I have a Goodman Furnace model GDS80705AXBB installed in 2008 new house. Over the past month it has been shutting itself off before the room temp is reached then tries to run again but does not ignite. At times it will run just fine like when the repairman is here. The 1st visit the inducer motor was replaced and 2 more visits since. The wires were cleaned and changed the ground connection. Now a new wiring harness is ordered. It flashes 4 times which the manual says - the Primary limit circuit is open. Does all the wiring need to be replaced on this? What do you think is the problem? Thank You KC
    Problem Solver:
  • 8 Answers
Your furnace should have a 5 year warranty. Check with Goodmanmfg.com and see if it is still covered. The installer should have registered the serial #.
Posted on Dec 18, 2013
4 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: furnace won't stay running
1 FLASH
Furnace fails to operate.
• Integrated control module
diagnostic LED is
flashing ONE (1) flash.
• Furnace lockout due
to an excessive
number of ignition
“retries” (3 total)1.
• Failure to establish flame.
Cause may be no gas to
burners, front cover
pressure switch stuck open,
bad igniter or igniter
alignment, improper orifices,
or coated/oxidized or
improperly connected flame
sensor.
• Loss of flame after establishment.
Cause may be
interrupted gas supply, lazy
burner flames (improper gas
pressure or restriction in flue
and/or combustion air
piping), front cover pressure
switch opening, or improper
induced draft blower
performance.
• Locate and correct gas
interruption.
• Check front cover
pressure switch
operation (hose, wiring,
contact operation).
Correct if necessary.
• Replace or realign
igniter.
• Check flame sense
signal. Sand sensor if
coated and/or oxidized.
• Check flue piping for
blockage, proper
length, elbows, and
termination.
• Verify proper induced
draft blower performance.
Posted on Nov 25, 2008
machtcl1
  • 61 Answers
SOURCE: Goodman furnace GMPN080-4 Getting 4 RED blinks/Open Limit Swtch
You have a limit switch located in the furnace (a little bigger than a dime and located near the center of the front panel, sometimes the switch is mounted to a small fiberglass board) . There will be two wires going to it. They sometimes trip so often that they fail to automatically reset(due to dirty filters or undersized ductwork). You can SHUT OFF POWER TO THE FURNACE, then remove the two screws holding the switch in the furnace, pull the switch out of the furnace and tap on it and wipe it off.
The switch may work a few more times but should be replaced with the same size and type. You will see some rating printed on the switch somewhere. Write down all the numbers and get a replacemet from a furnace/AC supply house. If you have a meter and know how to use it you could check the switch for continuity.
Sometimes just a tap on the switch will get it going. There will also be a couple of rollout switches that could be tripped. They have little buttons on them to reset them. If they trip it may have other issues to be solved.
Hope this helps!
Matt
Posted on Feb 01, 2009
james3751
  • 614 Answers
SOURCE: goodman gmp 125-4 gas trouble code
Rewire to schematic specs and check po;larity of transformer. Rus
Posted on Nov 04, 2009
Amana model gmh95070
Don't need the blue wire is common for the ac condsor unit what t-stat is it honeywell 4000 6000 8000 or one of rth models there is many t-stats as far as you saying fan stayes on check the auto / on section of the t-stst main wirers are RH/R-power W-heating Y-coolin G-fan
Mar 14, 2014 | Goodman Heating & Cooling
Fraser Johnston Furnace - Not heating
Check the furnace filter to make sure its not dirty . Dity airvfilters can cause the furnace to overheat and shut off on a high temperature limit switch when the switchs cools down it resets but the furnace has to be shut off to reset the control board. Hope this helps.
Jan 23, 2014 | Heating & Cooling
My girlfriend has a forced air Goodman furnace in her house. Her furnace has been not running well. Whenever the filter gets dirty the furnace does not run right which it to be expected. The problem is...
where is the thermostat located? i should be on a inside wall in a comon room and not around lights, computer or heat vent or air return. a thermostat is just a switch and will operate in its enviroment. does the fan cycle off before the heat starts blowing again? the fan on these are on a timer that the t stat will have to "brake" open on reaching temp to shut off. not knowing where your at look this over and i hope it helps. i dont think i would let someone sell me a control board for this problem.
Feb 08, 2011 | Goodman GMS90703BXA Heater
I'm not sure of the exact model of my Goodman furnace, but here is the problem. The new furnace was installed this summer (2010) and it is mounted in the space under the house in Big Bear Lake, CA....
I suppose this furnace is fueled by Natural Gas?
(Or is it Propane-- Bottled gas?)
Did the Service company leave you any manual, with your new furnace?
and I would think there was a warranty, for assuring you (the customer) satisfaction, no?
Have you called the people who sold/installed it?
What do they say?
If they did leave a manual-- what does it suggest for narrowing down your possible problems?
Like: Low Fuel-- Low Voltage- Filter Changes, Fan switch problems- or ignition failure problems?
For a new furnace, someone should be right there to do a start-up for you!
Let me know what you learn--
Mack B
Jan 14, 2011 | Goodman GMS80903BNA Heater
Goodman GMP075-3 not igniting. Everything cycles as it should but HSI does not glow. Thermostat is set to heat, temp approximately 10 to 15 degrees higher than room temp, blower motor starts, relay clicks...
The flash code is due to the furnace not proving flame 3 times in a row. If you have a multimeter you can ohm the ignitor out to see if it is good. Depending on the type (silicon Nitride or silicon Carbide) you can verify if it is good. A silicon Nitride ignitor looks like a small thin straight bar type will ohm @ 11 - 18 ohms, a carbide ignitor looks kinda like a tuning fork (sorta) will typically ohm @ 40 - 92 ohms. anything outside of those ranges will require a replacement.
Nov 02, 2010 | Goodman GMS90703BXA Heater
Goodman furnace model # GMNT100-4B On vacation neighbor checked house house filled with gas. He shut off main and furnace. Came home turned on gas to everything except furnace. All good. Furnace will not...
from my experience with goodman units ,it could have been a gas supply problem there are so many protective sensors that i dont think it is the unit by the way is it electronic ignitor or pilot
May 14, 2010 | Goodman GMS90703BXA Heater
Questionable installation of a Goodman furnace.
That seems to be the common practice. The low pressure created by the suction of the fan will draw air in from outside.
May 03, 2010 | Goodman GMS90703BXA Heater
Goodman furnace model # GMNT100-4B On vacation, neighbor checked house, house filled with gas. He shut off main and furnace. came home turned on gas to everything except furnace. All good. Furnace will...
Solid red typically means bad controller. Try unplugging the furnace, wait about 30 secs, then plug it back in. The possibility that the controller was sending voltage to the valve even when there was no flame is a bad sign. If the controller starts the furnace, watch it very closely and see what it does. If the solid light comes back on, it's time for a new board.
Mar 24, 2010 | Goodman GMS90703BXA Heater
Furnace cuts out because of "low air flow", then starts again
try the furnace without the filter. if it stays running then find out what filter came with the furnace. if you have the owners manual. look for the simple things first. blockage, is the motor and fan runnin properly.. good luck
Apr 09, 2009 | Goodman GMS90703BXA Heater
WHEN THE HEATER COMES ON THE FAN STARTS INSTANTLY AND BLOWS COLD
Do you have a heat pump? If so this is normal. You are probably used to a gas furnace. There are heat pumps that do have a delay though. Look on the circuit board in the air handler. There may be a set of pins that say 0-30-60-90 yours may be at 0. Also some digital T-stats offer that function for delay off to get the extra heat or cold from the system. Find out what the model number of the air handler and call the Goodman supplier in your area to see if you have these options.
If you have a gas furnace and it's not delaying the blower there is definately something wrong.
Mar 17, 2009 | Goodman Heating & Cooling
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
