Question about Ovens
Oven wont heat up on my zenith 60 leisure ze6hv
3 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: can`t get oven to heat on zenith 60
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case....
Posted on Nov 03, 2009
Testimonial: "thanks it was a loose wire as you explained it might be."
SOURCE: leisure levc66x - bang from fan oven blew
It appears that the ring element for the oven has burnt out and will need replacing.
Hope this helped.
Posted on May 16, 2010
Have Ck90g232 model,electric oven has no heat,the fan still works but not the light. All other ovens and hobs are functioning,is this an element issue and will a professional have to fix the problem?
The light may just be a burned out light bulb. Remove it and take it to an appliance store to find a replacement. As far as the oven goes, elements do burn out. They are relatively inexpensive. Make sure you have turned the oven OFF before you do anything. The heating elements do pull out and you can replace them yourself. Take the information about your oven and the heating element to an appliance store for a direct replacement.
Nov 15, 2017 | Ovens Ovens
My leisure 101 fan oven is not heating up the fan is coming on but not getting hot
Probable element has failed. Replace the element after testing it of course.
May 06, 2017 | Ovens
My leisure GRB6CVK electric oven(main oven) has stop heating up. Fan and light works but no heat. Help pls. Any thoughts. Sheryl
Unplug stove and take wires off element. test for continuity on the poles. Also check wire ends.
May 24, 2014 | Ovens
Top oven wont stay alight
Seems the Thermocouple (instrument that lets the oven know the gas is lit) is not working properly. Your ignitor is working thus allowing the gas to burn...but the heat is not moving down the thermo line to register as being lit. Thus the oven thinks gas is being pumped but not burning and turns off as a safety precaution. THere must be a thermostat sensor...usually a wire or tube that allows the heat from the burning flame travel towards a sensor...this is faulty...remove and replace.
Dec 02, 2013 | Ovens
Flavel milano 60 manual
Keep in mind that Flavel Ovens are built by Leisure CP. This link could helpfull: upl/26348-Range60Leaflet.pdf
If this information isnt help, this and other manuals could be find sending a request here.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 17, 2011 | Ovens
Oven takes too long to heat up sometimes wont even go to the temperature ignitor is working well can see the glow magic chef model 3488vvv serial 13368882kz
Hello there:
When you turn the oven on, open the oven door and look down at the bottom and see if its glowing red, it should glow red for about 45-60 seconds then you should hear the gas ignite. If the gas doesn't ignite, then your igniter glow bar is bad.
Here's the oven glow bar igniter for your model:
Manufacturer's Number: 74007498
show?id=yo6223wzsty&bids=142421.661381148&type=10&subid=
partimage.aspx?imgid=z3bqljbfbxnfodk0nzawndcvq0fnl3nvdg9ochryyxav
show?id=yo6223wzsty&bids=142421.661381148&type=10&subid=74007498
Sep 28, 2010 | Ovens
Location of thermal fuse in leisure cookmaster range cooker
where is the thermal fuse located in a leisure cooker
Jul 22, 2010 | Ovens
Leisure levc66x - bang from fan oven blew tripswitch - fan operating but no heat - top oven ok - 18 month old unit
Hope this helped.
May 13, 2010 | Ovens
Can`t get oven to heat on zenith 60
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
Nov 03, 2009 | Ovens
Oven wont heat
check the outlet for 220 and the power cord
May 25, 2008 | Ovens
Ovens Logo
27 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
