PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Laptop LCD Problem
By lgunnz on Sep 28, 2007
My laptop took a fall and now the monitor is difficult to see. I've tried system restore, updating drivers, brightness hot keys, and windows troubleshooter with no luck.
Same Problem
Jan 14, 2009
-   same-   Guest
Dec 27, 2008
-   my pc dropped and the whole screen turned black... but there was still all of the icons and they were visible, but the screen was dark... the brightness keys did not effect the screen
-   Guest
May 31, 2008
-   The same thing happened with me...i fell and took the laptop with me :( Could not affect the brightness with the brightness keys. -   Guest
May 19, 2008
-   trying to find the constrast button-   Guest
Feb 15, 2008
-   what f key do you use to restore my notebook system. I can't acces the internet I have the icons but I can't access.-   acosta0905
Best Solution
posted on Oct 02, 2007
Very Helpful)
mryozo
Rank: Apprentice
Rating: 100%, 1 votes
Hello:
This is not a solution to your problem, but it will resurrect your screen. Turn off the Laptop, disconnect it from power supply if its pluged and switch off the battery from the Laptop. Then, with the battery outside, connect the laptop switching to power grid (of course, using your ac adaptor). This is like a weird hardware reset due to a strange problem between battery charging and operting Laptop. I'm researching that stuff because i suffer this problem too. If I found a definitive solution, I will comunicate here. We must investigate to find out where is the f...g bug!!!
Comments:
Mar 17, 2008
- Hey, good news dudes. I finally fix it!!! It's easy to solve but it's a little bit tricky to open the notebook screen. I'll try to explain what I've done to fix that problem.(Sorry for my english,I'm still learning)
THIS IS THE HOWTO'S FIRST PART, TO BE CONTINUED IN A FEW HOURS. NOW IT'S TIME TO GO TO CLASS.SEE YA.
First of all, remember that the problem in my HP Compaq NX5000 was in the screen, because everyday had the same stupid trouble: the screen seem to switch off and switch on like a damaged bulbe light or neon tube,randomly, even if you don't touch the screen at all or move the laptop. So, I decided to dismantel my laptop, to search a bad contact between the laptop's mainboard and the TFT screen, because I suposed this probably was the problem. Here's a little HOWTO, only suggested to experienced people, because is easy to break plastic pieces from laptop if you aren't experienced enough.
0.Take a good place to operate, a good table, good lightning and a good set of screwdrivers and a empty cup or something like that to contain all the screws that you remove (They are too small and it's easy to loose them)
1.Remove all power supply and battery cell from laptop.
2.Touch the ground to discharge all static electricity that your body can store, avoiding high power discharges over the hardware.
3.Now you must remove a set of screws from laptop's behind side: those labeled with a keyboard sign and specially all near power supply plug(3) and around USB and VGA connectors(+3). Those are the most importants because when we take off that screws, we can release 3 components to start the job.
Now, open the laptop and using a plane screwdriver or something like that,trying to release the silver plastic piece that contain the switch buttons (power,wifi).Use the screwdriver in the slot between black and gray parts to help in the extraction of the gray section(remember,only the buttons container).Be careful on break that piece becasue it's fragile, and if you expect that will broke, test again the screws that you must already removed.(this must be a constatn checking in all the process:Don't force plastic, be patient and check all screws).
4.It's time to release the keyboard, so take care with this: the keyboard is connected to the mainboard by a special membrane connection. To release that membrane, where it's conneted to the mainboard, you must locate a plastic piece that acts like a secure to avoid accidental switch off. Pull Lift this piece of plastic.If you have released the marked screws, the keyboard is loose and you can easily pull off.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jun 26, 2009
Not Rated)
Cainaphile
Rank: Master
Rating: 70%, 4 votes
If your screen has lost its brightness making it hard to see and your hotkeys are not working, go to your battery symbol on the taskbar, right click, then power options, then on the left side of the window there should be an option the adjust the display brightness. hope this helps =)
Was this helpful?
Yes
No
Solution #3
posted on Sep 28, 2007
Not Rated)
Techwildcat
Rank: Wiz
Rating: 84%, 87 votes
Hi, it sounds like physical damage has taken placed in the screen. You will need to contact the tech support of the laptop at this point. They will tell you whether or not it needs to be replaced. I'm sorry to say that damage to LCD screens on laptops is for the most part permanent.
Sorry for the bad news.
Regards
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
I am looking for a TRUE desktop-replacement. I am looking for a quad-core min 4. GB of DDR3... (More)
Answer
the best site i have ever visited,,, thanks fixya guys
Answer
What should I check if my Dell Latitude D610 wil lplay dvds but will not read cds?
Answer
Thank you for your post. It was easy if I could find webcam settings, and flip it around as you say... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Laptops:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
