Question about Remington Polesaw Wizard
Broken latch lever - Remington Polesaw Wizard
How to open zetec bonnet with a broken pull lever
From the bottom. Few times have I seen it broke at the latch. Reach up and cut the cable in half( as far as you can away from the latch). Then cut a couple inches of the cable sheathing of at the latch side. expose the cable, then pull the cable to open. If it did break at the latch, then you'll need a long pick(right angle or hook). You'll have to reach up in the latch to grab the arm to release the bonnet.
Sep 02, 2016 | 2005 Ford Fiesta Zetec
How can I open the hood of a '97 Jeep Cherokee when the rod that pops open the latch is disconnected under the hood?
some times pulling the cable sheath from the side as person 2 pulls lever gets it open (not snapped cable, but stretched)
well , that can be hard. (snapped)
its just a cable. so the tech looks at that.
he sees if the center wire in said cable is broken. is it?
i remove it from lever and pull just it (center) open now?
no, we find it pulls out, and is say 2 foot long. 1/2 normal.
he may see , yes, it is then asks self where exactly
he finds it broken say in the middle. so gains access to that point
and cuts the cable there there , and skins back the sheath,
then pulls the good side center wire, and opens the latch.
now he replaces the cable.
and calibrates it per those words in the FSM.
it has 3 fail modes.
  1. lever broken
  2. cable broken or streatched
  3. or latch broken or needs calibration (adjusted to spec).
the only magic here is the yanking cable at mid span.
while BOB pulls lever. (bob is common mechanics name,a joke?)
LOL
Mar 03, 2015 | Jeep Cars & Trucks
Hood won t close
Check out the cable connection between the latch and your internal latch control. Till you locate the problem I would suggest tying down the hood with some sort of strap so it does not pop open at speed.
Apr 24, 2017 | Chevrolet Malibu Cars & Trucks
Passanger side door locking problem. when I insert the Key, it can turn forward to lock the door, but can not turn backward to unlock the door. And I tried the second key, does not work either.
Really sounds like one of 2 possible problems.
First, perhaps the door latch itself is broken, and that is unlikely, except that I am unfamiliar with that particular latch on that particular car.
Second, it sounds like, if you were to take the door panel off, you would find the latch is locked because one of the locking levers is holding the door latch locked.
There or 2 or 3 lever like things that affect the latch.
There is a lever from the outside door lock that goes to the door latch.
There is a lever from the inside locking handle that goes to the door latch, and yet may be one more.
If any of these are "stuck" or broken, they will "hold" the door latch in the locked position.
Be blessed.
Feb 07, 2013 | 1998 Nissan Altima
Cable to seat latch is broken, how do i open seat
try to access the broken cable with a pair of needlenose pliers or locate the latch lever and depress
Aug 01, 2012 | 2008 Qlink Siena 150
Hello, I'm trying to open the hood of my 1991 nissan maxima. I have pulled on the lever to open, however the lever will not move. I do not want to pull it too hard without damaging it. Please help!!!
It is 20, and 10 years past its designed life, this stuff happens. You need to figure out whether the latch cable has broken or the latch itself is bad. If the cable is bad, you should be able to reach up under the dash, find the cable coming from the back of the lever and pull it out from the inside. If it comes freely, then you know it is broken but do NOT pull it all the way out. If however the cable is good but the latch is broken you are going to have to get at the latch via under the bumper or through the grille, and unbolt it or the male prong on the hood. Some extensions and swivels will come in handy for your socket set. When you get the latch or prong loose the hood will open
There is also a remote possibility that the spring which pops the hood up when you pull the lever has broken and the hood is actually unlatched so long as the lever is pulled. Check this by having someone pull and hold the lever from inside while you try to open the hood and release the secondary.
Jun 21, 2011 | 1991 Nissan Maxima
Microwave door will not latch closed
I just had this problem with a Samsung microwave/hood combo. I pried/popped the inside molding out with a screwdriver. The little lip that the spring attached to had broken. I drilled a hole in the center of the door latch, reattached the spring, replaced in door, replaced inside decorative molding, and fixed in 5 minutes. Thank goodness because it's such a pain to replace these units.
Jun 30, 2010 | Neff B4540 Stainless Steel Electric Single...
1998 subaru legacy hood latch is broken :(
tre spring is on the latch itself,my guess is that the latch needs a little lube,work the area of the latch that the cable slides into with a screwdriver,it should spring back after you lube it
Sep 11, 2009 | Subaru Loyale Cars & Trucks
2007 chevrolet uplander LS the glove boxdoor latch broke,
without taking the dash apart is to use a needle nose plyer locate by grabbing the broken lever pulling the lever to undo the latch.
Aug 28, 2009 | 2007 Chevrolet Uplander LS Minivan
Broken maytag door latch assembly Maytag quiet series 300: the latch is not working, door is closed and cannot open, seems something snapped inside, how can I open the door ? and change the broken part ?
To open this latch, the handle works as a lever to push inward when you push up on the handle. If your handle if broken, it has probably ceased to work as a lever (the pivot pins have likely broken). You want to push in on the handle to open the latch, ideally toward the bottom of the handle opening. Once you get the latch open, you'll likely want to order a replacement (here is one source : http://www.repairclinic.com/PartDetail/Door-Latch/W10130694/1266678 ). Remember to turn off the power to the dishwasher, and you'll need a star head driver to remove the screws from the inside of the door to access and replace the latch.
Andrew
Nov 17, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Remington Polesaw Wizard Logo
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
