Question about Whirlpool Ovens
Felkod F8 induktion - Whirlpool Ovens
I have problems with my Hotplate!!!!! Name of the hotplate is just Induktion. The Hotplate is a Induktion and after a moment of heating it starts to blik and shots down with the Error: E R
From my previous mechanical engineering work, and have maintained a few of similar problems, but different maker. I found one one thqat it was not properly wired, check the owners manual and go over wire diagram. Secondly, is the kitchen on the other 2 I did the breqaker for that room was way over loaded, and sometimes it will shut your equiptment down b3efore the breaker goes off. This is because when the element reaches a certain tempature, or even rising in tempature the stove will kickback, almost like a car going into safemode, so it does not destroy the stove. I had to call an 3electrician, because3 I am not a certified elec.
Dec 26, 2012 | Ovens
F8 code on my frigidare double oven after cleaning with self cleaning oven ....know this is in the lock but need to know how to fix it myself left it unpluged overnight plugged back in and its still f8...
Hi
Yes F8 is oven door lock error warning.
You need to physically check the door switches and lock relay, these will be inside the oven casing.
It is probably not the easiest of diy jobs as everything is concealed.
Dec 16, 2010 | Ovens
We preheat oven 325 after 10 min. it shuts off and beeps with F8
This is what a F8 fault says for that unit:
F8 Analog / Digital problem Replace clock (ERC).
Jul 18, 2009 | Jenn-Air JJW8230D Electric Double Oven
F8 on my Ge true temp oven
F8 is the code for a bad clock/control. Hope this helps!
Jun 26, 2009 | Ovens
GE lower oven displaying code F8. Clear off does not clear code
Your ERC(clock) has failed. Replace the electronic oven control.
May 26, 2009 | GE JRP15 Electric Single Oven
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
Beeping sound and f8 displayed
F8 means to replace the elctronice range control board. Evidently the power failure caused damage to the board.
May 24, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Error Code F8
F8 Analog/Digital supervisory Replace clock assembly (also called the ERC)
ohhh thats not good, escpeccially with company coming, replacing the clock appox 175 for part, def wont happen by tommorow nad no you cant separate the 2 ovens both ae wired together
Mar 15, 2008 | Jenn-Air JJW8230D Electric Double Oven
F8 malfxn code
replace control board.
Dec 05, 2007 | GE JRP15 Electric Single Oven
Ovens Logo
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
