I have the manual, which does not address either of these issues. I did however, find online that this phone is quite selective in which bluetooth accessories work with the tv function.
thank you for your help
You can't post conmments that contain an email address.
When a call on your phone comes in i will vibrate, flashes red when battery is low. The light will also be red when its charging. It will turn off when its charged.
It can be from the power supply is not able the supply enough power due to failing components in the power supply module such as DC filter caps or loose transformer core is vibrating or from the backlight inverter transformers. You will have to take a close listen to find out exactly where the noise is generated from first.
in LG type phones, this actually easy.. first the easy part is to activate your bluetooth. check also your settings and your bluetooth name for you to know your device. if it is a phone to phone transmission, both must be activated. choose the picture but notice a bluetooth symbol on top of your screen usually beside the clock should be activated or moving. go to options then choose send.. there will be choices like infrared, bluetooth, etc. of course, choose bluetooth. it will re access and prompt the you and the receiver the bluetooth detected. then done.
