Question about Plumbing
Utilitech sump pump 1/2 HP #0313502
16 months old,pump works fine but external switch will not turn pump on. Heard they are defective and company will replace it. Where do I send it so as to get it replaced.
  • 3 Answers
SOURCE: My sump pump fails to work during big rains. If I
if you dont know how old it is and think it is really old replace floods are never fun
Posted on May 14, 2009
  • 1114 Answers
SOURCE: Pump will not come up to pressure and turn off!
With no leaks in line and assuming the jet is not embedded in debris at bottom of well, try priming the pump again and getting all the air out.
Posted on Jul 08, 2009
  • 119 Answers
SOURCE: What value starter capacitor for 1/6 hp Flotec sump
when a motor burns out this will happen , replace the pump.
Posted on Apr 19, 2010
aquaman987
  • 927 Answers
SOURCE: I replaced old pump w/
The water and therefore the pressure has to be going somewhere. If you are sure that there are no leaks in the house or outside, then the water is going back into the well. There is a check valve either in the suction line of the pump between the top of the well and the pump or down in the well.
If this check valve fails, it allows water to go the wrong way and back to the well. The result is that you lose pressure.
Secondly, you have to be sure that there are no air leaks between the top of the well and the inlet to the check valve. Leaks in that piping will make repriming difficult.
Write back with more and I'll try to help more.
Gary
Posted on Jan 22, 2011
SOURCE: my sump pump doesn't shut off, I am assuming it
Does the breaker to the pump pop when you raise the float up? If so, you have the same problem I had. I was bothered by the two cords coming out of the ground and plugged into an outside outlet since I have young kids playing around it. One of the cords was plugged into the back of the other cord's plug. I rewired the cords in a junction box. I didn't understand that the plug that was plugged into the outlet was actually a switch. When the float is up, it allows power to flow through the other electrical cord. By wiring both plugs to 120V, I basically wired the pump directly to power and the switch directly to power. My pump ran continuously for several months before I realized my error. Since the pump was always running, the float never was raised to the up position which would have popped the breaker. If you try raising up the float and your breaker pops, then you will know you did the same thing I did.
Posted on Jan 28, 2012
Motor would not start intermittently. Disassembled to determine possible problem.
The oil has to be there. Intermittent starting is usually the float switch hitting something in the sump. If the pump motor has a capacitor on it, replace the capacitor.
Aug 20, 2015 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Impeller runs, no water comes out. Removed output hose, air is blowing out when removed from sump.
Remove bottom cover, check for clogged intake holes, and make sure the impeller is solidly attached to the shaft. Can you see the water in the sump? Is the sump full of sand at the bottom?
Jun 28, 2015 | Utilitech 1/2-HP Cast-Iron 83 GPM...
Sump pump does not go on all the time have to shake pipe to get it going so water doesn't overflow
There should be a float switch in the pit, sounds like its getting stuck and when you shake it it activates. Check the switch, the rod, etc.
Mar 01, 2015 | Utilitech 0.33-HP Thermoplastic...
Why wont the pump turn on
If the pump is plugged in through a float switch the switch may be bad- try plugging the pump in by just the plug for the pump itself if possible -if that works then you need a new float switch.
Jun 10, 2014 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Pump won't shut-ff
Hi Ron...
Check your float switch....sometimes they can get stuck to cause this problem of not shutting down after draining the orginal water.
Take the float switch and move it up and down...this may help to clear the stuck switch inside of the float
Bud
Apr 24, 2013 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
I have a utilitech jet pump can only set pressure to 20-40 would like to set to at least 30-50 but cannot .The pump is less than 6 months old .any ideas other than i bought the wrong brand
Sorry Richard,
Sounds like you are correct, you bought the wrong type of pump...if your looking for pressure/output you might consider purchasing a "sprinkler pump"...they will go past 70psi and more
Please take time to rate me
Bud
Mar 31, 2013 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Pump not working
If power is going to pump and float switch is good, motor has fried, time to get a new one.
Oct 07, 2012 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
I have a Utilitech 1hp shallow well jet pump which turns off and on rapidly while using water. I have 25 psi in the air tank. I replaced the pressure switch and still have problems.
Good you got it working. Please post again if you have more trouble on this or another item. Also be sure and check what I mentioned just in case you are operating at the margins, don't want a failure right after you got it going!
Sep 15, 2012 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Plumbing Logo
329 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
