Question about Canon imageRUNNER C5180 Color Copier
5180 cannon feed trays not moving correctly - Canon imageRUNNER C5180 Color Copier
Cannon IR 1600 Rec paper jam message.no any paper find. how can i solve this problem?
Yes, often it is not a paper jam but a fail of paper to feed out of the tray which the machine thinks it has a jam. Clean feed rollers with Windex, or alcohol. Check the paper tray to see if paper size panels are set to the correct position. portrait, landscape, width length ect.. Good luck.
Jan 08, 2016 | Cannon Office Equipment & Supplies
Cannon pc 921 won't feed paper from tray or bypass, shows P for out of paper but tray is full I can't find any jam
Try cleaning the feed roller using ammonia solution. The sizing used in the manufacturing of paper has waxy substances that accumulate in the pores of the rubber rollers and reduce the friction on the feed roller..
May 29, 2014 | Canon PC-921 Black and White Copier
INSTRUCTION MANUEL
I have a friends Baby lock BL 5180. She could not get it to work so I brought it home. I thought it was probably just the way it was threaded so I rethreaded the machine and noticed that the feed dogs are not moving. The machine works but will not pull the material into the machine.
Oct 29, 2013 | Baby Lock Eclipse Serger
I would like to downlode cannon c 5180 printer driver
easiest way is to visit cannon website. all drivers are on there.
Feb 09, 2012 | Cars & Trucks
My paper seems to not want to feed properly it suddenly shifts to the side....Cannon ip3500
Make sure that the paper guide is up against the right hand side of the paper in the feed tray. You should not be adle to move the paper sideys in the feed tray. If you can, the guide is not set right.
Feb 11, 2011 | Office Equipment & Supplies
My baby lock 5180 isn't pulling my material through to serge
I have the same problem. The feed dogs are not moving.
Jan 12, 2010 | Baby Lock Eclipse Serger
How do you load the paper in cannon ip1800
If the paper is loaded correctly--that is, placed in the paper holder and the side guides are tight against the paper, then the printer may need cleaning or it is defective. Check that there is not too much paper in the tray.
Many time the little rubber rollers that grab the paper become glazed and will not pick the paper up. Also, the feed mechanism may have just worn out.
If this is an older printer, it might need to be replaced if you can't find a shop to clean it for you.
Feb 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon mx700 can i use the rear verticle paper feed as an alternative to the front bottom horozintal paper feed
Yes, use the "feed switch" button on the front of the printer. There are small lights that indicate the paper tray to be used.
Sep 24, 2008 | Cannon Office Equipment & Supplies
HP 5180 Printer
are you using only that size paper when printing. if there's another size underneath, then you're going to see some slippage.
got fresh printer drivers?
Jan 14, 2008 | Dell A920 InkJet Printer
Cd tray not feeding
I had the same problem. My printer was sitting too far back in the cabinet and the cd tray was hitting the back wall when it was pulling it throuh. I moved the printer forward and the obstruction in the back was no longer an issue. It started printing all cd's just fine.
Jul 17, 2007 | Epson Stylus Photo R220 InkJet Printer
Canon imageRUNNER C5180 Color Copier Logo
14 people viewed this question
old marine
old marine
