Question about Levelone Level One WAP-3101 Wireless PoE Access Point 802.11a/b/g
How do you do a physical factory reset on these AP's?
Why i cannot factory reset username, password and ssid ap? and i just can factory reset ip ap
What are you connecting the wap-1001 to? An existing network . Does the subnet mask match it defaults to 255.255.0.0
if the p.c you plug directly into the ethernet connection of the ap has a different subnet mask it can't talk to the router. how does your p.c get its ip address is it static or dynamic via dhcp server . ip is default of 192.168.1.20 also is anything assigned 192.168.1.20 .
http://download.level1.com/level1/manual/WAP-1001v1.02_UM.pdf
the default password and user name is in the user manual
Jun 17, 2015 | Levelone Level One FreeCon 802.11G Outdoor...
Password admin is not working
there maybe a reset button on the back of the AP. If so power up the AP and press this reset button for a few seconds then release the button and it should be reset to the factory defaults.
Sep 28, 2012 | EnGenius ECB3500 - wireless access point...
Cannot access my tp link TL-WA601G 108M Wireless Access Point
Use the Factory Default Reset button: First, turn off the AP's power. Second, press and hold the default Reset button then turn on the AP's power, until the system LED lights up (about 3 seconds). Last, release the reset button and wait for the AP to reboot.
Reset the factory defaults.
Here is your user manual:
http://www.tp-link.com/english/soft/20091515618.pdf
Default username and password is admin for both
May 20, 2012 | TP-LINK Computers & Internet
How to RESET Motorola AP 6532 Access Point to Factory Default?
This is the reset username Username : reset Password:
MAC address XX XX XX XX 10 20 = IP address of 169.254.16.32 *10 in Hex = 16 in Dec *20 in Hex = 32 in Dec
Apr 29, 2012 | Motorola AP 6532 Access Point
3com AP 7250 - how do i reset it to factory defaults if i don't have the admin password ?
It will have a reset button on it, hold it down for ten seconds and it should reset the router to factory.
Mar 12, 2012 | 3Com Wireless LAN Access Point 7250...
I have 2 comtrend dh-10pf powerline adapters. one of the adapters status is a red flashing light and the AP light and the Ethernet light are blank. the second powerline adapter has a solid red status...
To start you need to factory reset both adapters,
plug them both into a wall socket next to each other, press the config/f reset button, hold in until ap light goes off, repeat on the other one.
Now you should have a red status light on both.
Press the config/f reset button on one for about 5 seconds, wait until ap light stays on, this one is now your access point (ap) that should be plugged in to your router when you have finished config.
Now press the ap adapter config button again for about 5 seconds until ap light flashes, then press the config button on the other adapter until ap light flashes, wait until they both stop flashing, wait a few seconds, the status light on both adapters should be green, and one adapter should have an amber ap light.
Hope this helps.
Jan 28, 2009 | Computers & Internet
Change the ip address
If your AP password erros, you can't enter the setup page of your AP in you browser. Do hard reset. Press little button behind your AP about 30 seconds. Will reset your AP to factory default, IP 192.168.0.50 subnet 255.255.255.0 user name: admin password: leave it blank.
May 24, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
How to probe the configuration or reset the 2700AP?
Restore it to default, with these things, if it wont work on automatic, then something is worng.
Feb 27, 2008 | D-Link AirPremier DWL-2700AP 802.11g/b...
Levelone Level One WAP-3101 Wireless PoE Access Point 802.11a/b/g Logo
Top Levelone Computers & Internet Experts
micky dee
Prashant M
Prashant M
Are you a Levelone Computer and Internet Expert? Answer questions, earn points and help others
