Procom md200tbe heater
The pilot light lights the burner yet continuously goes out after having been lit for several moments thus shutting off the unit. How do I stop this?
SOURCE: Pilot light goes out!
Try cleaning the orifice . I use a twist tie wire off a loaf of bread . Careful, dont damage it .
Posted on Nov 10, 2007
  • 41 Answers
SOURCE: pilot light wont stay lit once heater shuts off/ light goes off randomly
Hi Watertec00,
I am not familiar with this heater but it sounds like it could be a blockage in the main gas line into the heater or perhaps a blockage to the pilot gas line and maybe starving for gas. Best bet first is to check the main gas line from the heater. Easiest way to do this is to remove it from the heater and blow it through with compressed air. Then try the heater again. If that doesn't fix the problem then you can try blowing compressed air down through the pilot line. Could be a little dirt creating a blockage there. Then try the heater again. If it still does the same thing then try removing the panels to expose the heater's piping. If you can remove the main pipe into the heater from the gas and blow compressed air through it it should clear any obstruction from both the main line and the pilot. If this doesn't work then I would think you have a more severe problem and will need to take it to your local Heater Repairer. Hope this helps.
Regards
Bryan
Posted on Dec 22, 2007
SOURCE: Pilot goes out!!
My manual shows three possibilities:  1) Insufficient fresh air available for combustion, so ODS kicks off gas flow 2) Low gas line pressure (should be between 11 and 14") or 3) ODS/Pilot is partially clogged.  Toll free number for ProCom is 877-886-5989.
Posted on Dec 14, 2008
zonaluver
  • 7 Answers
SOURCE: Torpedo heater wont stay lit.
Do you have the serial number or the manufacture date? There are some design changes and I would need to know the year of manufacture to assist accurately. Usually it is a relay or the thermocouple connection that will affect the unit staying lit.
Posted on Mar 29, 2009
  • 139 Answers
SOURCE: Pool Heater Light main burner then goes out
take millivolt reads while main burner is on.i suspect you will see a drop in voltage until you get to point where it will no longer operate burner(around 200mv).if this is the case you probably have poor pilot characteristics due to dirty pilot,pilot out of adjustment ,obstruction or insufficient gas pressure
Posted on Jun 21, 2009
Heater serial # 3687823 was working fine then just stopped. cant get it to light now
if the pilot lights when held but wont stay lit, the thermocouple is shot, local hardware stores sell universal thermocouples. self explanatory to replace. if even when pressing the button the pilot doesn't light there is a blockage in the gas line or control valve. that needs a pro to fix.
Mar 16, 2014 | Procom Heating & Cooling
Burner won't light, pilot is burning just fine.
Once you get the pilot to light and stay lit did yall move the burner knob to the ON position? Is the temp knob all the way up?
Nov 27, 2011 | Procom Heating & Cooling
We have 14 ProCom heaters, second cold season...we are having trouble keeping some of the pilot light lit and shutting off after several seconds. The gas pressure in the building is 7.5 lbs and the...
the pilots should be clean ,they should be playing on the thermocouple if this is so then it could be new thermocouples if it was a pressure problem nothing would work , as it 1 , 6, 9 ,11, it could just be dirty pilots hope this helps
Jan 03, 2011 | Procom MN300TBA Heater
My pilot light ignites but when you turn the knob to light the burner it goes out?
Your pilot generator may be the cause. They tend to get weak and will hold the pilot but won't be strong enough to operate the gas valve solenoid. All space heaters have some sort of thermocouple device in the pilot that hold the gas open as long as the pilot is lit. Some simply hold the gas valve open while others called millivolt valves use a pilot generator to operate the solenoid. Another type of heater is an ODS type. This system has a oxygen depletion pilot safety feature. When oxygen gets low the pilot shuts down the gas. If this is what you have then all you need to do is blow the dust out the pilot and it should stay on.
Dec 05, 2010 | Procom ML300HGA Heater
Pilot light won't stay lit.,and shuts heater off when it goes off.
Could be the thermocouple...or the gas regulator....there should be a troubleshooting guide in your manual that should help you diagnose the problem. If you dont have a manual check out the Procom Website and click "Customer Service" then go to the manuals. Hope this helps!
Mar 12, 2010 | Procom Heating & Cooling
HEATER AND PILOT GOES OFF AT TIMES
Sounds like your oxygen depletion sensor is shutting your unit off. The problem with fixing your unit is that it may cost you the same to purchase a new one (assuming you pay someone to fix it).
Feb 16, 2009 | Procom ML060HPA Heater
ProCom blueflame heater pilot light difficult to light
You pilot ignator is plugged.I take a small wire and run it in the hole every year and I also Blow the heaters out real well with air.THis has always worked far me.I need a phone number or email address to Pro Com because i'm having problems with a new one i just bought and I can't find the papework.Could you pleas eif you have this info email it to me
Good Luck
Jay
jaycalk@yahoo.com
Jan 07, 2009 | Procom (177653) Utility Heater
Burner won't light
I left it off for a couple hours and it fired back up.
Nov 08, 2008 | Procom ML300HGA Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
