Question about Jensen JR400 Remote Control
Holmes hasf 1717 in op. Batteries have been replaced
Why is my Holmes HASF-1710 not getting power
This may be a duplicate post but here's my advice. Do a little disassembly to get to the "guts" of the fan. It is not uncommon for the speed control switch to break in such a way as to not allow the circuit to be completed. You may have to actually remove the switch and inspect it to be sure of this. I've had trouble finding replacement switches so I have put them back together with superglue. If this is your problem and you choose to use this solution just be sure all the switch parts get put back where they belong. If this is not your problem, break out the ohm meter and start checking your connections. Hope this helps
Jul 06, 2014 | Holmes Products HASF1516 Stand (Pedestal)...
How do I get the housing off my Holmes hasf 1301 fan?
try turning it counter clockwise no need to be gentle.
Apr 09, 2014 | Oasis Hunter 54' Ceiling Fan
Holmes hasf 1701
this is special operation, you must have skill for to do this. You can use jering with oil and lubricate the house motor is more easy and more efective. Unless the motor is faulty. In that case will be replace it.
God bless you
Jul 11, 2013 | Dryers
At&t 1717 after power failure get beeps and flashing "E2" code. 1717 no longer responds to any command.
Please check the manual, or download it here. At page 7 of the manual, theyl mention you need to call a service-number for help, concerning E-codes.
Oct 10, 2012 | AT&T 1717 Digital Answering Machine
Hello. I have a stand (pedestal) Holmes fan, model number HASF-1516, that is not working when plugged in to the electrical socket. How do I go about troubleshooting?
Firstly please make sure that you connecting wire in not cut at any where and connection is good.
If your connection is ok then also it doesn't rotates then might be your coil has been burned and you need to replace its wiring and check the starter
Aug 18, 2011 | Holmes Products HASF1516 Stand (Pedestal)...
Hi, I have a pedestal fan (16") for which am looking for spare parts. I need - fan blade (5 blades) - the clips that hold the base grill and the front grill Make: Holmes Model:...
Seriously?? It's a $30.00 fan. IF you could get parts for it, they'll cost you more that the original price of the fan, but I guess if you insist. Go here and call them or chat online, they'll tell you if parts can be had.
https://www.holmesproducts.com/fans/
Jun 09, 2017 | Holmes Products Dryers
We have two holmes fans and they both stopped working within the same week, we replaced the batteries and nothing and we tried to manually start them and nothing; any ideas>
mcdevito75 here, You say you changed the batteries in both fans, tried to spin the blades and no start., Double check battery install, try another set of batteries even new batteries from the store can be weak or even dead as batteries have shelf life of, not too long. Spin the fan blades as fast but as safe as possible by hand with the on /off switch off, and listen for any noise from the fan motor, a sraping sound, or whistle could mean a bad motor. Lastly, bring the fans to a Staples, they will be glad to test them, a Radio Shack also can test the fan motors.
Jul 28, 2010 | Holmes Products HAPF622R Floor / Box Fan
What is the DC voltage needed for AT&T 1717
The AT&T 1717 requires 9 Volts _ AC.
Too bad some solutions are provided with inproper information.
I have a 1717 and just replaced the AC adaptor so I speak with experience.
Feb 22, 2010 | AT&T 1717 Digital Answering Machine
Jensen JR400 Remote Control Logo
27 people viewed this question
Top Jensen Televison & Video Experts
Jaime Hernandez
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
