Question about GE Monogram ZIR36NMRH Refrigerator
Ice buildup at bottom of refrigerator behind left crisper drawer
SOURCE: Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Posted on Feb 11, 2009
  • 163 Answers
SOURCE: Evaporator fan stops working due to ice buildup around fan.
you need a drain tube heater.it is like a chain fence tie made from alluminum,you can actually use the fence ties,wrap one side around defrost heater and stick the other side in drain.that will prevent it from happening again
Posted on Mar 07, 2009
  • 219 Answers
SOURCE: ge profile water/ice fridge side under bottom drawer
take out the back panel in frzzer side use a steamer to clean out your drain hole
Posted on Mar 19, 2009
  • 2976 Answers
SOURCE: Refrigerator crisper drawers are freezing veggies
Shut the air flow into the crispers if you can. If not, turn the refrigerator temperature warmer by just a few degrees. The air into the fridge from the freezer is channeled into the crispers.
Posted on Jul 01, 2009
woodchuck789
  • 4059 Answers
SOURCE: ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
My Kitchenaid refrigerator deli drawer freezes everything, how can I fix this?
Check the air flow vents for ice buildup, this happened with my whirlpool fridge. Hope it helps.
Feb 03, 2015 | KitchenAid Refrigerators
My crisper drawers collect water
adjust your settings for what you keep in there...and you should be able to solve the problem
Oct 19, 2014 | Samsung RF265AA Bottom Freezer French Door...
Water in bottom vegetable drawer and bottom of refrigerator ge profile side by side
This model has two evaporators, so Do you have an ice ball in behind the crisper (should be on the left)? Is there brown looking water going down the back and collecting under the crispers? I need two things, a complete model number (there is 8 different model with this number you gave) also where is the ice and water located? Thanks
Jul 25, 2014 | GE Profile PSW26P Stainless Steel Side by...
Why is water leaking from the inside bottom of refrigerator?
Hay Lola , your drain hose is clogged open the back panel and blowdry all the ice until the water drains good luck APPLIANCES R EN
Mar 14, 2013 | Magic Chef Refrigerators
My 12 year old subzero fridge (650) is not getting cold. this morning i discovered ice behind the fresh food drawer, removed it, it was running fine, temp 35. now tonight the temp is 51. freezer is fine....
Is it flashing vacuum condenser? Ice behind the crisper drawer shouldn't effect the temp. What is it set at? You can go to www.subzerospecialists.com and click on Tech Help for additional info.
Feb 23, 2011 | Sub-Zero 650 / O Bottom Freezer...
Samsung bottom mount refrigerator RB2055SW/XAC Canada. Symptom: Freezer temperature fluctuates between -5 and -20 degrees centigrade, regardless of temp setting. No ice buildup visible. Fridge is fine,...
The crisper can freeze when air leaks around the base of the duct assembly. To prevent this, the air tower will need to be removed. Disconnect power to the unit first. All the shelves and drawers will need to be removed, to access the tower. With the air tower out, now run a bead of silicone on the floor of the refrigerator where the tower sits. Now replace the duct on top of the sealant to make a tight seal and prevent the air leakage.
Jan 07, 2011 | Refrigerators
I am getting water in the bottom under the crisper drawers and it turns to ice. Where is the leak?
It is coming from the bottom of the back wall, possibly behind a panel. During the defrost cycle, water rolls down into a tray which drains on the compressor from where it evaporates. This is iced up or blocked with debris.
Dec 08, 2009 | Roper Refrigerators
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Ice acculation under crisper drawers
No. There is, however, a drain hole in the back center that tends to get plugged. Remove the lower two drawers and see if it is plugged. It drains to a pan under the unitand behind the kickpanel
Oct 16, 2008 | Sub-Zero Refrigerators
Kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE Monogram ZIR36NMRH Refrigerator Logo
41 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
