Question about Ovens
How to set the clock on a Stoves EL716 - Ovens
5 Suggested Answers
  • 250 Answers
SOURCE: How do I set the clock time on Stoves Cooker
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remianing time.
Posted on Aug 15, 2009
SOURCE: need to adjust clock setting
Press + and - at the same time (manual says hold for 3? seconds) and then + or - to set the time. If from power up, as I did yesterday, I don't think you need to hold them together for any length of time, but maybe it was my imagination, since I tried it first before I read the manual.
Posted on Nov 19, 2010
  • 552 Answers
SOURCE: how to remove door on stoves EL716 toop oven
Click on the link below to watch a video that explains how to remove the door on most modern ovens.
http://www.appliancerepairlesson.com/2011/01/22/oven-door_diy-oven-repair-help-101/
Posted on Mar 06, 2011
SOURCE: Manual for Stoves EL716 oven
I have a Stoves Newhome EL716 double electric oven and last night, it just lost all power and stopped working - no grill, oven, lights, clock or anything. Can anyone tell me what this could be please? Thank you.
Posted on Sep 09, 2011
How do i set the clock on Stoves cooker model number GL 716
if I could see the panel I might be able to tell you ours is press clock then the + or=- buttons
Feb 02, 2017 | Stoves Ovens
How do I replace bulb in oven? Stoves el716 what is bulb part order number?
you can remove the bulb first then go to the local pound shop or a hardware shop or even morrisons or tesco the buld will be a standard screw in but has to be an oven buld not a normal one ive found these bulbs in the local shops easily do not use any unhardened buld for the oven type i replaced one the other day as usual i got a pack of two from the local hardware guy for a couple of quid
Oct 18, 2014 | Ovens
I have a stoves 720ef anf for no obvious reason the clock resets to 23.59 and the oven turns off, can you suggest anything
You obviously have a power loss somewhere. The oven will not work unless a time is set on the clock. I would suggest you have problem with the feed to the cooker which an electician should be able to check it out. If anything else is wrong on the cooker, it shouldn't reset the clock.
Nov 28, 2011 | Stoves 720EF Electric Double Oven
I have a Stoves double oven and after a power cut the clock has stopped working and the main oven is not working either. the clock is completely off. the small top oven is still working though. what can...
The clock controls the ovens. In other words, directly you set any time on the clock, a contact operates within it to provide power to the ovens. (Normally the grill remains operational). You may need a new clock/timer. Before you do so, try switching the power off at the main isolating switch and leaving it off for a few mins, then switching it back on, to try to get the clock to operate. You may need to do this a few times.
Normally Stoves stick a label identifying the model on the left hand edge of the lower oven. You see this when you lower the main oven door. it will probably start with a 05 and be 9 digits long. With this number you can identify the oven and obtain parts.
Nov 07, 2010 | Stoves 720EF Electric Double Oven
How to remove door on stoves EL716 toop oven
I can only say for the 720. You have to remove the whole oven from the kitchen furniture and then unscrew/remove the top and side panels. You will then see the springs on either side of the door.
Important. Remove the inner glass panel from the door first, before you release the springs.
To remove the springs, ensure the door is closed and then unhook them. You then should be able to remove the door frame.
May 07, 2010 | Stoves 720EF Electric Double Oven
How do i set the clock on a stoves 700gr mk2 double gas cooker
my stoves 700gr has stoped workin can you pls help
Dec 12, 2009 | Stoves Ovens
How do I set the clock time on Stoves Cooker efa700h. I would assume the clock is the same on most stoves models
Aug 02, 2009 | Stoves 720EF Electric Double Oven
Need to adjust clock setting on Stoves 900 GDO Stoves 900 GDO gas double oven
Mar 06, 2009 | Stoves Ovens
Feb 22, 2009 | Stoves 720EF Electric Double Oven
Electric stoves
if the model has a digital clock and when the power went of it may have fried the little computor.if you dont have trip switchs in fuse box
Nov 07, 2008 | GE JGRP17 Gas Single Oven
Ovens Logo
212 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
