Question about Heath Zenith All Metal Motion Sensor Light Control, 270;, Detection Zone, Lifetime Warranty, Bronze
Heath zenith motion sensor light part model hb 4192
Sensor no longer works
4 Suggested Answers
fisherman816
  • 66 Answers
SOURCE: How do I replace the Halogen bulb on the Heath
Unscrew the bulbs counterclockwise with youre finger tips.
Posted on Nov 13, 2009
  • 54 Answers
SOURCE: I have a sensor that stays on all night when the
Your motion detector is based on infrared or heat sensing technology. Moving air or wind will make your unit more sensitive to false alarming. Here are a few things for you to check: 1) make sure your unit is sealed. Any holes or openings in the unit's casing will affect operation. 2) you may need to readjust the unit's sensitivity. There may be an adjustment pod or jumper inside the detector to reduce sensitivity. 3) make sure the unit is mounted securely. If the wind causes the detector to move, even slightly, this could be the cause of your problem.
Posted on Feb 02, 2010
  • 250 Answers
SOURCE: need to wire motion sensor to light, have three
The black wire goes with the black house supply wire, and the red wire goes with the black wire from the lighting fixture. The white wires all connect together.
Posted on Feb 22, 2010
Can I buy just the motion hb 4192
It is cheaper to buy new machine
Feb 14, 2015 | Dryers
How to set a outside sensor light?
Request instructions directly from Heath Zenith.
Jul 19, 2014 | Heath Zenith Halogen Quartz Motion Sensor...
The LED flashes, but the lights won't come on. Do I need to install a light shield. The sensor is mounted in a well shaded area 10 to 12 feet above ground. There are landscape lights beneath the sensor are...
There are settings on the sensor itself. Should be a dusk to dawn setting that will keep it off during those times and then function at night. as far as not working I would first suggest setting the sensitivity. Disrupting to power could have reset this.
Oct 15, 2013 | Heath Zenith Heath/Zenith SL-5411-WH Heath...
Need the manuel for setting heath zenith lamp module model no BC-465
i have a question about heath zenith motion sensor light.
i put up two new Heath Zenith Motion Sensor Light Control the i buy from home depot tie into switch leg. When i put in on test it work fine stay on for a few second them off, but when i set up on automatic Time-1min.\ Dual Brite-off \ Lamp Mode-Normal light go off and them come back on for the rest of the nigh long and go off morning time. Any body have this problem?
Jul 06, 2012 | Heath Zenith Secure Home Motion Activated...
My sensor no longer works. It use to turn on the porch light when someone entered the carporch. How do I open the sensor so that I can put new batteries in it? I know that it uses AAA batteries.
Manual for this sensor is not available.
In the Zenith I have installed The motion sensor battery slot was h at the back side of the sensor, you had to remove the sensor from the wall sliding it on one side to access the battery. It mounted two AA batteries, not AAA.
Aug 17, 2010 | Heath Zenith 270 Degree Replacement Motion...
Need to wire motion sensor to light, have three wire(red, black & white), need to know how to hookup wires? my model no. is :-heath zenith sl-5318-bz-a
Feb 22, 2010 | Heath Zenith SL5316WHB Replacement...
Flood lights take a very long time to come on
Insure you are using a standard flood light on motion sensor lights and not a florescent energy efficient flood light as they take longer to reach full brightness as the bulb filiment warms up. They are better suited for constant lighting rather than intermittent purposes such as sensor lights.
Good Luck
Nov 21, 2008 | Heath Zenith Electrical Supplies
Heath Zenith Security Light fixture with motion stopped working.
I am in the middle of a discussion with Heath/Zenith over a closely related and perhaps identical issue. I purchased their 5718 model from Home Depot and based on the fact that their brochure stated that "CFL bulbs are only usable on 270 degree units." I purchased the model 5718 unit (270 degree) and used CFL bulbs. It experienced the same problem others noted.
The technician at Heath/Zenith told me that only DIMMABLE CFL bulbs would work with this unit (even if the DualBrite feature is turned off). Standard CFL bulbs will not work.
Their brochure does not make that clear. Perhaps that is the answer to others' problems.
Nov 12, 2008 | Heath Zenith SL-6136-WH Basic Solutions...
Heath Zenith All Metal Motion Sensor Light Control, 270;, Detection Zone, Lifetime Warranty, Bronze Logo
285 people viewed this question
Top Heath Zenith Home Security Experts
Mike
Domenico Grillo
Are you a Heath Zenith Home Security Expert? Answer questions, earn points and help others
