Question about Pioneer 2 Handle Satin Nickel 6" Rain Head Shower Faucet+Valve....
Hot water not coming in a MIROLIN shower single handle.Do i have to replace the cartridge?how?
3 Suggested Answers
  • 68 Answers
SOURCE: Single handle Pioneer shower faucet
its the mixing slide in there its stuck u can take it apart at the handle it pulls out shake it if it doesnt move its bad. what happens is over time sediment gets in there and seazes it up. if you take it apart and its not stuck then its ur mixing valve on your boiler is bad good luck
Posted on Dec 21, 2008
koflach79
  • 35 Answers
SOURCE: Hot water dosen't come out.
hot water supply is probably turned off. Is it a rental or did you buy the place? Does it have a crawl space or a basement? Where is your water heater? Start at the water heater and trace the line to the shower. There may be a valve in between that has been shut off. Good luck.
Posted on Feb 21, 2010
Replaced cartridge now only have hot water
You likely took out the anti-scald ring out when you took it apart and then put it in in a different spot preventing the handle from turning far enough. You may also have the cartridge or handle upsidedown.
Nov 25, 2013 | Price Pfister R897EBK Brushed Nickel...
I need a replacement cartridge # 17196-0100k for a single handle price pfiser shower valve. where can i order one?
I have a single handle price pfister shower valve Model 17196-0100k .No cold water.It's coming hot on both sides.
Mar 28, 2011 | Price Pfister R89-7PC0 Chrome Portland...
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
When i turn it on it is only warm at best. when i turn it all the way hot the water comes out in a trickle. all our other showers and sinks get hot water just fine. this is a single handle shower and does...
You will need to remove the old cartridge from inside the shower valve body and either refurbish it with new rubber seals and O rings or replace the cartridge altogether (preferable). It's not a complicated fix but the Posi Temp cartridge can be a bear to remove. Moen and Danco make special 'pullers' to make the cartridge removal go a little easier (sold at Lowes/HD and plumbing supply for anywhere between $15 and $35 but well worth it, IMO).
Oct 27, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Water is not very hot.
First try adjusting the pressure balancing gear located right behind the handle. If you still do not have hot water I suggest to replace the cartridge.
Jan 13, 2010 | Delta & Single Handle Shower Faucet
My shower seems to run even after closing the shower to off position. the water is coming out hot?????? thankyou JOHn Vancouver
REPLACE THE CARTRIDGE. TURN OFF WATER, REMOVE HANDLE AND FACE PLATE. REMOVE TWO SCREWS UNDER PLATE. PULL OUT CARTRIDGE AND INSERT NEW. REASSEMBLE
Jan 06, 2010 | Delta & Single Handle Shower Faucet
Single handle shower no hot water.
when shipped the anti scold is in cold mode remove center handle will c a blue and red adjustment pull red off and move up or down and replace check for desired temp if cold or to hot readjust
Jul 15, 2009 | Moen 3175 Legend One Handle Shower Faucet...
NO HOT WATER IN THE SHOWER
take the control apart. and replace the cartirdge. most likely the washer in the cartridge need to be changed.
it is cheaper to get the cartridge then to replace the washer.
Mar 16, 2009 | Kohler Home
Pioneer 2 Handle Satin Nickel 6" Rain Head Shower Faucet+Valve.... Logo
Top Pioneer Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Pioneer Plumbing Expert? Answer questions, earn points and help others
