this is my problem in my NEC VersaPro NX series, Why I could not PLay Call Ot duty
COD MP 1.1 build win-x86 Oct 8 2003 ----- FS_Startup ----- Current language: english Current search path: D:PROGRA~1CALLOF~1mainpak6.pk3 (3 files) D:PROGRA~1CALLOF~1mainpak5.pk3 (4858 files) D:PROGRA~1CALLOF~1mainpak4.pk3 (1668 files) D:PROGRA~1CALLOF~1mainpak3.pk3 (1992 files) D:PROGRA~1CALLOF~1mainpak2.pk3 (694 files) D:PROGRA~1CALLOF~1mainpak1.pk3 (2642 files) D:PROGRA~1CALLOF~1mainpak0.pk3 (12828 files) D:PROGRA~1CALLOF~1/main D:PROGRA~1CALLOF~1mainlocalized_english_pak1.pk3 (3736 files) localized assets pak file for english D:PROGRA~1CALLOF~1mainlocalized_english_pak0.pk3 (1204 files) localized assets pak file for english
File Handles: ---------------------- 29625 files in pk3 files execing default_mp.cfg couldn't exec language.cfg couldn't exec config_mp.cfg couldn't exec autoexec_mp.cfg ========= autoconfigure configure_mp.csv: using configuration 0 cpu MHz 256 sys MB 64 vid MB execing configure_mp.cfg fs_basepath is write protected. fs_homepath is write protected. Hunk_Clear: reset the hunk ok ...detecting CPU, found Intel Pentium III Measured CPU speed is 0.16 GHz System memory is 320 MB (capped at 1 GB) Video card memory is 64 MB Streaming SIMD Extensions (SSE) supported
Winsock Initialized Opening IP socket: localhost:28960 Hostname: experien-3a00f3 IP: 127.0.0.1 ----- Client Initialization ----- ----- Initializing Renderer ---- ------------------------------- ----- Client Initialization Complete ----- ----- R_Init ----- Initializing OpenGL subsystem ...initializing QGL ...calling LoadLibrary( 'C:WINDOWSsystem32opengl32.dll' ): succeeded ...setting mode 4: 800 600 FS ...using colorbits of 32 ...calling CDS: ok ...registered window class ...created window@0,0 (800x600) Initializing OpenGL driver ...getting DC: succeeded ...GLW_ChoosePFD( 32, 24, 8 ) ...35 PFDs found ...GLW_ChoosePFD failed ...GLW_ChoosePFD( 32, 24, 0 ) ...35 PFDs found ...GLW_ChoosePFD failed ...failed to find an appropriate PIXELFORMAT ...restoring display settings ...WARNING: could not set the given mode (4) ...shutting down QGL ...unloading OpenGL DLL Forcing 640x480 resolution to allow OpenGL to run in fullscreen ...initializing QGL ...calling LoadLibrary( 'C:WINDOWSsystem32opengl32.dll' ): succeeded ...setting mode 3: 640 480 FS ...using colorbits of 32 ...calling CDS: ok ...created window@0,0 (640x480) Initializing OpenGL driver ...getting DC: succeeded ...GLW_ChoosePFD( 32, 24, 8 ) ...35 PFDs found ...GLW_ChoosePFD failed ...GLW_ChoosePFD( 32, 24, 0 ) ...35 PFDs found ...GLW_ChoosePFD failed ...failed to find an appropriate PIXELFORMAT ...restoring display settings ...WARNING: could not set the given mode (3) ...shutting down QGL ...unloading OpenGL DLL ----- CL_Shutdown ----- RE_Shutdown( 1 ) ----------------------- Hunk_Clear: reset the hunk ok Could not load OpenGL. Make sure that you have the latest drivers for your video card from the manufacturer's web site.
my curser will not move. I clicked function key and the lock and it goes to a screen where the only...
(More)
my curser will not move. I clicked function key and the lock and it goes to a screen where the only thing showing is an owner locked icon and words owner lock. the curser will move on this screen. if I click owner lock it goes back to the locked screen
the internal mouse pad will not turn off...even when you hit the button below space bar and the...
(More)
the internal mouse pad will not turn off...even when you hit the button below space bar and the slide bar to the right of the mouse area does not work
