Question about Jenn-Air W30400P Stainless Steel Electric Single Oven
I have a Jenn-Air jjw9630ddb (double electric bake oven). The top oven (bake) only heats up to about 170. The broil is fine. I want to remove the bake element, but it is a hidden element (broil is exposes). How do I get the thing out to test it? There are a number of screws here and there (non in the back wall except around fan, just on front). Do I have to take the whole oven out???
the dr
  • 447 Answers
SOURCE: Jenn-Air w156 Single Wall Oven Problem
Most likely its the EOC (electronic oven control), it needs to be replaced. If you self cleaned the oven a lot the very high heat generated fatigues computers in modern ovens.
Posted on Sep 28, 2007
tzweeb
  • 318 Answers
SOURCE: Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Posted on Jan 22, 2009
rickzilla
  • 706 Answers
SOURCE: lower electric wall oven won't heat up
It is highly likely that your heating element is open so I would ( with power removed) verify the integrity of the element by detaching it and making sure it is not elecltrically OPEN, It is nothing more than a big power resistor that when current is flowing,..gets hot but if it becomes open.. you will not have any curent flow thru it ( or heat generated from it). That would be the first place I would look.. It could also be the control that feeds it..
A few ideas to check..
Regards,
Rick
Posted on Feb 16, 2009
  • 189 Answers
SOURCE: Upper oven elements don't heat
Hello- 'Successfully' sounds like you were forewarned....  During the 'self-clean' cycle a circuit or connection to the upper elements burned out while attempting to turn stuff inside the oven to ash. Since this is a wall oven my recommendation is for service from a good tech in your area. You may have lucked out with a fried connector, but many times control board is damaged beyond repair and must be replaced. Only on-site diagnostics will confirm, and this is a very heavy unit for most owners to safely service.  - Remember- Don't use 'self clean'!! Scrape and clean with soapy water and cloth. Turn on oven to 450deg. for 30 min. Much safer. Less costly.       Please acknowledge this post if the info is helpful- Have more if needed.  Thanks-  Ed
Posted on Mar 23, 2010
mc1bean
  • 3053 Answers
SOURCE: Jenn-Air wall oven, broil elements will not start
Hello, germin
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and farther back, It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your oven, from repair to trouble shooting it. Even pictures and video's. Just scroll around and you will see tons of information to almost any question you might have on your Oven. If you go to this link and click around, I am sure you will find out so much about your oven, you will know more than the company that made it. The good thing about this link is, then you can make the decision of DIY or hiring a pro. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
My bottom oven ( non-confection) will not go on-it will just sat 100 degrees but won't get warm or hot. Top seems to be working fine. This started after I tried to use the self cleaning feature.
If broil and bake do not work on your bottom oven, it is probably your lower thermistor or control board. If the bake works but broil doesn't or broil works and bake doesn't, it is very likely your heating element. With an ohmmeter, the heating elements should be about 40 ohms. Much higher or lower signals a problem. If you suspect the control board is the problem, they can be repaired quickly and reliably at www.fixyourboard.com
Oct 11, 2010 | GE Profile JTP56 Electric Double Oven
I have a double oven. Model WW27430. The top oven will not heat. The bottom is fine. I was told that is was the relay board. which I replaced and I am still having the same problem. Could both...
Looking at the schematic I see 2 possibilities:
1. I think the most likely cause is a failed "limit switch" aka "thermal fuse" aka "temperature cutout". For each oven there is a limit switch that feeds power to both elements. So the upper limit switch is probably tripped which would kill power to the upper bake and broil elements. The limit switch is usually located on the back wall of the oven cavity.
2. There are a relay board for each oven. Be sure you changed the right one.
Best Regards,
Bruce
Jun 19, 2010 | Jenn-Air WW27430P Stainless Steel Electric...
Mar 23, 2010 | Jenn-Air JJW8230D Electric Double Oven
Our Jenn-Air double oven is 10 yrs old. Will not
There are 3 things that can cause this:
1. Bake or Broil element faulty. The oven cycles these on and off to reach and maintain the average setpoint temperature. If the elements heat poperly during the time they are ON, then they are OK (may be able to see them glow).
2. The temperature sensor probe is faulty. This can cause the oven to think it's hotter than it actually is.
3. The above two causes can be easily diagnosed by a technician with an ohm-meter. If they are both OK, then the problem is in the controller itself. If this is the case you may want to have us repair the controller. We see this fault quite often.
Hope this helps you out.
Regards,
Bruce
Oct 10, 2009 | Jenn-Air JJW8230D Electric Double Oven
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Oven will not heat
Sounds to me like your bottome element is burned out.  I would replace this, or at least take it out and bring it to an appliance store to have it tested.
Mar 04, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
No heat
relay in the control circuit maybe bad
Aug 23, 2007 | Bosch HBL 5056 Electric Double Oven
Jenn-Air W30400P Stainless Steel Electric Single Oven Logo
44 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
