Question about Luxor 19822 COB
The tv screen has went pink - Luxor 19822 COB
Bravia TV has pink screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 01, 2015 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
All other input works fine e.g. dvd, TV went pink screen.
If other inputs show no problems and you are not using a cable box or satellite receiver, etc. just off air antenna, something on the main board is failing. please double check other inputs again.
Feb 17, 2014 | LG 32LC7D Television
TV stopped working
Your description suggests a power supply problem
Feb 23, 2013 | Televison & Video
Have sharp quos 52" screen went pink. Can still
Hi, My guess is your daughter messed it up. Go to menu and color and reset to default should fix it.
You may have to adjust color for your best viewing. Good luck.
Sep 27, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
MY TV DIED=(
Your controller board went out inside the TV and needs repair. I hope this information helps you out.
Apr 23, 2009 | Philips 60P8341 60" Rear Projection...
Pink Screen
Most likely the green electron-gun in the CRT is failing.
Jerry G.
Jun 11, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Pink screen
When the "pink screen" happens on my Polaroid FLM-1911 TV, I unplug the power cord from the back of the unit, wait 30 seconds, and replug it. This fixes the problem.
Oct 23, 2007 | Televison & Video
Pink Screen
There is a service bulletin for this problem - you need to reintialize the memory settings in the service menu - I have a pdf file showing how to do this.
Sep 09, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Luxor 19822 COB Logo
18 people viewed this question
Top Luxor Televison & Video Experts
Sp Gupta
sureshd2008
rugby prop
Are you a Luxor Televison and Video Expert? Answer questions, earn points and help others
