Question about Milwaukee Tool K06 Switch Milwaukee 6365 6370 6377 6378 Circular Saw
Remove blade on Milwaukee 6365 circular saw - Milwaukee Tool K06 Switch Milwaukee 6365 6370 6377 6378 Circular Saw
  • 3 Answers
SOURCE: Milwaukee Sawsal Broken blade
Spay inside where blade fits in with PB BLASTER & let set a while. Maybe you will get lucky & the blade will fall out as it should. If not then it will have to be dissembled in this area. There are 2 BB's inside that fit into the small hole on the blade. They are forced in by a spring, be careful not to lose these. Also check the accuatator when you pull the finger release, make sure it is going all the way or it is not broken, Good luck.
Posted on Jan 21, 2009
SOURCE: Solution for "changing blades on a milwaukee miter saw
Have you removed the old blade yet?
The blade lock my be broken off -- it should be a button on top of the motor.
This saw has left hand threads -- turn clockwise to loosen the bolt/nut.
If you can't find the blade lock, lower the saw onto a piece of wood llike a 2x4 to keep the blade from turning.
Posted on May 02, 2009
  • 34 Answers
SOURCE: miter saw motor is running back wards
DON'T BE SURPRISED IF THE MOTOR STILL RUNS BACKWARDS. YOU CANNOT REVERSE AN
AC MOTOR BY REVERSING THE POWER WIRE CONNECTIONS.
Posted on Jun 22, 2009
rowdy45176
  • 2176 Answers
SOURCE: motor on miter saw is runnig back wards
I would suggest going to Milwaukeetool.com and typing in your model number and pulling up a wiring schematic for this tool. If your switch and field are not as shown on this breakdown (its a good one) I would either take it to a repair center or change what is wrong one wire at a time. They also have a toll free number and would be more than willing to help with your problem. Let me know and have a good day. P.S. I would not run the blade backwards though.
rowdy45176
  • 2176 Answers
SOURCE: I have a Milwaukee sawzall 6509-22 with a quick
K you used the saw after inserting blade?? If so couple ideas, hold collar open and put saw blade in a vise and try pulling back on saw, or you can remove the quik lok cam and release it that way, its not that hard, but I would try vise first. Let me know
Posted on Jul 29, 2009
I have a Milwaukee circular saw, 6365, and am replacing the switch. Need a wiring diagram!
Scott,
What is the serial number on your saw? I need that to make sure I get the correct info for you.
May 30, 2015 | Milwaukee Tool Saws
How replace blade on 7 1/4 circular saw - Milwaukee
UNPLUG THE SAW first!! Look for the blade lock on the top or front of the motor body, Hold the lock button down while turning the blade nut with a wrench. After a bit you'll feel the lock button engage and hold the blade firm. Rotate the the wrench counter clockwise and remove the nut, Slide the blade out from under the guard and replace with a new one. Reinstall the nut following the above procedure.
Sep 15, 2014 | Milwaukee Tool Saws
Milwaukee sawzall blade
Cut or snap the blade off at the end so you can get the holder apart. I have had to do this before. Usually you can just use a set of pliers and work the blade back and forth until it snaps off but I just use an air powered cut-off tool and cut them.
Aug 05, 2012 | Milwaukee tools Milwaukee 6509-22...
Saw won't turn when blade is attached, just clicks?
Dose it spin with the blade off. If so then the blade is bent take the blade off and put it on a flat surface if it dosn't lay flat you need a new blade.Even if you could strighen it enough to rotate it wouldn't cut vary good and wouldn't be safe to use.
Jan 24, 2011 | Milwaukee Tool 6310 20 Saw Circ 6 1/2 18V
I have a Milwaukee circular saw model 6365. It still cuts fine, but it squeals loudly (like a little girl) when running. Sorry, couldn't help myself. Seems like the motor bearing(s) need lubrication. ...
You can try to lube the bushings, but they will always start to squeal again. I have tried just about everything, 2 cycle oil works good, wd-40 is a little thin, blaster works ok for a while, reg 3m oil forget it, motor oil, no, white grease, hard to get in there, axle grease, yes, but you have to take the bushings out. The oils, you don't have to take the saw apart. Hope this helps.
Aug 18, 2010 | Milwaukee 0730-22 V28 6-1/2" Circular Saw...
Cant push in the release button to take off the blade on a Ridgid R3200 circular saw
Happens to my Milwaukee sometimes. Spin the blade around (by hand) while trying to push in the lock button. That will usually engage it. If not, the old-fashioned way of wedging the blade against the base with a piece of scrap wood always works
Nov 27, 2009 | Ridgid Saws
Blade running the wrong way
the field is in upside down, remove it and rotate it 180 degrees. Let me know
Nov 05, 2009 | Milwaukee 0730-22 V28 6-1/2" Circular Saw...
I need a wiring diagram for a milwaukee heav duty circular saw
It is probably something like a 6365 and on all the Milwaukee products they have a switch wiring diagram but nothing for the switch. I would recommend going to a local repair center with the switch and match it up with a new one probably less than 15.00 If you give me your location with zip code I can direct you to the closest one. Let me know
Apr 08, 2009 | Milwaukee 0730-22 V28 6-1/2" Circular Saw...
Milwaukee Tool K06 Switch Milwaukee 6365 6370 6377 6378 Circular Saw Logo
82 people viewed this question
Top Milwaukee Tool Saws Experts
Jim Thurston
Dave
Level 1 Expert
JOHN LAPIER
Are you a Milwaukee Tool Saw Expert? Answer questions, earn points and help others
