Question about Utilitech Plumbing
Have a 1/2 HP Utilitech cast-iron sump pump #0313502 16 months old from Lowes, the pump works fine but the external switch will not turn the pump on. Heard they are defective switchs. Where do I send it to get it replaced?
  • 3 Answers
SOURCE: My sump pump fails to work during big rains. If I
if you dont know how old it is and think it is really old replace floods are never fun
Posted on May 14, 2009
dogsled48195
  • 411 Answers
SOURCE: I have a pacific hydrostar vertical float sump
The Float Switch (2) automatically switches on and off at a water depth of approxi. mately 4 inches. The ON/OFF height can be manually changed by adjusting the Float Switch Lock.
Posted on Jan 28, 2011
aquaman987
  • 927 Answers
SOURCE: We have a flotec well pump, less than a year old.
To replace the switch, shut off power, remove wires noting all wire locations.
You may have to relieve pressure in the system by using water until the surge tank is empty.
I'm not sure about that.
You do have to either remove the switch from the piping by unscrewing it or remove the piping from the switch by removing the connector and unscrewing the connector from the switch.
Assembly is the reverse. You should use teflon tape of dope on the screw connection below the switch.
The procedure should take about a half hour but you won't have any water during this time.
Gary
Posted on Jul 21, 2011
H2_Brad
  • 425 Answers
SOURCE: what causes intake valve to stick on 16 hp single
Most likely just the age of the engine. It is not uncommon to have to de-carbon the valves, head, and top of the piston in a small engine after years of use.
SOURCE: my sump pump doesn't shut off, I am assuming it
Does the breaker to the pump pop when you raise the float up? If so, you have the same problem I had. I was bothered by the two cords coming out of the ground and plugged into an outside outlet since I have young kids playing around it. One of the cords was plugged into the back of the other cord's plug. I rewired the cords in a junction box. I didn't understand that the plug that was plugged into the outlet was actually a switch. When the float is up, it allows power to flow through the other electrical cord. By wiring both plugs to 120V, I basically wired the pump directly to power and the switch directly to power. My pump ran continuously for several months before I realized my error. Since the pump was always running, the float never was raised to the up position which would have popped the breaker. If you try raising up the float and your breaker pops, then you will know you did the same thing I did.
Posted on Jan 28, 2012
Motor would not start intermittently. Disassembled to determine possible problem.
The oil has to be there. Intermittent starting is usually the float switch hitting something in the sump. If the pump motor has a capacitor on it, replace the capacitor.
Aug 20, 2015 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Impeller runs, no water comes out. Removed output hose, air is blowing out when removed from sump.
Remove bottom cover, check for clogged intake holes, and make sure the impeller is solidly attached to the shaft. Can you see the water in the sump? Is the sump full of sand at the bottom?
Jun 28, 2015 | Utilitech 1/2-HP Cast-Iron 83 GPM...
.where can i purchase a replacement housing for my pump
How about where you bought pump?
Utilitech is a lowes brand, isn't it?
Apr 14, 2015 | Utilitech 2-HP Irrigation Pump UTP20P1
Why wont the pump turn on
If the pump is plugged in through a float switch the switch may be bad- try plugging the pump in by just the plug for the pump itself if possible -if that works then you need a new float switch.
Jun 10, 2014 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Pump won't shut-ff
Hi Ron...
Check your float switch....sometimes they can get stuck to cause this problem of not shutting down after draining the orginal water.
Take the float switch and move it up and down...this may help to clear the stuck switch inside of the float
Bud
Apr 24, 2013 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
I have a utilitech jet pump can only set pressure to 20-40 would like to set to at least 30-50 but cannot .The pump is less than 6 months old .any ideas other than i bought the wrong brand
Sorry Richard,
Sounds like you are correct, you bought the wrong type of pump...if your looking for pressure/output you might consider purchasing a "sprinkler pump"...they will go past 70psi and more
Please take time to rate me
Bud
Mar 31, 2013 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Pump not working
If power is going to pump and float switch is good, motor has fried, time to get a new one.
Oct 07, 2012 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
I have a Utilitech 1hp shallow well jet pump which turns off and on rapidly while using water. I have 25 psi in the air tank. I replaced the pressure switch and still have problems.
Good you got it working. Please post again if you have more trouble on this or another item. Also be sure and check what I mentioned just in case you are operating at the margins, don't want a failure right after you got it going!
Sep 15, 2012 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Plumbing Logo
326 people viewed this question
Top Utilitech Plumbing Experts
Dave
J.D. Browning
J.D. Browning
Boyet Soriano
Boyet Soriano
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
