Question about Global ICP GLOBAL TECHNOLOG Sunsei Solar Panels & Panel Kits SE-6000 Solar Panel
What does it mean wp 5w voc 24volts v spec 15volts
Pilot on but does not light up furance
check all safety switches that is in line with gas regulator to make its not open. if all switches are closed then check at gas valve or regulator you should have 24volts. if you get 24volts there that mean you gas regulator is defected.
Jan 18, 2015 | Heating & Cooling
I need help to reset password Client - N380 from thinstation
This is the spec for the device
Model
Thin client NP-N380
Stand-alone operating system
WIN CE 6.0 OS
Maximum Users
Unlimited
CPU
ARM11 800HZ
RAM
128MB
STORAGE
128MB
Audio output
yes
Audio input
Yes (except remote desktop connection)
USB Port
3 or 4
COM TAP
Derivable
Support scanning gun
YES
Support touch screen
YES
Support printer
YES (Network printer)
Power input
5V~2A power 5W
Communication distance
Network Cable biggest communication valid distance
Size(mm)
115*115*26
Support Max resolution
1280*1024or1440*900@24 color depth
Whether to support the latest system patch
support
WIFI
Optional(150Mbps)
Support of the operating system
win xp/2000/2003/7/vista/2008
Keyboard mouse port
USB
Whether can do secondery development
YES
Whether could do USB upgrade
YES
Get the password from this documentation.
http://www.thinclientech.com/wp-content/uploads/2014/01/N380-Manual-Instruction-Embedded-Technology.pdf
Sep 26, 2014 | Computers & Internet
How do I convert the .voc to an mp3 file? I can not even open the .voc file.
you must copy the files into PC and after that you must use an audio files convertor. ( http://www.fileinfo.com/extension/voc) or use winamp Media player 5.6, videolan VLC media player to open the .voc files
Mar 29, 2011 | RCA VR5230 Voice Recorder
What are the recommended engine oil specs
All temps...5W-30....
SAE Synthetic 5W-30 is the recommended oil to be used.
Nov 13, 2010 | 1995 Honda Accord
What oil to use for a passat 1.9 tdi 2003
In order of preference:
Amsoil 5W-40
Valvoline 5W-40
Both meet the VW spec.
Oct 16, 2009 | 2003 Volkswagen Passat
Can 15 volt power adaptor be used on an 18volt scanner?
you dont have other choice, how about to buy an multi plug-in adaptor from 3V up to 23V can manage the voltage of your scanner, but if not this 15volts can support your scanner..
Jun 22, 2009 | HP ScanJet 2300C Flatbed Scanner
What power supply needed?
Here is the site that give you the specs on your laptop. You have a LL Series laptop and the specs is the very first AC Adaptor you see in the list courtesy of laptopacadaptor.com This is the specs and you can verify it at the link below.
15-24Volts 5Amps 90 Watt Max
http://www.laptopacadapter.com/nec.html
Feb 15, 2009 | Intel Computers & Internet
Convert .voc to .mp3 format
VOC format is not a commonly used format, most popular player software(Windows Media Player, Quick Time, iTunes, etc) and devices(iPod, iPhone, Zune, etc) do not support this format. To play VOC files in these software or devices, you need convert them to popular formats such as WAV, MP3, M4A, etc.
The following introduces a step by step guide about how to convert VOC to MP3.
VOC File Format
Mar 03, 2008 | RCA RP5020 Digital Voice Recorder
Global ICP GLOBAL TECHNOLOG Sunsei Solar Panels & Panel Kits SE-6000 Solar Panel Logo
Top Global Electrical Supplies Experts
Steve
Gene Haynes
Are you a Global Electrical Supply Expert? Answer questions, earn points and help others
