Insufficient vertical height
I have a Panasonic TV Model No CT-32G13W. When the set is powered on, the picture fills the entire screen. At some point in time, retrace lines appear at the bottom of the screen and move vertically upwards resulting into a narrow picture. i know that it is a strong possibility that the problem is probably in the vertical output circuit. I tried to get a schematic from a vendor on the internet but the print is very poor and is impossible to read. I would very much appreciate if you would assist me in solving this problem.
  • 1 more comment
  • Anonymous Nov 30, 2007
    I need the schematic diagram from Sanyo AVM 1907 in order to repair the problem in the vertical
  • Anonymous Nov 15, 2008
    picture is significantly narrower than the screen; picture is centered on the screen with black space to the left and right; but picture reaches all the way to the top and to the bottom. Is it vertical insufficiency?
  • rudolfol Nov 15, 2008
    picture is significantly narrower than the screen. There is black space to the left and to the right of the picture. But the picture extends all the way to the top and all the way to the bottom of the screen. Is this vertical insufficiency? What causes it? What is the fix?
    An expert who has answered 500 questions.
  • 556 Answers
1 it is due to electrolytic capacitor defective in vrtical output stage. 2 loose contact in vertical. 3 fault due to feedback ckt in v/stage. as per schematic diagram is concern check
Posted on Sep 29, 2007
Horizontal lines across TV screen Pansonic CT 35g25
Check its vertical output section circuit for any component damage or loose soldering terminals. Check the solder terminals of the vertical output IC. Resolder all the suspected solder terminals by applying al little more fresh solder, without making any solder bridge short in between adjacent solder terminals.
If this do not help you, replace the vertical output IC. Lose of Vertical Scan is the problem of your TV.
Aug 04, 2012 | Panasonic CT-35G25 TV
It appears that the image on the screen is zoomed in, but I can't figure out how to "undo" that. Thank you!
If the image on screen is zoomed both in vertical and horizontal direction, your TVs power regulator inside it is faulty. [Overvoltage]. If it is zoomed in vertical direction only, that is only the height of the picture is zoomed, you can adjust it with the remote control button directly on going through menu and get in to the function menu. Normally all TV remote has a special button marked as "Zoom" which on pressing it once the picture get zoomed, again another press the picture gets wide and again an another press picture will come to normal mode. You should select normal mode to retify the problem.
Oct 16, 2010 | Panasonic CT-27SL14 27" TV
Picture on TV ''squeezed'' to center of screen horizontally
Check the horizontal trafo output voltage,the capacitors and the power supply voltage (135-155V dif.the tube diameter).
Aug 14, 2009 | Panasonic Televison & Video
High pitch squeal, buzz, no picture
Tossed the television and put a new one in.
May 16, 2009 | Panasonic Televison & Video
Panasonic 32" CT-32G13W
That's good you have time and patience.
You should have service manual and electronics knowledge to recognize and test / check parts in tv.
Problem is in Pin Out area of tv and you can have new parts from Panasonic Parts.
You can buy service manual from Service Manual net
Good Luck.
Dec 11, 2008 | Panasonic CT-32HXC14 32" TV
Maybe the vertical IC output are damaged you need to replace him
Sep 19, 2008 | Panasonic CT-27G14 27" TV
Panasonic CT-27G34A screen jiggles/glitches up and down slightly
Sounds like dried up cap either in vertical circuit or power supply.
Apr 27, 2008 | Panasonic CT-27G34 27" TV
Help with panasonic ct-z1410
If the picture is short top to bottom then the vertical is your problem . Check the caps in this area as they tend to become weak can't fill the verticals height . The transistor you talk about if it reads 1 ohm from the collector to the base or the emitter then the set would not work , But it will read 1ohm from the base to the emitter . Check the vertical . Good luck
Mar 14, 2008 | Televison & Video
Adjusting vertical height
I looked for info for your the Mct-2051 & imagine my surprise that Magnasonic not only doesn't have a manual for your model they don't recognize the model #. Excuse my sarcasm.
If MCT-2051 is not a typo, then the closest I could find was an MCT-2053 & there was no mention of a vertical height adjustment by software control. From my past experience this adjustment can only be performed by a TV tech because you need to access the inside of the TV.
The fact the picture has shrunk this much means that the vertical height driver is failing & eventually you will see nothing but a vertical line, stretched across the screen. Which will mean, that do to Magnasonics' lack of support, you'll be out of luck.
When shopping in the future for a TV try to stay with name brands who will support their products.
By the way, where did you hear that you could adjust the VH utilizing the remote? That could possibly be a function of digital device like a computer monitor, not an analog device like your TV.
Feb 25, 2008 | Televison & Video
Panasonic CT-32hX41 vertical picture problem (hourglass)
this product has a pincushion problem and requires servicing but unfortunatley it is what we call in the business NECO
Dec 05, 2006 | Panasonic CT-27HL14 27" TV
Televison & Video Logo
280 people viewed this question
Top Televison & Video Experts
