Question about Rotel Rsp-1068
Return factory specs reset - Rotel Rsp-1068
Will a hard reset on lg lucid smartphone restore uninstalled apps
Yes, that will make it so that the software will return to the factory state. If not then you'll have to either follow the prompts through the phone menus or boot mode to initiate a factory data reset.
Mar 17, 2014 | LG Lucid VS840 4G Verizon
Go to the NetGear device and pull the power plug out, look for the rest pin (the small port) and push a paper clip into the port. Hold it down and reattach the power line. Hold for 10 seconds. This should return the device to Factory specs. Resinsall the software you were provided with and came in the box. Start over and go from there.
Jan 24, 2014 | NetGear FS608 Networking Switch
I forgot the password to my htc mytouch 4g phone
The only thing you can do is reset the phone to factory specs, unfortunately, you'll lose your data if not already backed up. Follow this procedure:
What does a Hard Reset do and how is it performed?
A hard reset removes all information from your device and returns it to a state just like it has never been used before. All contacts, messages, emails, 3rd party applications, etc. will need to be reinstalled after performing a hard reset. To perform a hard reset, from the Home screen tap Menu > Settings > SD & phone storage > Factory data reset. Follow the on-screen prompts to complete. This process will take 5-10 minutes
src: http://www.htc.com/us/support/t-mobile-mytouch-4g/help/general-and-other
Apr 13, 2011 | Cameras
How do you return the netbook to factory settings
if this is the SYNET07526:
Did you try the reset button on the back? about 1in. diagonally from the right lower corner of the data plate. insert a tooth pick in the little hole and hold for about ten seconds with the power plugged in. This should reset it to the factory specs.
If that does not work then you may have to flash the system. If you decide to do this, see my TIP at:
: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
Jan 18, 2011 | Sylvania G-Netbook
I forgot my pattern and google accout to unlock my motorola cliq.
The only way is to hard reset the phone. That will erase all your data and it will return back to factory specs.
http://www.technipages.com/hard-reset-motorola-cliq.html
Oct 19, 2010 | Motorola Mobility CLIQ Cell Phone
Reset password on compaq evo desktop for windows xp professional. Present password forgotten.
...ONLY A TRY HERE, BUT GO INTO SETUP,RESET TO "DEFAULT" TO RETURN EVERYTHING TO FACTORY SPECS.YOU WANT LOSE ANY OF YOUR DATA, HOPEFULLY.
I recently bought a new Dell with Win7 preloaded...it inadvertently came with a password installed...Dell's oops...had to send a tech out with new HDD and a backup disc I didn't get. Passwords are now stored on HDD's!
Mar 06, 2010 | Compaq Evo D510 PC Desktop
Bought used phone and did not recieve security code
Hard reset to return the phone to factory specs. Search manufacturer website or ask your service provider.
Oct 17, 2009 | Cell Phones
Reset to factory specs for blackberry curve 8330
how to reset the Curve back to factory state (a complete wipe-out). Please note if you just want to reboot the device, you only need to take out the battery.
To reset the phone back to factory state:
Go to Options -> Security Options -> General Settings
Press the BlackBerry Menu key and select "Wipe Handheld" and type in "blackberry"
Thanks.
Jun 04, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Resetting data
A Hard Reset wipes the internal memory and returns the Treo to its factory specs, in effect returning the Treo 750 to the state it was in when you purchased it. All data entered, preferences set or software installed on the Treo after purchase will be lost after a hard reset and will have to transferred or reinstalled via ActiveSync / Windows Mobile Device Center.
power_button.jpg The Palm Treo 750 can be hard reset by pressing and holding the power button (seen left) while at the same time pressing and holding reset button beneath the miniSD memory card door. Press and hold the two buttons until the screen completely fades. When the screen returns, you'll be given the option to "Erase all data." Select Yes to complete the hard reset.
The Treo will now be as it was when it left the factory and you can start fresh. You may have to perform a soft reset after the hard reset to get the unit to power on.
May 07, 2008 | Palm Treo 750 Smartphone
How to reset to factory specs??
Enter the SETUP menu and select RESET. You'll be prompted to reset two sections. Answer YES to both and everything that can be set to default will go back to the factory default state.
Jan 13, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Open Questions:
Rotel Rsp-1068 Logo
26 people viewed this question
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
richie46
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
