Question about Plumbing
How to lubricate a binding spout in a KWC Domo faucet
3 Suggested Answers
  • 17 Answers
SOURCE: Sticking of KWC DOMO model faucet.
I would definitely take it apart to find out what is causing it to bind, that is not normal. Make sure that you turn your water supply lines off under the sink, via angle/strait stops. From under the faucet there is one or two nuts fastening the faucet to the counter, they are usually screwed on just a little more than hand tight. The problem may not be fixable, so be prepared to replace the faucet.
Posted on Mar 19, 2010
Just received the new part for the domo. My model is older and is chrome with black. I have removed the top screw and need to know what is the next step in taking apart the rest of the faucet so I can replace the new part # k.32.60.00
Thank you, Stuart
Posted on May 29, 2010
My KWC Domo faucet leaks when pull out is in spray mode is this an easy fix
Probably needs at least one new rubber seal, you'd probably contact your supplier.
Various spare parts are shown in this manual (attached):
Jul 10, 2016 | Plumbing
Installed a new KWC Domo faucet and its leaking (alot) under the sink
Does if have a sprayer and is it still hooked up?
Aug 14, 2014 | Plumbing
New kwc domo leaking under (alot) sink
mixing chamber of the faucet may be cracked
Sticking of KWC Suprimo faucet
My bathroom faucet handle (not same brand as yours) was so hard to turn that it pulled the base around with it on the vanity when I jerked it. I used an Allen wrench to take out one of the set screws holding the handle on, put the tiny straw of a WD40 can in the set screw hole, squirted WD40 inside the handle, replaced the setscrew, and worked the handle to and fro a few times to lubricate the inside. No more sticking!
Feb 22, 2014 | KWC 10.271.333.700 Suprimo Kitchen Faucets
My husband installed a new KWC Domo faucet in our kitchen yesterday. When he was finished, he turned the faucet on and got a trickle of water. We are stumped and the instructions are no help.
Take off the aerator from the spout (it just screws on, and should not be so tight you need a wrench) and then run the water. You'll probably find the aerator screen is clogged with debris and you can wash it off. This often happens when you turn the water supply off to connect the new faucet. After you clean off the aerator and screw it back into place your new faucet should work fine.
Feb 27, 2011 | Microwave Ovens
KWC Domo single handle faucet is sticky...how do I fix that? Do I have to replace a cartridge?
Have the same issue. No one seems to have an answer, including KWC (except to buy a new $90.00 cartridge).
Nov 09, 2010 | Danze D403412 Melrose Single Handle...
Thank you, Stuart
May 11, 2010 | Delta Model 470: Signature Kitchen...
Mar 19, 2010 | Delta Model 470: Signature Kitchen...
KWC Domo faucet sprayer won't switch between spray and stream
Having installed and fixed kwc domo faucets for years I'd probably take the spray head off of the hose, then look into the bottom of the spray head and see if the check valve is still there. It probably is. I used to use a thin screwdriver to pry the check valve out out.It will come out. You need to work at it a bit but these hold back a lot of water pressure and catch any crud coming down the water lines.
TL
Mar 17, 2010 | Plumbing
Plumbing Logo
125 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
