank as part of your water heater and water pipes? if yes, check to make sure tank pressure matches your incoming water pressure from your municipal hook up
Aug 18, 2015 | Amtrol Water Heaters
Boilermate er3
is it an electric or gas or oil fired. Er3 means it is not getting up to temperature within the required time. Electrical - element bad. for oil or gas, no ignition or fuel supply.
Oct 28, 2013 | Amtrol ST-120V-C THERM-X-TROL ASME...
Boilermate wh-7l, thermostat
Your BoilerMate obtains its energy from the home's boiler and does not have a reset button itself. I work for Amtrol, the manufacturer, and can be of assistance with more info. What is the problem you are experiencing?
May 28, 2012 | Water Heaters
No hot water have amtrol boilermate. boiler works fine to heat house just not hot water
May 23, 2010 | Water Heaters
Amtrol wh7p
https://youtu.be/pUOBR1k3KvM- try seeing if this video answers anything. If not, there are a bunch of others about water heaters; just look around until you find one that looks similar to the one you have and watch. Sometimes, you get lucky lol
Jun 14, 2017 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
Beeping noise
E2 means hot water over shot, make sure to check boiler hot water system to make sure zone valve or control is staying closed when the call for boiler hot water to the water heater is isolated. Sometimes a zone valve will fail open or not close properly causing hot boiler water to constantly feed the water heater.
Dec 08, 2009 | Amtrol Water Heaters
ER3 no hot water
Need new aquastat.
Sep 28, 2009 | Amtrol ST-120V-C THERM-X-TROL ASME...
Amtrol Boilermate makes whining noise
I had also this problem before, same with buzzing sounds on my Amtrol Boilermate and all I had to do was to call the local dealer and they have got it fixed.
May 05, 2009 | Emerson Part UWL Chrome Ultrasystem water...
No hot water from the Amtrol Boiler Mate model wh7p
Mar 09, 2009 | Water Heaters
Water Heaters Logo
77 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
