Question about Black & Decker & Leaf Hog Blower / Vacuum
How do I swith the vacuum to blower - Black & Decker & Leaf Hog Blower / Vacuum
How to replace the swith vacum craftman model113.177765
I suggest you go to Sears repair parts website. They have parts for most stuff they sell, plus a lot for other appliances, etc. I hope this helps.
Apr 01, 2014 | Craftsman 17765 Canister Wet/Dry Vacuum
Swith on change on the control don,t change from cleaning to rinse
You may want to contact a BISSELL Authorized Service Center to have a qualified technician inspect your machine.
Here's a quick link to locating one. http://www.bissell.com/service-centers/?cid=ccsocial
Jan 06, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Why my heater blower fan inside the car do not run when i switched on
try cheaking the fuse if not the blower motor its self has gone and need replacing
Sep 21, 2012 | 2006 Suzuki Grand Vitara
Blower swith in position 1,2,3 no blower, in
Check the cover for the environmental cabin filter. It is located on the far right side of the cowling right below the right windshield wiper. There are a few torx screws that secure the cover and then it pulls out to reveal the cabin filter. The cover (being poorly designed by VW) cracks and during rain the rain runs off the window and soaks the cabin filter. The water from the soaked filter then drips down into the blower motor and shorts out the resistor module at the bottom of the blower motor. The blower will continue to operate at full speed because it is operating on an open circuit without need for resistance for the resistor pack. There is a small access "panel" at the bottom of the blower motor you will need to remove in order to see the problem, you should see a frighteningly burned looking module in there. Good Luck! Hope this helps!
Nov 20, 2009 | 2000 Volkswagen Jetta TDI
The blower stoped working in my 1999 astro, no heat, no air, no nothing. is it more than likley the blower motor?
Yes and No. They like to burn up the resistors, swithes and blower motors! You will need to trace it down. See if you have power at the blower motor, if not then start working your way back. It's alot easier to get to if you pull the coolant and washer resivor's out, then you have good access to the blower and resistor!
Nov 01, 2009 | 1999 Chevrolet Astro
Blower motor stays running
by now u figured out that you pull the 30amp fuse from the panel on passanger door size of dash
the lower blower motor operates on another 15amp fuse
Jun 26, 2009 | 2000 Buick Century
Blower switch where is the relay to change
I think its behind the glove box
did you check the fuse?
Oct 08, 2008 | 1997 Ford Escort
Vacuum or Blower?
* Blowers perform the single, simple function of blowing material. * Blower/vacuum combinations combine the blower function with a vacuum feature. Leaves or debris can be directed into an attached bag, which makes this type of unit great for vacuuming leaves from shrubs. An additional mulching feature is available on some leaf blower/vacuums. Mulched lawn debris can be used in compost piles or bagged for disposal. Most convert easily from blowing to vacuuming mode.
Aug 27, 2008 | Toro Lawn Mower With Toro Power Tools
Black & Decker & Leaf Hog Blower / Vacuum  Logo
52 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
