My gas wall heater makes very loud noises, like a "bang!" noise. Is this dangerous and can it be fixed.
    Problem Solver:
  • 5 Answers
Yes it can take and blow out the fluts in it
Posted on Oct 22, 2013
Therinnaiguy
  • 1420 Answers
SOURCE: Rinnai gas heater loud noise on ignition
It may be, Rinnai suggests a maximum length of about 13 equivalent feet of venting including elbows. Add 6 feet for every 90 degree elbow. If the vent is longer than this it is taxing the combustion fan motor and it will start giving you error codes and will not ignite. Remove the trim panel from behind the heater and find the flexable air intake pipe. Temporally remove it from a fitting and test the unit a few times to see if the unit starts quieter. This procedure will be taking room air into the heater for combustion and circumventing the direct vent feature of the heater, not a fix. Have you had the gas pressure tested? It gould be that! You may wish to consider relocating the heater and fire your installation contractor for putting you in this predicament, not Rinnai.
Posted on Nov 05, 2009
Testimonial: "Thanks very much. Please see comments."
Therinnaiguy
  • 1420 Answers
SOURCE: Loud Knocking
If the noise is not coming from the fan as Buffalo suggests, it is most likely the expansion and contraction of the heat exchanger. The old school way to lessen the noise of expansion is to bank the combustion chamber with a hammer. I don't recommend it today because the metal is so thin (thus all the noise) and you may damage it. You will get used to it and the noise may soften the more it is used. You will never get it to stop.
Posted on Dec 04, 2007
SOURCE: 2000 watt baseboard heater is making loud clicking noise
Most base board heaters installation instructions say to attach to the wall with screws which are slack ( not fully tightened) in order to allow the heater case to expand and contract otherwise you get a clicking noise
Posted on Oct 31, 2008
  • 19 Answers
SOURCE: Oil-filled SoftHeat baseboard heater makes loud gurgling noises
is this for a boiler system
Posted on Apr 22, 2009
SOURCE: brivis ducted heater making a banging noise every
The heating system has a number of burners which must ignite as soon as the heater starts. When one or more burners does not fully or partially start properly, unburnt gas fed to that burner accumulates in a small pocket until is is eventually ignited causing a small explosion. This condition is caused by restricted/blocked burner jets. The gas jets are small and easily fouled by spider nests or other items sucked into the system. You will need to have the heater serviced by a qualified gas plumber.
Posted on Jun 20, 2009
Cozy dual wall heater, makes loud noise and shakes heart when it starts
check gas pressure, natural gas 3.5 and propane 11, also if you have stainless steel burners drill out the first series of holes on the carry over tube to match other holes use 1/64 drill bit.
Feb 27, 2015 | Cozy Heating & Cooling
Washing machine making loud banging cracking noise.
Sounds like something's got between the drum and tub and is resting on the heater element. Remove the heater and check in the gap
May 09, 2012 | Washing Machines
Martin lp gas heater has recently begun to make loud metallic bangs during use. This heater is approximately 15 years old. Can these metal banging noises be a sign of something potentially dangerous? ...
If you can inspect the combustion chamber for cracks it may be a good idea. To get rid of the banging, put a dent in the metal combustion chamber.
Jan 18, 2011 | Heating & Cooling
I have a H100ID1 natural gas heater. For the past 2 weeks it has been heating the water but making a loud banging noise and shaking the whole heater. It stopped making the noise and won't heat the water....
Is it leaking? Has anything shaken loose inside? If you can get it to light the cause and fix for the banging and shaking is here: https://sites.google.com/site/haywardpoolheater/
Takes about 30 minute and you are done, but you have to figure out what else has gone wrong to stop it lighting
Jul 01, 2010 | Hayward 100,000 BTU Pool Heater H100ID1 -...
MY WILLIAMS WALL GAS HEATER MAKES A LOUD BANG AFTER A FEW MINUTES ON
Question, is this bang a metal sound or like a small poof of a gas burner? If it is a metal "bong", it is the heat exchanger expanding. You could hit the combustion chamber with a hammer causing a dent (really) and it may take the noise away. If it is a "poof", it should be looked at by a technician.
Jan 04, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Adjust resonance screw makes loud noise on start up
I'm not sure what you mean "adjust resonance screw". I'm going to guess the adjustment screw your talking about is under at screw cover and is the appliance regulator screw. It adjust the gas input to your burners. Too low pressure is caused by backing the screw off and can result in delayed ignition or a "loud noise". It's really a small explosion caused by built up gas and damage your heater. Too high of pressure is caused by turning the screw in too far and can over-fire the heater which is also dangerous. I'm assuming you burn natural gas because with propane the appliance regulator is wide open. Your gas company may come and use a manometer to set the manifold pressure to factory settings (3.5 to 4.0 W.C.) for you. Otherwise, turn the screw back in until the ignition is not delayed and the loud noise is replaced by a nice quick ignition. Good luck.
Jan 02, 2010 | Empire DV-215 Direct Vent Natural Gas...
My water heater have countinous loud sound?
There are several different things the sound could be. If it is a popping noise it could be from the sediment inside the water heater as it is heating. It could also be noise(bang) from the water pipes having excessive pressure. If the water heater is gas it could be the noise from the burner when in operation or gas regulator vibration. Need a better description of the noise to be more helpful.
Nov 05, 2009 | American Standard Water Heaters
Loud noises, shaking, visible white powder in chlorinator
Stop using the heater immediately. You are boiling the water inside and this can lead to a dangerous situation if a limit switch fails to act in time.
You will likely find the diverter in the inlet side of the heater is broken. You are looking for a stainless steel plate in the water path. If you can move it by hand, it is broke. It is not replaceable and requires a new heat exchanger assembly to repair it.
Your part number is IDXHXA1101. We sell it as will most pool dealers. If you would like a quote, contact us at www.arrowmotor.net
Jun 16, 2009 | Hayward H Series Induced Draft Abg 100,000...
Heating & Cooling Logo
310 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
