Question about Azpen Tablets & eReaders
My screen is stuck on azpen downloading and it won't go any further
I forgot my password for my tablet azpen model A746G what should i do?
To perform a factory data reset on your Azpen tablet, you need to backup files first from your device because it will delete all data. If you are through, you have to switch it off. Hold the volume button while you press the power button for ten times. Then press the reset button four times. Then release all buttons when it switches on. If you see the Android symbol and triangle on the screen, use your volume keys to navigate through the recovery menu. Select Wipe data/Factory data reset. Use power button. Select delete all data. Then select reboot now.
Still have any issues, you must go to customer care at +1-800-243-0051
Apr 27, 2017 | Tablets & eReaders
My tablet screen is frozen on the screen that reads azpen.when i turn it off and back on it is still frozen.it will not take a charge nor if i leave it on will the battery die.what can i do?
Hard Reset
Press Vol-up&Vol-Down button at same time, Then press the power button.
This starts your devices Recovery Mode.You can do a Wipe/Factory Reset from there. Use the Vol Up&Down buttons to navigate and the power button to select.
Be Careful and DONT MESS with the Other options or you may Brick your phone.
Apr 12, 2015 | Azpen 03038 A9 9.7" 8gb Android tm 4.0 Os...
PRICE FOR BATTERY FOR AZPEN A720
Do a google search for
Mar 06, 2015 | Azpen A720 7 inch Tablet with 8GB Memory
I can't find Azpen A740 firmware. Can I install another device's of Azpen?
Absolutely, definitely not!
Tablets are usually manufactured plain and then branded. You might find another make that shares the same hardware with the firmware you want in the public domain. The unit will then announce it as a different manufacturer's brand, but that's of little consequence.
Feb 14, 2015 | Azpen A701 7 inch Tablet with 4GB Memory
Problems with Azpen A727 tablet.
Soft Reset Press the reset button on the back of the tablet with a fine point object for about two seconds. This will not erase data store on the tablet. This may help if the screen is frozen or not responsive to touch.
Nov 24, 2014 | Tablets & eReaders
Ok I did something I should not have and now I cant get in on my Azpen a700 I was in setting and was fixin some problem and I came to the list that had to with the screen and yes I did click it now ca
I would start here:
https://www.mediafire.com/folder/gm9wb67b05bs4/Azpen_A700
Using a PC that can access the web. There are sites that have all the 'factory' software in about 10 different files. You connect to the PC using a USB port, and then 'shell' or 'command' into the Azpen with it powered on. you can then reload the software and should be good.
Another site that has Azpen support is :
http://forum.sdx-developers.com/viewforum.php?f=528
You will need some of the developer software, especially one that has the adb program to connect to the Azpen.
Oct 27, 2014 | Tablets & eReaders
How to fix an azpen a909 not charging problem?
Swap power cables, swap power outlets, and try a computer. if issue persists, then the issue is within the hardware itself and you will need to replace it.
Let me know so I can further assist.
Thanks,
Hunter Quinn
IBM Technician
Jul 15, 2014 | Tablets & eReaders
Tablets & eReaders Logo
77 people viewed this question
Top Azpen Tablets & eReaders Experts
 Mikey
Mikey
ray gallant
Outback Jack
Outback Jack
Are you an Azpen Tablet and eReader Expert? Answer questions, earn points and help others
